HMs DIY #1-6
Store Link
Because I want to keep this datafield and the app free for use I would be very grateful about a small donation to PayPal
A detailed description of how to use it can be found here:
HMs_DIY_GUIDANCE.pdf
HMs_DIY_ANLEITUNG.pdf
Thanks very much to mcinner1 for putting so much time into this documentation!
Designer download
You can contribute on my github page.
You can upload your layout so others can use it as well.
Also any changes to the fonts.txt can be updated there as well.
Garmin_HMsDIY
RELEASE NOTES
3.9.1
* switched to new SDK 9.3.0
* added devices: Approach S72 43mm, Approach S72 47mm, D2 Mach 2 Pro, Edge 1060, Edge Explore 3, Edge Explore 3 Plus, Enduro 4, fenix 9 43mm, fenix 9 47mm, fenix 9 Pro 43mm, fenix 9 Pro 47mm, fenix 9 Pro 51mm,
fenix 9 Pro Solar 47mm, fenix 9 Pro Solar 51mm, Forerunner 70, Forerunner 170, Forerunner 170 Music, MARQ (Gen 3)
3.8.3
* fixed problem with backslash in configuration string
3.8.1
* switched to new SDK 8.3.0
* added devices: Approach S50, D2 Mach 2, Descent G2, Edge 550, Edge 850, Edge MTB, eTrex Touch, fēnix 8 Pro 47mm / 51mm / MicroLED, Forerunner 970, Forerunner 570 42mm, Forerunner 570 47mm,
GPSMAP H1, Instinct 3 AMOLED 45mm, Instinct 3 AMOLED 50mm, Instinct 3 Solar 45mm / 50mm, Instinct Crossover AMOLED, Instinct E 40mm, Instinct E 45mm, Venu 4 41mm, Venu 4 45mm / D2 Air X15, Venu X1, vívoactive 6
for full releasenotes see: releasenotes.txt
  • Did you restart the datafield?
    Yes - DIY loaded after setting night-mode!
  • As you can see on that Edge screenshot:
    Speedsensor status = 3, but the blue crossed circle does not hide.
    And there is nothing at the place of Version and App:
  • It's bad that those bugs exist - but I'm glad, that I'm not the only with this problems Wink
    BTW, I have a special test layout for the Edge 1030 to see, how good the fonts between designer and device matches...
    I think that some could be better but currently I didn't have the time to fix them in the fonts.txt
    But what is a bit strange: even in Designer they do not match perfectly to e.g. a line.
    Actually all font examples should start at the same y position as a line - but they don't...
    Any explanations for that?
    <?xml version="1.0" encoding="UTF-8"?>
    <DIYLayout>
        <Device name="Edge 1030"/>
        <LayoutElement type="1" color="FF0000" x="0" y="235" x2="281" y2="235" eletype="LN" valuetype="FX" radius="1" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="141" y="0" x2="141" y2="469" eletype="LN" valuetype="FX" radius="1" stroke="1" nr_values="1"/>
        <LayoutElement type="3" text="----------------- XTINY: ------------------"/>
        <LayoutElement type="1" color="666666" x="100" y="0" x2="100" y2="469" eletype="LN" valuetype="FX" radius="1" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="666666" x="181" y="0" x2="181" y2="469" eletype="LN" valuetype="FX" radius="1" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="666666" x="0" y="10" x2="281" y2="10" eletype="LN" valuetype="FX" radius="1" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="666666" x="0" y="10" fixedtext="true" eletype="FX" text="XTINY" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="666666" x="100" y="10" fixedtext="true" eletype="FX" text="XX" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="666666" x="141" y="10" fixedtext="true" eletype="FX" text="XX" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="666666" x="181" y="10" fixedtext="true" eletype="FX" text="XX" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="666666" x="281" y="10" fixedtext="true" eletype="FX" text="XTINY" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="3" text="----------------- TINY: -------------------"/>
        <LayoutElement type="1" color="777777" x="90" y="0" x2="90" y2="469" eletype="LN" valuetype="FX" radius="1" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="777777" x="191" y="0" x2="191" y2="469" eletype="LN" valuetype="FX" radius="1" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="777777" x="0" y="30" x2="281" y2="30" eletype="LN" valuetype="FX" radius="1" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="777777" x="0" y="30" fixedtext="true" eletype="FX" text="TINY" font="TINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="777777" x="90" y="30" fixedtext="true" eletype="FX" text="XX" font="TINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="777777" x="141" y="30" fixedtext="true" eletype="FX" text="XX" font="TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="777777" x="191" y="30" fixedtext="true" eletype="FX" text="XX" font="TINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="777777" x="281" y="30" fixedtext="true" eletype="FX" text="TINY" font="TINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="3" text="----------------- SMALL: --------------------"/>
        <LayoutElement type="1" color="888888" x="80" y="0" x2="80" y2="469" eletype="LN" valuetype="FX" radius="1" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="888888" x="201" y="0" x2="201" y2="469" eletype="LN" valuetype="FX" radius="1" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="888888" x="0" y="60" x2="469" y2="60" eletype="LN" valuetype="FX" radius="1" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="888888" x="0" y="60" fixedtext="true" eletype="FX" text="SMALL" font="SMALL" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="888888" x="80" y="60" fixedtext="true" eletype="FX" text="XX" font="SMALL" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="888888" x="141" y="60" fixedtext="true" eletype="FX" text="XX" font="SMALL" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="888888" x="201" y="60" fixedtext="true" eletype="FX" text="XX" font="SMALL" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="888888" x="281" y="60" fixedtext="true" eletype="FX" text="SMALL" font="SMALL" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="3" text="----------------- MEDIUM: ------------------"/>
        <LayoutElement type="1" color="999999" x="70" y="0" x2="70" y2="469" eletype="LN" valuetype="FX" radius="1" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="999999" x="211" y="0" x2="211" y2="469" eletype="LN" valuetype="FX" radius="1" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="999999" x="0" y="95" x2="469" y2="95" eletype="LN" valuetype="FX" radius="1" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="999999" x="0" y="95" fixedtext="true" eletype="FX" text="MED" font="MEDIUM" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="999999" x="70" y="95" fixedtext="true" eletype="FX" text="XX" font="MEDIUM" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="999999" x="141" y="95" fixedtext="true" eletype="FX" text="XX" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="999999" x="211" y="95" fixedtext="true" eletype="FX" text="XX" font="MEDIUM" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="999999" x="281" y="95" fixedtext="true" eletype="FX" text="MED" font="MEDIUM" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="3" text="----------------- LARGE: ------------------"/>
        <LayoutElement type="1" color="AAAAAA" x="60" y="0" x2="60" y2="469" eletype="LN" valuetype="FX" radius="1" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="AAAAAA" x="221" y="0" x2="221" y2="469" eletype="LN" valuetype="FX" radius="1" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="AAAAAA" x="0" y="135" x2="469" y2="135" eletype="LN" valuetype="FX" radius="1" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="AAAAAA" x="0" y="135" fixedtext="true" eletype="FX" text="LG" font="LARGE" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="AAAAAA" x="60" y="135" fixedtext="true" eletype="FX" text="XX" font="LARGE" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="AAAAAA" x="141" y="135" fixedtext="true" eletype="FX" text="XX" font="LARGE" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="AAAAAA" x="221" y="135" fixedtext="true" eletype="FX" text="XX" font="LARGE" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="AAAAAA" x="281" y="135" fixedtext="true" eletype="FX" text="LG" font="LARGE" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="3" text="----------------- NR_MILD: ------------------"/>
        <LayoutElement type="1" color="BBBBBB" x="50" y="0" x2="50" y2="469" eletype="LN" valuetype="FX" radius="1" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="BBBBBB" x="231" y="0" x2="231" y2="469" eletype="LN" valuetype="FX" radius="1" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="BBBBBB" x="0" y="244" fixedtext="true" eletype="FX" text="Mild" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="BBBBBB" x="50" y="235" fixedtext="true" eletype="FX" text="00" font="NR_MILD" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="BBBBBB" x="141" y="235" fixedtext="true" eletype="FX" text="88" font="NR_MILD" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="BBBBBB" x="231" y="235" fixedtext="true" eletype="FX" text="00" font="NR_MILD" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="BBBBBB" x="281" y="244" fixedtext="true" eletype="FX" text="Mild" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="3" text="----------------- NR_MEDIUM: ------------------"/>
        <LayoutElement type="1" color="CCCCCC" x="40" y="0" x2="40" y2="469" eletype="LN" valuetype="FX" radius="1" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="CCCCCC" x="241" y="0" x2="241" y2="469" eletype="LN" valuetype="FX" radius="1" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="CCCCCC" x="0" y="280" x2="469" y2="280" eletype="LN" valuetype="FX" radius="1" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="CCCCCC" x="0" y="293" fixedtext="true" eletype="FX" text="Med" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="CCCCCC" x="40" y="280" fixedtext="true" eletype="FX" text="00" font="NR_MEDIUM" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="CCCCCC" x="141" y="280" fixedtext="true" eletype="FX" text="88" font="NR_MEDIUM" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="CCCCCC" x="241" y="280" fixedtext="true" eletype="FX" text="00" font="NR_MEDIUM" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="CCCCCC" x="281" y="293" fixedtext="true" eletype="FX" text="Med" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="3" text="----------------- NR_HOT: ------------------"/>
        <LayoutElement type="1" color="DDDDDD" x="30" y="0" x2="30" y2="469" eletype="LN" valuetype="FX" radius="1" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="DDDDDD" x="251" y="0" x2="251" y2="469" eletype="LN" valuetype="FX" radius="1" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="DDDDDD" x="0" y="335" x2="469" y2="335" eletype="LN" valuetype="FX" radius="1" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="DDDDDD" x="0" y="354" fixedtext="true" eletype="FX" text="Hot" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="DDDDDD" x="30" y="335" fixedtext="true" eletype="FX" text="00" font="NR_HOT" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="DDDDDD" x="141" y="335" fixedtext="true" eletype="FX" text="88" font="NR_HOT" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="DDDDDD" x="251" y="335" fixedtext="true" eletype="FX" text="00" font="NR_HOT" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="DDDDDD" x="281" y="354" fixedtext="true" eletype="FX" text="Hot" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="3" text="----------------- NR_TAI_HOT: ------------------"/>
        <LayoutElement type="1" color="EEEEEE" x="0" y="395" x2="469" y2="395" eletype="LN" valuetype="FX" radius="1" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="EEEEEE" x="0" y="424" fixedtext="true" eletype="FX" text="THot" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="EEEEEE" x="30" y="395" fixedtext="true" eletype="FX" text="00" font="NR_THAI_HOT" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="EEEEEE" x="141" y="395" fixedtext="true" eletype="FX" text="88" font="NR_THAI_HOT" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="EEEEEE" x="251" y="395" fixedtext="true" eletype="FX" text="00" font="NR_THAI_HOT" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="EEEEEE" x="281" y="424" fixedtext="true" eletype="FX" text="THot" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
    </DIYLayout>
  • Please read the Guidance (auch in deutsch: Anleitung) at the top of this thread. There us a whole chapter expkaining fontmapping!
  • Thank, I got it working now.  It would be helpful if the error message stated the version was wrong.  I think I was doing things at just the wrong time.  I looked for a newer version of designer, but it looked the same.  A short while later, I saw a newer version available.
    I could not find the mention of needing all 4 clones in the guidance, but I will give it a try.
    Thanks again
  • I could not find the mention of needing all 4 clones in the guidance, but I will give it a try.
    You need not all 4 clones. If you only set one datafield, one clone is enough!
  • And here are my test layouts for day and night.
    Day:
    <DIYLayout>
        <LayoutElement type="1" color="FFFFFF" x="0" y="0" x2="282" y2="470" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="FFFF00" x="0" y="0" fixedtext="false" eletype="CN" text="HMs DIY #1" font="SMALL" halignment="2" precision="0" nr_values="1" sampletext="HMs DIY #1"/>
        <LayoutElement type="0" color="FFFF00" x="125" y="0" fixedtext="false" eletype="DV" text="$V" font="SMALL" halignment="2" precision="0" nr_values="1" sampletext="2.6.0"/>
        <LayoutElement type="0" color="FFFF00" x="185" y="0" fixedtext="false" eletype="DV" text="2.x.x" font="SMALL" halignment="2" precision="0" nr_values="1" sampletext="2.x.x"/>
        <LayoutElement type="0" color="FF0080" x="0" y="25" fixedtext="false" eletype="XX" text="noch $V Byte frei" font="MEDIUM" halignment="2" precision="0" nr_values="1" sampletext="1312314"/>
        <LayoutElement type="0" color="00FF40" x="141" y="55" fixedtext="true" eletype="FX" text="Hallo" font="LARGE" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="00FF00" x="141" y="100" fixedtext="false" eletype="ND" text="Mordor" font="LARGE" halignment="1" precision="0" nr_values="1" sampletext="Trallala "/>
        <LayoutElement type="0" color="00FF00" x="141" y="139" fixedtext="false" eletype="NN" text="Eribor" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="Eribor"/>
        <LayoutElement type="1" color="0000FF" x="141" y="235" x2="0" y2="0" eletype="DT" valuetype="FX" radius="40" stroke="10" nr_values="1"/>
        <LayoutElement type="1" color="0000FF" x="141" y="235" x2="0" y2="0" eletype="CR" valuetype="FX" radius="50" stroke="2" nr_values="1"/>
        <LayoutElement type="0" color="FF8000" x="0" y="400" fixedtext="false" eletype="CT" text="$D.$N.$Y" font="MEDIUM" halignment="2" precision="0" nr_values="1" sampletext="63312"/>
        <LayoutElement type="0" color="FF8000" x="0" y="430" fixedtext="false" eletype="CT" text="$H:$M:$S" font="MEDIUM" halignment="2" precision="0" nr_values="1" sampletext="63312"/>
        <LayoutElement type="0" color="FFFFFF" x="141" y="300" fixedtext="true" eletype="FX" text="das ist weiß" font="SMALL" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="141" y="324" fixedtext="true" eletype="FX" text="das ist schwarz" font="SMALL" halignment="1" precision="0" nr_values="1" sampletext=""/>
    </DIYLayout>
    Night:
    <DIYLayout>
        <LayoutElement type="0" color="8080FF" x="141" y="355" fixedtext="true" eletype="FX" text="DARK" font="LARGE" halignment="1" precision="0" nr_values="1" sampletext=""/>
    </DIYLayout>
  • Is "Distance to next point"  the same as Garmin "Distance to Next" or"Course PT Distance"?   Can "Course PT Distance" be added if it is not currently available?
  • I found the problems. Because I split the code into 3 separate files (low, med, hig) to save some memory, I forgot to change the bits in the "hig" source code. I am sorry for that.
    Hiding, app version and name should work again, version coming soon.
  • Hi
    Sorry, datafields do not have permission to access courses or routes.
    regards
    Erich
