HMs DIY #1-6
Store Link
Because I want to keep this datafield and the app free for use I would be very grateful about a small donation to PayPal
A detailed description of how to use it can be found here:
HMs_DIY_GUIDANCE.pdf
HMs_DIY_ANLEITUNG.pdf
Thanks very much to mcinner1 for putting so much time into this documentation!
Designer download
You can contribute on my github page.
You can upload your layout so others can use it as well.
Also any changes to the fonts.txt can be updated there as well.
Garmin_HMsDIY
RELEASE NOTES
3.9.1
* switched to new SDK 9.3.0
* added devices: Approach S72 43mm, Approach S72 47mm, D2 Mach 2 Pro, Edge 1060, Edge Explore 3, Edge Explore 3 Plus, Enduro 4, fenix 9 43mm, fenix 9 47mm, fenix 9 Pro 43mm, fenix 9 Pro 47mm, fenix 9 Pro 51mm,
fenix 9 Pro Solar 47mm, fenix 9 Pro Solar 51mm, Forerunner 70, Forerunner 170, Forerunner 170 Music, MARQ (Gen 3)
3.8.3
* fixed problem with backslash in configuration string
3.8.1
* switched to new SDK 8.3.0
* added devices: Approach S50, D2 Mach 2, Descent G2, Edge 550, Edge 850, Edge MTB, eTrex Touch, fēnix 8 Pro 47mm / 51mm / MicroLED, Forerunner 970, Forerunner 570 42mm, Forerunner 570 47mm,
GPSMAP H1, Instinct 3 AMOLED 45mm, Instinct 3 AMOLED 50mm, Instinct 3 Solar 45mm / 50mm, Instinct Crossover AMOLED, Instinct E 40mm, Instinct E 45mm, Venu 4 41mm, Venu 4 45mm / D2 Air X15, Venu X1, vívoactive 6
for full releasenotes see: releasenotes.txt
  • Hi
    It seems you got the versions mixed up. All versions should be on 2.7.3 and the designer too!
    I tried hiding, and showing version number, worked without a problem!
    Black/white switching is on my todo list, I will have to find a practical way to implement it.
    I added all available ANT+ device types. Have you tried Fitnessequipment ANT fields?
  • Does the day/night switching and the usage of the special "dark mode" string work for anybody at any device?
    Yes it works fine!
    What you have to consider is:
    you have to build 2 different layouts:
    DAY: the one you are used to. Note: the white rectangle over all the display would be not necessary for the Edge, because the background for DAY is white anyway. The white rectange only is necessary to see your work on the designer!
    NIGHT: You have to toggle all black text to white, colored elements can stay as they are. Remove the white rectangle.
    (No automatic color reversal!)
    I did it that way:
    -Open the XML-layout file with any simple texteditor
    -Replace all Color 000000 with 888888 (or whatever...)
    -Replace all Color FFFFFF with 000000
    -Replace all Color 888888 with FFFFFF
    See my layout for NIGHT:
    <?xml version="1.0" encoding="UTF-8"?>
    <DIYLayout>
        <Device name="Edge 1030"/>
        <LayoutElement type="1" color="000000" x="0" y="0" x2="282" y2="470" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="141" y="3" fixedtext="true" eletype="FX" text="© HM-DIY" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="3" text="***   DATENFELD BEGRENZUNG   ***"/>
        <LayoutElement type="1" color="FFFFFF" x="141" y="577" x2="0" y2="0" eletype="CR" valuetype="FX" radius="500" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="0" y="166" x2="282" y2="166" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="0" y="224" x2="282" y2="224" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="0" y="354" x2="282" y2="354" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="0" y="412" x2="282" y2="412" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="141" y="166" x2="141" y2="223" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="141" y="355" x2="141" y2="412" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="92" y="412" x2="92" y2="470" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="190" y="412" x2="190" y2="470" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="3" text="***   BATTERY   ***"/>
        <LayoutElement type="1" color="FFFFFF" x="14" y="19" x2="46" y2="33" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="46" y="22" x2="50" y2="30" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="16" y="21" x2="44" y2="31" eletype="RF" valuetype="BV" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="16" y="21" x2="19" y2="31" eletype="RF" valuetype="BV" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="00B001" x="16" y="21" x2="44" y2="31" eletype="RH" valuetype="BV" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="38" y="37" fixedtext="false" eletype="BV" text="$V" font="SMALL" halignment="0" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="38" y="37" fixedtext="true" eletype="FX" text="%" font="SMALL" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="2" replDC="00B001" valDC00="1000" colDC00="00C000" valDC01="200" colDC01="00C000" valDC02="110" colDC02="F8C840" valDC03="1" colDC03="FF0000" invertcolor="false"/>
        <LayoutElement type="3" text="***   TEMPERATUR   ***"/>
        <LayoutElement type="0" color="FFFFFF" x="272" y="19" fixedtext="false" eletype="TM" text="$V °C" font="SMALL" halignment="0" precision="1" nr_values="1"/>
        <LayoutElement type="3" text="***   DATEN IM OBEREN BEREICH   ***"/>
        <LayoutElement type="0" color="FFFFFF" x="139" y="36" fixedtext="false" eletype="CC" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="167" y="45" fixedtext="true" eletype="FX" text="rpm" font="SMALL" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="88" y="101" fixedtext="true" eletype="FX" text="Speed" font="SMALL" halignment="0" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="144" y="89" fixedtext="false" eletype="CS" text="$V" font="NR_MEDIUM" halignment="1" precision="1" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="191" y="101" fixedtext="true" eletype="FX" text="km/h" font="SMALL" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="29" y="136" fixedtext="false" eletype="AS" text="$V" font="MEDIUM" halignment="1" precision="1" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="30" y="136" fixedtext="false" eletype="AS" text="$V" font="MEDIUM" halignment="1" precision="1" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="56" y="141" fixedtext="true" eletype="FX" text="km/h" font="TINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="143" y="140" fixedtext="true" eletype="FX" text="avg." font="TINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="237" y="136" fixedtext="false" eletype="AC" text="$V" font="MEDIUM" halignment="0" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="236" y="136" fixedtext="false" eletype="AC" text="$V" font="MEDIUM" halignment="0" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="274" y="141" fixedtext="true" eletype="FX" text="rpm" font="TINY" halignment="0" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="10" y="170" fixedtext="true" eletype="FX" text="Timer" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="85" y="188" fixedtext="false" eletype="TT" text="$H:$M:$C" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="150" y="170" fixedtext="true" eletype="FX" text="Strecke" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="238" y="188" fixedtext="false" eletype="DS" text="$V" font="NR_MILD" halignment="0" precision="1" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="259" y="197" fixedtext="true" eletype="FX" text="km" font="SMALL" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="3" text="***   HERZ + POWER+ TE Bereich   ***"/>
        <LayoutElement type="1" color="F80001" x="71" y="238" x2="0" y2="0" eletype="CF" valuetype="FX" radius="7" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="F80001" x="82" y="238" x2="0" y2="0" eletype="CF" valuetype="FX" radius="7" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="F80001" x="77" y="244" x2="0" y2="0" eletype="CF" valuetype="FX" radius="6" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="F80001" x="66" y="241" x2="78" y2="252" eletype="LN" valuetype="FX" radius="6" stroke="3" nr_values="1"/>
        <LayoutElement type="1" color="F80001" x="87" y="241" x2="76" y2="252" eletype="LN" valuetype="FX" radius="6" stroke="3" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="99" y="224" x2="183" y2="255" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="141" y="229" fixedtext="false" eletype="TE" text="TE  $V" font="SMALL" halignment="1" precision="1" nr_values="1"/>
        <LayoutElement type="1" color="0F4FFF" x="204" y="232" x2="216" y2="241" eletype="LN" valuetype="FX" radius="0" stroke="6" nr_values="1"/>
        <LayoutElement type="1" color="0F4FFF" x="196" y="243" x2="207" y2="252" eletype="LN" valuetype="FX" radius="0" stroke="6" nr_values="1"/>
        <LayoutElement type="1" color="0F4FFF" x="208" y="238" x2="203" y2="245" eletype="LN" valuetype="FX" radius="0" stroke="4" nr_values="1"/>
        <LayoutElement type="1" color="D0D0D0" x="141" y="286" x2="159" y2="202" eletype="AC" valuetype="FX" radius="122" stroke="20" nr_values="1"/>
        <LayoutElement type="1" color="F80001" x="141" y="286" x2="160" y2="201" eletype="AF" valuetype="HR" radius="122" stroke="16" nr_values="1"/>
        <LayoutElement type="1" color="FF000A" x="141" y="286" x2="160" y2="201" eletype="AF" valuetype="AH" radius="106" stroke="8" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="141" y="286" x2="160" y2="201" eletype="AC" valuetype="FX" radius="102" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="FF000A" valDC00="2000" colDC00="F80000" valDC01="1680" colDC01="F80000" valDC02="1500" colDC02="FF8080" valDC03="1350" colDC03="00C000" valDC04="1200" colDC04="38A8F8" valDC05="700" colDC05="C0C0C0" valDC06="600" colDC06="C0C0C0" invertcolor="false"/>
        <LayoutElement type="2" replDC="F80001" valDC00="2000" colDC00="F80000" valDC01="600" colDC01="F80000" invertcolor="false"/>
        <LayoutElement type="0" color="FFFFFF" x="78" y="263" fixedtext="false" eletype="HR" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="37" y="334" fixedtext="false" eletype="HZ" text="$V" font="TINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="3" text="***   HR TIME ZONES   ***"/>
        <LayoutElement type="1" color="C0C0C0" x="55" y="350" x2="65" y2="354" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="38A8F8" x="66" y="350" x2="76" y2="354" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="00C000" x="77" y="350" x2="87" y2="354" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF8080" x="88" y="350" x2="98" y2="354" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="99" y="350" x2="109" y2="354" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="55" y="350" x2="109" y2="350" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="C0C0C1" x="55" y="320" x2="65" y2="351" eletype="RV" valuetype="P1" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C0C1" valDC00="1000" colDC00="C0C0C0" valDC01="1" colDC01="C0C0C0" invertcolor="false"/>
        <LayoutElement type="1" color="38A8F9" x="66" y="320" x2="76" y2="351" eletype="RV" valuetype="P2" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="38A8F9" valDC00="1000" colDC00="38A8F8" valDC01="1" colDC01="38A8F8" invertcolor="false"/>
        <LayoutElement type="1" color="00C001" x="77" y="320" x2="87" y2="351" eletype="RV" valuetype="P3" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="00C001" valDC00="1000" colDC00="00C000" valDC01="1" colDC01="00C000" invertcolor="false"/>
        <LayoutElement type="1" color="FF8081" x="88" y="320" x2="98" y2="351" eletype="RV" valuetype="P4" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="FF8081" valDC00="1000" colDC00="FF8080" valDC01="1" colDC01="FF8080" invertcolor="false"/>
        <LayoutElement type="1" color="FF0001" x="99" y="320" x2="109" y2="351" eletype="RV" valuetype="P5" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="FF0001" valDC00="1000" colDC00="FF0000" valDC01="1" colDC01="FF0000" invertcolor="false"/>
        <LayoutElement type="3" text="***   AVERAGE HR  ***"/>
        <LayoutElement type="0" color="000000" x="77" y="302" fixedtext="false" eletype="AH" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="80" y="302" fixedtext="false" eletype="AH" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="78" y="301" fixedtext="false" eletype="AH" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="79" y="301" fixedtext="false" eletype="AH" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="3" text="***   POWER  52;80;105;140;170;195;300   ***"/>
        <LayoutElement type="1" color="D0D0D0" x="141" y="286" x2="382" y2="338" eletype="AC" valuetype="FX" radius="122" stroke="20" nr_values="1"/>
        <LayoutElement type="1" color="F80002" x="141" y="286" x2="381" y2="339" eletype="AF" valuetype="CB" radius="122" stroke="16" nr_values="1"/>
        <LayoutElement type="1" color="007FFA" x="141" y="286" x2="381" y2="339" eletype="AF" valuetype="AB" radius="106" stroke="8" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="141" y="286" x2="381" y2="339" eletype="AC" valuetype="FX" radius="102" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="007FFA" valDC00="3000" colDC00="F80000" valDC01="1700" colDC01="F80000" valDC02="1400" colDC02="FF8080" valDC03="1050" colDC03="00A800" valDC04="800" colDC04="0F82F8" valDC05="520" colDC05="C0C0C0" valDC06="1" colDC06="C0C0C0" invertcolor="false"/>
        <LayoutElement type="2" replDC="F80002" valDC00="3000" colDC00="F80000" valDC01="1" colDC01="F80000" invertcolor="false"/>
        <LayoutElement type="0" color="FFFFFF" x="205" y="263" fixedtext="false" eletype="CB" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="3"/>
        <LayoutElement type="0" color="FFFFFF" x="244" y="334" fixedtext="false" eletype="PZ" text="$V" font="TINY" halignment="1" precision="0" nr_values="3"/>
        <LayoutElement type="3" text="***   PWR TIME ZONES   ***"/>
        <LayoutElement type="1" color="C0C0C0" x="173" y="350" x2="183" y2="354" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="38A8F8" x="184" y="350" x2="194" y2="354" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="00C000" x="195" y="350" x2="205" y2="354" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF8080" x="206" y="350" x2="216" y2="354" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="217" y="350" x2="227" y2="354" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="173" y="350" x2="227" y2="350" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="C0C0C2" x="173" y="320" x2="183" y2="351" eletype="RV" valuetype="S1" radius="0" stroke="1" nr_values="3"/>
        <LayoutElement type="2" replDC="C0C0C2" valDC00="1000" colDC00="C0C0C0" valDC01="1" colDC01="C0C0C0" invertcolor="false"/>
        <LayoutElement type="1" color="38A8FA" x="184" y="320" x2="194" y2="351" eletype="RV" valuetype="S2" radius="0" stroke="1" nr_values="3"/>
        <LayoutElement type="2" replDC="38A8FA" valDC00="1000" colDC00="38A8F8" valDC01="1" colDC01="38A8F8" invertcolor="false"/>
        <LayoutElement type="1" color="00C002" x="195" y="320" x2="205" y2="351" eletype="RV" valuetype="S3" radius="0" stroke="1" nr_values="3"/>
        <LayoutElement type="2" replDC="00C002" valDC00="1000" colDC00="00C000" valDC01="1" colDC01="00C000" invertcolor="false"/>
        <LayoutElement type="1" color="FF8082" x="206" y="320" x2="216" y2="351" eletype="RV" valuetype="S4" radius="0" stroke="1" nr_values="3"/>
        <LayoutElement type="2" replDC="FF8082" valDC00="1000" colDC00="FF8080" valDC01="1" colDC01="FF8080" invertcolor="false"/>
        <LayoutElement type="1" color="FF0002" x="217" y="320" x2="227" y2="351" eletype="RV" valuetype="S5" radius="0" stroke="1" nr_values="3"/>
        <LayoutElement type="2" replDC="FF0002" valDC00="1000" colDC00="FF0000" valDC01="1" colDC01="FF0000" invertcolor="false"/>
        <LayoutElement type="3" text="***   AVERAGE POWER   ***"/>
        <LayoutElement type="0" color="000000" x="204" y="302" fixedtext="false" eletype="AB" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="207" y="302" fixedtext="false" eletype="AB" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="205" y="301" fixedtext="false" eletype="AB" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="206" y="301" fixedtext="false" eletype="AB" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="3" text="***   TACX ZEICHEN   ***"/>
        <LayoutElement type="0" color="0F82F8" x="139" y="260" fixedtext="true" eletype="FX" text="Tocx" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="0F82F8" x="140" y="260" fixedtext="true" eletype="FX" text="Tocx" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="0F82F8" x="141" y="260" fixedtext="true" eletype="FX" text="Tocx" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="0F82F8" x="141" y="260" fixedtext="true" eletype="FX" text="." font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="141" y="276" fixedtext="true" eletype="FX" text="NEO" font="TINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="142" y="276" fixedtext="true" eletype="FX" text="NEO" font="TINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="142" y="277" fixedtext="true" eletype="FX" text="NEO" font="TINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="3" text="***   GANG ANGABE + ZEICHEN   ***"/>
        <LayoutElement type="1" color="006FFA" x="141" y="324" x2="-10" y2="-252" eletype="CF" valuetype="AC" radius="20" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="006FFA" x="160" y="306" x2="123" y2="342" eletype="LN" valuetype="AC" radius="12" stroke="8" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="141" y="324" x2="-10" y2="-252" eletype="CF" valuetype="FX" radius="16" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="142" y="311" fixedtext="false" eletype="BG" text="210;32;11;13;15;17;19;21;24;28;32;36" font="MEDIUM" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="2" replDC="006FFA" valDC00="700" colDC00="00C000" valDC01="650" colDC01="00E000" valDC02="600" colDC02="FF8080" valDC03="1" colDC03="FF0000" invertcolor="false"/>
        <LayoutElement type="3" text="***   DATEN IM UNTEREN BEREICH   ***"/>
        <LayoutElement type="0" color="FFFFFF" x="9" y="358" fixedtext="true" eletype="FX" text="Uhrzeit" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="75" y="377" fixedtext="false" eletype="CT" text="$H:$M" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="150" y="358" fixedtext="true" eletype="FX" text="Runde" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="270" y="358" fixedtext="false" eletype="LD" text="$V km" font="XTINY" halignment="0" precision="2" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="151" y="382" fixedtext="false" eletype="LR" text="$V" font="MEDIUM" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="224" y="377" fixedtext="false" eletype="LT" text="$H:$M:$C" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="10" y="416" fixedtext="true" eletype="FX" text="kCal" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="45" y="433" fixedtext="false" eletype="CA" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="100" y="416" fixedtext="true" eletype="FX" text="Gesamt km" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="142" y="434" fixedtext="false" eletype="OM" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="200" y="415" fixedtext="true" eletype="FX" text="Pause" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="240" y="434" fixedtext="false" eletype="PT" text="$m:$S" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
    </DIYLayout>
  • You're right about the versions - this morning Garmin Express said "everything is in sync".
    Now it found again changes - and after the new sync, the configuration parameter for "direction" is there...
    (would it be possible to somehow show the version of the installed dafield in the configuration dialogs?)
    I reopened the designer (it says "v2.7.3 (B)") and my design, re-saved it and copied the string again to my #4 clone.
    The datafield version is still not shown (just an empty place at the postion where it should be).
    And my previously working hidden values are now still shown (in red, because the underlying dynamic color for the "Hidden"-Color is "FF0000").
    This is the dynamic color definition:
    <LayoutElement type="2" replDC="FF00FD" valDC00="1" colDC00="000000" hideDC00="false" blinkDC00="false" valDC01="0" colDC01="FF0000" hideDC01="true" blinkDC01="false" invertcolor="false"/>
    And these are some of my elements which use the above dynamic color:
    <LayoutElement type="0" color="FF00FD" x="276" y="28" fixedtext="false" eletype="C1" text="Bat. $V%" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="55"/>
    <LayoutElement type="0" color="FF00FD" x="276" y="266" fixedtext="false" eletype="TE" text="Training $V" font="TINY" halignment="0" precision="0" nr_values="1" sampletext="2"/>
    <LayoutElement type="0" color="FF00FD" x="6" y="450" fixedtext="false" eletype="EV" text="Ankunft $H:$M" font="TINY" halignment="2" precision="0" nr_values="1" sampletext="65360"/>
    The first is the battery value of my ANT Speed sensor - if it's 0 it should hide (because that means, it's not connected)
    The second is Training effect which should also not been shown if the value is 0
    And the third is one of my navigation values which should not been shown if no navigation is started - and therefore that value is also 0...
  • I added all available ANT+ device types. Have you tried Fitnessequipment ANT fields?
    I will try that - maybe it's that...
  • Yes it works fine!
    Open mouthOpen mouth
    Why doesn't it work here?
    I already did exactly what you're saying - but it does never switch to the "dark" layout - it always uses the "day" layout, even when I explicitely set the color mode "night" and reboot the device.
  • Actually I wanted to post my day and my night xml here - but the forums software currently says
    Sorry, you have been blocked
    You are unable to access forums.garmin.com
    when I try to copy the XML in the "Insert code" popup window Rage
  • I just tested the nightmode - and - yes - you are right!
    Does not work anymore!
    (Have not tested it for a while...)
  • Hi
    Hmm, just tried it in the simulator and it works fine there. Could you post your white and black config strings?
    Did you restart the datafield?
  • First I send a Layout I use for testing new features, and Bodenseematze is right:
    -The hidden function does not work anymore (has worked before blinking- sorry for that...)
    -The Version and Appname data does not show - keep blank.
    The red crossed circles in my test-layout get blue if a connection was established and should dissappear when data is transmitted. It worked before.
    <DIYLayout>
        <LayoutElement type="3" text="***   WATT   52;80;105;140;170;195;300   ***"/>
        <LayoutElement type="1" color="FFFFFF" x="0" y="0" x2="282" y2="188" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="256" y="144" x2="0" y2="0" eletype="DA" valuetype="SN" radius="12" stroke="3" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="159" y="147" x2="0" y2="21" eletype="DT" valuetype="SN" radius="6" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="159" y="147" x2="0" y2="21" eletype="DT" valuetype="SN" radius="4" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="159" y="147" x2="0" y2="0" eletype="CR" valuetype="FX" radius="28" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="224" y="147" x2="0" y2="0" eletype="DT" valuetype="SN" radius="14" stroke="2" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="16" y="124" fixedtext="false" eletype="DV" text="2.x.x" font="TINY" halignment="2" precision="0" nr_values="1" sampletext="2.x.x"/>
        <LayoutElement type="0" color="000000" x="16" y="146" fixedtext="false" eletype="CN" text="HMs DIY #1" font="TINY" halignment="2" precision="0" nr_values="1" sampletext="HMs DIY #1"/>
        <LayoutElement type="3" text="----------------- Seperator ------------------"/>
        <LayoutElement type="1" color="000000" x="0" y="22" x2="282" y2="22" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="51" x2="282" y2="51" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="80" x2="282" y2="80" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="110" x2="282" y2="110" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="70" y="0" x2="70" y2="110" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="118" y="0" x2="118" y2="110" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="190" y="0" x2="190" y2="110" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="33" y="3" fixedtext="true" eletype="FX" text="Sensor" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="95" y="3" fixedtext="true" eletype="FX" text="Status" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="155" y="3" fixedtext="true" eletype="FX" text="Value1" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="227" y="3" fixedtext="true" eletype="FX" text="Value2" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="34" y="27" fixedtext="true" eletype="FX" text="Speed" font="TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="92" y="27" fixedtext="false" eletype="C0" text="$V" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="1"/>
        <LayoutElement type="0" color="000000" x="154" y="27" fixedtext="false" eletype="C3" text="$V km" font="TINY" halignment="1" precision="1" nr_values="1" sampletext="25.3"/>
        <LayoutElement type="0" color="000000" x="237" y="27" fixedtext="false" eletype="C2" text="$V km/h" font="TINY" halignment="1" precision="1" nr_values="1" sampletext="22.7"/>
        <LayoutElement type="0" color="000000" x="34" y="56" fixedtext="true" eletype="FX" text="Power" font="TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="92" y="56" fixedtext="false" eletype="E0" text="$V" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="1"/>
        <LayoutElement type="0" color="000000" x="92" y="87" fixedtext="false" eletype="E1" text="$V" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="4"/>
        <LayoutElement type="0" color="000000" x="154" y="56" fixedtext="false" eletype="E3" text="$V W" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="217"/>
        <LayoutElement type="0" color="000000" x="237" y="56" fixedtext="false" eletype="E2" text="$V rpm" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="117"/>
        <LayoutElement type="0" color="000000" x="154" y="87" fixedtext="false" eletype="E5" text="$V ws" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="14.5"/>
        <LayoutElement type="0" color="000000" x="237" y="87" fixedtext="false" eletype="E4" text="$V wd" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="217"/>
        <LayoutElement type="0" color="000000" x="34" y="86" fixedtext="true" eletype="FX" text="" font="TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="3" text="***   GEFAHR !!   ***"/>
        <LayoutElement type="1" color="FF1234" x="118" y="37" x2="125" y2="49" eletype="CR" valuetype="C0" radius="10" stroke="3" nr_values="1"/>
        <LayoutElement type="1" color="FF1234" x="112" y="31" x2="125" y2="44" eletype="LN" valuetype="C0" radius="0" stroke="3" nr_values="1"/>
        <LayoutElement type="1" color="FF1234" x="125" y="30" x2="111" y2="44" eletype="LN" valuetype="C0" radius="0" stroke="3" nr_values="1"/>
        <LayoutElement type="1" color="FF1234" x="118" y="65" x2="125" y2="77" eletype="CR" valuetype="E0" radius="10" stroke="3" nr_values="1"/>
        <LayoutElement type="1" color="FF1234" x="112" y="59" x2="125" y2="72" eletype="LN" valuetype="E0" radius="0" stroke="3" nr_values="1"/>
        <LayoutElement type="1" color="FF1234" x="125" y="58" x2="111" y2="72" eletype="LN" valuetype="E0" radius="0" stroke="3" nr_values="1"/>
        <LayoutElement type="2" replDC="FF1234" valDC00="25" colDC00="0F82F8" hideDC00="true" blinkDC00="false" valDC01="10" colDC01="0F82F8" hideDC01="false" blinkDC01="false" valDC02="0" colDC02="FF0000" hideDC02="false" blinkDC02="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="0" y="0" fixedtext="false" eletype="NB" text="$V" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="425.34"/>
    </DIYLayout>
  • And here are ma Tacx-Layouts - Day and Night:
    DAY:
    <DIYLayout>
        <LayoutElement type="1" color="FFFFFF" x="0" y="0" x2="282" y2="470" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="141" y="3" fixedtext="true" eletype="FX" text="� HM-DIY" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="1" color="000000" x="141" y="577" x2="0" y2="0" eletype="CR" valuetype="FX" radius="500" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="166" x2="282" y2="166" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="224" x2="282" y2="224" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="354" x2="282" y2="354" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="412" x2="282" y2="412" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="141" y="166" x2="141" y2="223" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="141" y="355" x2="141" y2="412" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="92" y="412" x2="92" y2="470" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="190" y="412" x2="190" y2="470" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="14" y="19" x2="46" y2="33" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="46" y="22" x2="50" y2="30" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="16" y="21" x2="44" y2="31" eletype="RF" valuetype="BV" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="38" y="37" fixedtext="false" eletype="BV" text="$V" font="SMALL" halignment="0" precision="0" nr_values="1" sampletext="87"/>
        <LayoutElement type="0" color="000000" x="38" y="37" fixedtext="true" eletype="FX" text="%" font="SMALL" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="2" replDC="00B001" valDC00="1000" colDC00="00C000" hideDC00="false" valDC01="200" colDC01="00C000" hideDC01="false" valDC02="110" colDC02="F8C840" hideDC02="false" valDC03="1" colDC03="FF0000" hideDC03="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="272" y="19" fixedtext="false" eletype="TM" text="$V �C" font="SMALL" halignment="0" precision="1" nr_values="1" sampletext="18.4"/>
        <LayoutElement type="0" color="000000" x="139" y="36" fixedtext="false" eletype="CC" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1" sampletext="167.34"/>
        <LayoutElement type="0" color="000000" x="167" y="45" fixedtext="true" eletype="FX" text="rpm" font="SMALL" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="88" y="101" fixedtext="true" eletype="FX" text="Speed" font="SMALL" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="144" y="89" fixedtext="false" eletype="CS" text="$V" font="NR_MEDIUM" halignment="1" precision="1" nr_values="1" sampletext="45.34"/>
        <LayoutElement type="0" color="000000" x="191" y="101" fixedtext="true" eletype="FX" text="km/h" font="SMALL" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="29" y="136" fixedtext="false" eletype="AS" text="$V" font="MEDIUM" halignment="1" precision="1" nr_values="1" sampletext="34.76"/>
        <LayoutElement type="0" color="000000" x="30" y="136" fixedtext="false" eletype="AS" text="$V" font="MEDIUM" halignment="1" precision="1" nr_values="1" sampletext="34.76"/>
        <LayoutElement type="0" color="000000" x="56" y="141" fixedtext="true" eletype="FX" text="km/h" font="TINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="143" y="140" fixedtext="true" eletype="FX" text="avg." font="TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="237" y="136" fixedtext="false" eletype="AC" text="$V" font="MEDIUM" halignment="0" precision="0" nr_values="1" sampletext="188.45"/>
        <LayoutElement type="0" color="000000" x="236" y="136" fixedtext="false" eletype="AC" text="$V" font="MEDIUM" halignment="0" precision="0" nr_values="1" sampletext="188.45"/>
        <LayoutElement type="0" color="000000" x="274" y="141" fixedtext="true" eletype="FX" text="rpm" font="TINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="10" y="170" fixedtext="true" eletype="FX" text="Timer" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="85" y="188" fixedtext="false" eletype="TT" text="$H:$M:$C" font="NR_MILD" halignment="1" precision="0" nr_values="1" sampletext="4374"/>
        <LayoutElement type="0" color="000000" x="150" y="170" fixedtext="true" eletype="FX" text="Strecke" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="238" y="188" fixedtext="false" eletype="DS" text="$V" font="NR_MILD" halignment="0" precision="1" nr_values="1" sampletext="12.56"/>
        <LayoutElement type="0" color="000000" x="259" y="197" fixedtext="true" eletype="FX" text="km" font="SMALL" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="1" color="000000" x="99" y="224" x2="183" y2="255" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="141" y="229" fixedtext="false" eletype="TE" text="TE  $V" font="SMALL" halignment="1" precision="1" nr_values="1" sampletext="4.2"/>
        <LayoutElement type="1" color="000000" x="141" y="286" x2="160" y2="201" eletype="AC" valuetype="FX" radius="102" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="FF000A" valDC00="2000" colDC00="F80000" hideDC00="false" valDC01="1680" colDC01="F80000" hideDC01="false" valDC02="1500" colDC02="FF8080" hideDC02="false" valDC03="1350" colDC03="00C000" hideDC03="false" valDC04="1200" colDC04="38A8F8" hideDC04="false" valDC05="700" colDC05="C0C0C0" hideDC05="false" valDC06="600" colDC06="C0C0C0" hideDC06="false" invertcolor="false"/>
        <LayoutElement type="2" replDC="F80001" valDC00="2000" colDC00="F80000" hideDC00="false" valDC01="600" colDC01="F80000" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="78" y="263" fixedtext="false" eletype="HR" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1" sampletext="183.55"/>
        <LayoutElement type="0" color="000000" x="37" y="334" fixedtext="false" eletype="HZ" text="$V" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="4"/>
        <LayoutElement type="1" color="000000" x="55" y="350" x2="109" y2="350" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C0C1" valDC00="1000" colDC00="C0C0C0" hideDC00="false" valDC01="1" colDC01="C0C0C0" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="2" replDC="38A8F9" valDC00="1000" colDC00="38A8F8" hideDC00="false" valDC01="1" colDC01="38A8F8" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="2" replDC="00C001" valDC00="1000" colDC00="00C000" hideDC00="false" valDC01="1" colDC01="00C000" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="2" replDC="FF8081" valDC00="1000" colDC00="FF8080" hideDC00="false" valDC01="1" colDC01="FF8080" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="2" replDC="FF0001" valDC00="1000" colDC00="FF0000" hideDC00="false" valDC01="1" colDC01="FF0000" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="FFFFFF" x="77" y="302" fixedtext="false" eletype="AH" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="154.49"/>
        <LayoutElement type="0" color="FFFFFF" x="80" y="302" fixedtext="false" eletype="AH" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="154.49"/>
        <LayoutElement type="0" color="000000" x="78" y="301" fixedtext="false" eletype="AH" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="154.49"/>
        <LayoutElement type="0" color="000000" x="79" y="301" fixedtext="false" eletype="AH" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="154.49"/>
        <LayoutElement type="1" color="000000" x="141" y="286" x2="381" y2="339" eletype="AC" valuetype="FX" radius="102" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="007FFA" valDC00="3000" colDC00="F80000" hideDC00="false" valDC01="1700" colDC01="F80000" hideDC01="false" valDC02="1400" colDC02="FF8080" hideDC02="false" valDC03="1050" colDC03="00A800" hideDC03="false" valDC04="800" colDC04="0F82F8" hideDC04="false" valDC05="520" colDC05="C0C0C0" hideDC05="false" valDC06="1" colDC06="C0C0C0" hideDC06="false" invertcolor="false"/>
        <LayoutElement type="2" replDC="F80002" valDC00="3000" colDC00="F80000" hideDC00="false" valDC01="1" colDC01="F80000" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="205" y="263" fixedtext="false" eletype="CB" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="3" sampletext="455.34"/>
        <LayoutElement type="0" color="000000" x="244" y="334" fixedtext="false" eletype="PZ" text="$V" font="TINY" halignment="1" precision="0" nr_values="3" sampletext="4"/>
        <LayoutElement type="1" color="000000" x="173" y="350" x2="227" y2="350" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C0C2" valDC00="1000" colDC00="C0C0C0" hideDC00="false" valDC01="1" colDC01="C0C0C0" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="2" replDC="38A8FA" valDC00="1000" colDC00="38A8F8" hideDC00="false" valDC01="1" colDC01="38A8F8" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="2" replDC="00C002" valDC00="1000" colDC00="00C000" hideDC00="false" valDC01="1" colDC01="00C000" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="2" replDC="FF8082" valDC00="1000" colDC00="FF8080" hideDC00="false" valDC01="1" colDC01="FF8080" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="2" replDC="FF0002" valDC00="1000" colDC00="FF0000" hideDC00="false" valDC01="1" colDC01="FF0000" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="FFFFFF" x="204" y="302" fixedtext="false" eletype="AB" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="347.23"/>
        <LayoutElement type="0" color="FFFFFF" x="207" y="302" fixedtext="false" eletype="AB" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="347.23"/>
        <LayoutElement type="0" color="000000" x="205" y="301" fixedtext="false" eletype="AB" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="347.23"/>
        <LayoutElement type="0" color="000000" x="206" y="301" fixedtext="false" eletype="AB" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="347.23"/>
        <LayoutElement type="0" color="0F82F8" x="139" y="260" fixedtext="true" eletype="FX" text="Tocx" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="0F82F8" x="140" y="260" fixedtext="true" eletype="FX" text="Tocx" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="0F82F8" x="141" y="260" fixedtext="true" eletype="FX" text="Tocx" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="0F82F8" x="141" y="260" fixedtext="true" eletype="FX" text="." font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="141" y="276" fixedtext="true" eletype="FX" text="NEO" font="TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="142" y="276" fixedtext="true" eletype="FX" text="NEO" font="TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="142" y="277" fixedtext="true" eletype="FX" text="NEO" font="TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="1" color="F8F8F8" x="141" y="324" x2="-10" y2="-252" eletype="CF" valuetype="FX" radius="16" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="142" y="311" fixedtext="false" eletype="BG" text="210;32;11;13;15;17;19;21;24;28;32;36" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="5"/>
        <LayoutElement type="2" replDC="006FFA" valDC00="700" colDC00="00C000" hideDC00="false" valDC01="650" colDC01="00E000" hideDC01="false" valDC02="600" colDC02="FF8080" hideDC02="false" valDC03="1" colDC03="FF0000" hideDC03="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="9" y="358" fixedtext="true" eletype="FX" text="Uhrzeit" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="75" y="377" fixedtext="false" eletype="CT" text="$H:$M" font="NR_MILD" halignment="1" precision="0" nr_values="1" sampletext="63312"/>
        <LayoutElement type="0" color="000000" x="150" y="358" fixedtext="true" eletype="FX" text="Runde" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="270" y="358" fixedtext="false" eletype="LD" text="$V km" font="XTINY" halignment="0" precision="2" nr_values="1" sampletext="2.23"/>
        <LayoutElement type="0" color="000000" x="151" y="382" fixedtext="false" eletype="LR" text="$V" font="MEDIUM" halignment="2" precision="0" nr_values="1" sampletext="17"/>
        <LayoutElement type="0" color="000000" x="224" y="377" fixedtext="false" eletype="LT" text="$H:$M:$C" font="NR_MILD" halignment="1" precision="0" nr_values="1" sampletext="1326"/>
        <LayoutElement type="0" color="000000" x="10" y="416" fixedtext="true" eletype="FX" text="kCal" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="45" y="433" fixedtext="false" eletype="CA" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1" sampletext="1563.77"/>
        <LayoutElement type="0" color="000000" x="100" y="416" fixedtext="true" eletype="FX" text="Gesamt km" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="142" y="434" fixedtext="false" eletype="OM" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1" sampletext="1121.21"/>
        <LayoutElement type="0" color="000000" x="200" y="415" fixedtext="true" eletype="FX" text="Pause" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="240" y="434" fixedtext="false" eletype="PT" text="$m:$S" font="NR_MILD" halignment="1" precision="0" nr_values="1" sampletext="374"/>
    </DIYLayout>
    NIGHT:
    <DIYLayout>
    </DIYLayout>
