HMs DIY #1-6
Store Link
Because I want to keep this datafield and the app free for use I would be very grateful about a small donation to PayPal
A detailed description of how to use it can be found here:
HMs_DIY_GUIDANCE.pdf
HMs_DIY_ANLEITUNG.pdf
Thanks very much to mcinner1 for putting so much time into this documentation!
Designer download
You can contribute on my github page.
You can upload your layout so others can use it as well.
Also any changes to the fonts.txt can be updated there as well.
Garmin_HMsDIY
RELEASE NOTES
3.9.1
* switched to new SDK 9.3.0
* added devices: Approach S72 43mm, Approach S72 47mm, D2 Mach 2 Pro, Edge 1060, Edge Explore 3, Edge Explore 3 Plus, Enduro 4, fenix 9 43mm, fenix 9 47mm, fenix 9 Pro 43mm, fenix 9 Pro 47mm, fenix 9 Pro 51mm,
fenix 9 Pro Solar 47mm, fenix 9 Pro Solar 51mm, Forerunner 70, Forerunner 170, Forerunner 170 Music, MARQ (Gen 3)
3.8.3
* fixed problem with backslash in configuration string
3.8.1
* switched to new SDK 8.3.0
* added devices: Approach S50, D2 Mach 2, Descent G2, Edge 550, Edge 850, Edge MTB, eTrex Touch, fēnix 8 Pro 47mm / 51mm / MicroLED, Forerunner 970, Forerunner 570 42mm, Forerunner 570 47mm,
GPSMAP H1, Instinct 3 AMOLED 45mm, Instinct 3 AMOLED 50mm, Instinct 3 Solar 45mm / 50mm, Instinct Crossover AMOLED, Instinct E 40mm, Instinct E 45mm, Venu 4 41mm, Venu 4 45mm / D2 Air X15, Venu X1, vívoactive 6
for full releasenotes see: releasenotes.txt
  • Okay, I wasn't expecting this speed! This is crazy. Thanks a lot.
  • Yes - works - but does not update the editor-fields!
    But thanks a lot anyway!
  • Hi, Finally I have to be able to edit a file. I have add a field of %FTP close to Current Power but it always show "0". In another sceen it is running ok. Could you check it?
    <?xml version="1.0" encoding="UTF-8"?>
    <DIYLayout>
        <Device name="Edge 1030"/>
        <LayoutElement type="1" color="FFFFFF" x="0" y="0" x2="282" y2="470" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0006" x="141" y="290" x2="10" y2="239" eletype="LN" valuetype="AH" radius="0" stroke="18" nr_values="1"/>
        <LayoutElement type="1" color="FF0005" x="141" y="290" x2="10" y2="258" eletype="LN" valuetype="AH" radius="0" stroke="17" nr_values="1"/>
        <LayoutElement type="1" color="FF0004" x="141" y="290" x2="10" y2="275" eletype="LN" valuetype="AH" radius="0" stroke="20" nr_values="1"/>
        <LayoutElement type="1" color="FF0003" x="141" y="290" x2="10" y2="294" eletype="LN" valuetype="AH" radius="0" stroke="17" nr_values="1"/>
        <LayoutElement type="1" color="FF0002" x="141" y="290" x2="10" y2="311" eletype="LN" valuetype="AH" radius="0" stroke="17" nr_values="1"/>
        <LayoutElement type="1" color="FF0001" x="141" y="290" x2="10" y2="326" eletype="LN" valuetype="AH" radius="0" stroke="17" nr_values="1"/>
        <LayoutElement type="1" color="FF0006" x="141" y="290" x2="272" y2="239" eletype="LN" valuetype="AB" radius="0" stroke="18" nr_values="1"/>
        <LayoutElement type="1" color="FF0005" x="141" y="290" x2="272" y2="258" eletype="LN" valuetype="AB" radius="0" stroke="17" nr_values="1"/>
        <LayoutElement type="1" color="FF0004" x="141" y="290" x2="272" y2="275" eletype="LN" valuetype="AB" radius="0" stroke="20" nr_values="1"/>
        <LayoutElement type="1" color="FF0003" x="141" y="290" x2="272" y2="294" eletype="LN" valuetype="AB" radius="0" stroke="17" nr_values="1"/>
        <LayoutElement type="1" color="FF0002" x="141" y="290" x2="272" y2="311" eletype="LN" valuetype="AB" radius="0" stroke="17" nr_values="1"/>
        <LayoutElement type="1" color="FF0001" x="141" y="290" x2="272" y2="326" eletype="LN" valuetype="AB" radius="0" stroke="17" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="141" y="283" x2="0" y2="0" eletype="CF" valuetype="FX" radius="112" stroke="18" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="141" y="283" x2="0" y2="0" eletype="CR" valuetype="FX" radius="138" stroke="18" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="141" y="283" x2="0" y2="0" eletype="CR" valuetype="FX" radius="106" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="141" y="283" x2="10" y2="220" eletype="LN" valuetype="FX" radius="0" stroke="13" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="141" y="283" x2="10" y2="344" eletype="LN" valuetype="FX" radius="0" stroke="13" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="141" y="283" x2="272" y2="220" eletype="LN" valuetype="FX" radius="0" stroke="13" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="141" y="283" x2="272" y2="344" eletype="LN" valuetype="FX" radius="0" stroke="13" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="0" y="0" x2="282" y2="232" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="0" y="334" x2="282" y2="470" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="155" x2="282" y2="155" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="212" x2="282" y2="212" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="354" x2="282" y2="354" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="410" x2="282" y2="410" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="141" y="155" x2="141" y2="410" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="94" y="410" x2="94" y2="470" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="188" y="410" x2="188" y2="470" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="28" y="11" fixedtext="true" eletype="FX" text="Bateria" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="36" y="29" fixedtext="false" eletype="BV" text="$V" font="SMALL" halignment="0" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="35" y="29" fixedtext="true" eletype="FX" text="%" font="SMALL" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="139" y="15" fixedtext="false" eletype="CC" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="169" y="22" fixedtext="true" eletype="FX" text="rpm" font="SMALL" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="141" y="560" x2="0" y2="0" eletype="CR" valuetype="FX" radius="500" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="88" y="86" fixedtext="true" eletype="FX" text="Velocidad" font="TINY" halignment="0" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="144" y="71" fixedtext="false" eletype="CS" text="$V" font="NR_HOT" halignment="1" precision="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="191" y="83" fixedtext="true" eletype="FX" text="km/h" font="MEDIUM" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="110" y="129" fixedtext="true" eletype="FX" text="vel media" font="XTINY" halignment="0" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="144" y="123" fixedtext="false" eletype="AS" text="$V" font="SMALL" halignment="1" precision="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="175" y="129" fixedtext="true" eletype="FX" text="km/h" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="10" y="158" fixedtext="true" eletype="FX" text="Tiempo" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="55" y="158" fixedtext="false" eletype="PT" text="$H:$M:$S" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="77" y="175" fixedtext="false" eletype="TT" text="$H:$M:$S" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="150" y="158" fixedtext="true" eletype="FX" text="Distancia" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="238" y="175" fixedtext="false" eletype="DS" text="$V" font="NR_MILD" halignment="0" precision="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="258" y="184" fixedtext="true" eletype="FX" text="km" font="SMALL" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="148" y="215" fixedtext="false" eletype="TE" text="$V" font="SMALL" halignment="2" precision="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="88" y="227" fixedtext="true" eletype="FX" text="bpm" font="TINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="109" y="262" fixedtext="false" eletype="HR" text="$V" font="LARGE" halignment="0" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="112" y="273" fixedtext="true" eletype="FX" text="/" font="MEDIUM" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="125" y="274" fixedtext="false" eletype="HZ" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="90" y="312" fixedtext="false" eletype="AH" text="$V" font="SMALL" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="90" y="335" fixedtext="true" eletype="FX" text="avg. HR" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="203" y="227" fixedtext="true" eletype="FX" text="Watt" font="TINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="203" y="262" fixedtext="false" eletype="CB" text="$V" font="LARGE" halignment="1" precision="0" nr_values="3"/>
        <LayoutElement type="0" color="000000" x="203" y="308" fixedtext="false" eletype="AB" text="$V" font="SMALL" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="203" y="335" fixedtext="true" eletype="FX" text="avg. Watt" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="10" y="358" fixedtext="true" eletype="FX" text="hora" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="86" y="369" fixedtext="false" eletype="CT" text="$H:$M" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="150" y="358" fixedtext="true" eletype="FX" text="relacion cambio" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="221" y="375" fixedtext="false" eletype="BG" text="220;30;10;12;14;16;18;21;24;28;32;36;42;50" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="10" y="415" fixedtext="true" eletype="FX" text="kCal" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="50" y="433" fixedtext="false" eletype="CA" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="105" y="415" fixedtext="true" eletype="FX" text="desnivel +" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="141" y="433" fixedtext="false" eletype="TA" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="198" y="415" fixedtext="true" eletype="FX" text="desnivel" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="249" y="433" fixedtext="false" eletype="GR" text="$V" font="NR_MILD" halignment="0" precision="0" nr_values="16"/>
        <LayoutElement type="0" color="000000" x="265" y="439" fixedtext="true" eletype="FX" text="%" font="MEDIUM" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="2" replDC="FF0006" valDC00="1700" colDC00="AA0000" valDC01="600" colDC01="C0C0C0" invertcolor="false"/>
        <LayoutElement type="2" replDC="FF0005" valDC00="1700" colDC00="AA0000" valDC01="1550" colDC01="F80000" valDC02="600" colDC02="C0C0C0" invertcolor="false"/>
        <LayoutElement type="2" replDC="FF0004" valDC00="1700" colDC00="AA0000" valDC01="1550" colDC01="F80000" valDC02="1350" colDC02="00A800" valDC03="600" colDC03="C0C0C0" invertcolor="false"/>
        <LayoutElement type="2" replDC="FF0003" valDC00="1700" colDC00="AA0000" valDC01="1550" colDC01="F80000" valDC02="1350" colDC02="00A800" valDC03="1200" colDC03="0F82F8" valDC04="600" colDC04="C0C0C0" invertcolor="false"/>
        <LayoutElement type="2" replDC="FF0002" valDC00="1700" colDC00="AA0000" valDC01="1550" colDC01="F80000" valDC02="1350" colDC02="00A800" valDC03="1200" colDC03="0F82F8" valDC04="1000" colDC04="F8C840" valDC05="600" colDC05="C0C0C0" invertcolor="false"/>
        <LayoutElement type="2" replDC="FF0001" valDC00="1700" colDC00="AA0000" valDC01="1550" colDC01="F80000" valDC02="1350" colDC02="00A800" valDC03="1200" colDC03="0F82F8" valDC04="1000" colDC04="F8C840" valDC05="650" colDC05="828282" valDC06="600" colDC06="C0C0C0" invertcolor="false"/>
        <LayoutElement type="2" replDC="FF000E" valDC00="40" colDC00="00A800" valDC01="30" colDC01="00FC00" valDC02="20" colDC02="F8C840" valDC03="10" colDC03="F80000" valDC04="1" colDC04="FFFFFF" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="256" y="11" fixedtext="true" eletype="FX" text="Temp" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="0000FF" x="275" y="30" fixedtext="false" eletype="TM" text="$V" font="SMALL" halignment="0" precision="1" nr_values="2"/>
        <LayoutElement type="0" color="000000" x="169" y="18" fixedtext="true" eletype="FX" text="rpm" font="SMALL" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="144" y="64" fixedtext="false" eletype="CS" text="$V" font="NR_HOT" halignment="1" precision="1" nr_values="1"/>
        <LayoutElement type="0" color="008000" x="144" y="123" fixedtext="false" eletype="AD" text="$V" font="SMALL" halignment="1" precision="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="10" y="158" fixedtext="true" eletype="FX" text="Tiempo en movimiento" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="25" y="175" fixedtext="false" eletype="PT" text="$H:$M:$S" font="NR_MILD" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="77" y="175" fixedtext="true" eletype="FX" text="" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="150" y="158" fixedtext="true" eletype="FX" text="          Distancia" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="258" y="179" fixedtext="true" eletype="FX" text="km" font="SMALL" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="109" y="260" fixedtext="false" eletype="HR" text="$V" font="LARGE" halignment="0" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="222" y="273" fixedtext="true" eletype="FX" text="/" font="MEDIUM" halignment="0" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="90" y="308" fixedtext="false" eletype="AH" text="$V" font="SMALL" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="175" y="260" fixedtext="false" eletype="CB" text="$V" font="LARGE" halignment="1" precision="0" nr_values="3"/>
        <LayoutElement type="0" color="000000" x="246" y="273" fixedtext="false" eletype="FT" text="$V" font="SMALL" halignment="0" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="10" y="358" fixedtext="true" eletype="FX" text="Reloj" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="221" y="375" fixedtext="false" eletype="BG" text="11;13;15;17;19;21;23;25;28;30;34;36;52" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="10" y="415" fixedtext="true" eletype="FX" text="ALTITUD" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="50" y="433" fixedtext="false" eletype="CL" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="198" y="415" fixedtext="true" eletype="FX" text="PENDIENTE" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="249" y="433" fixedtext="false" eletype="GR" text="$V" font="NR_MILD" halignment="0" precision="1" nr_values="16"/>
    </DIYLayout>
  • Did you set a FTP in the settings?
  • I hve  just notice my mistake.%FTP is a ( H) value and I have not write down anything in the field text. Could you say me how to fill in? I have no idea. Must I write numbers from 0 to 100?
    Ahhh, Thanks for you great job and for you patience
  • It is not a question of (H) or (M) value...
    In the designer tool the text-field contains $V - that's ok. You also can type in: $V %
    What's important is to declare your FTP (Functional Threshold Power) in the DIY-setup routine. Open the IQ-Setup for DIY - the routine where you paste the string from the designer. Scroll to the last line - FTP. Type in your FTP as Watt.
    If you don't know your FTP then look up in your Edge first:
    Turn on your Edge 1030, from the home-scren tap "My Stats", scroll down a little - there you are!
    If there is no FTP stored on your Edge and you don't know what FTP is:
    https://help.trainingpeaks.com/hc/en-us/articles/204071934-How-to-Calculate-Threshold-Power-Heart-Rate-or-Pace
  • What speed did you get? If it is lower than 6kmh than its clear that pace is higher than 10 min/km. Seems to be a calibration issue with the device.
  • Good morning! I‘m not sure if you have seen my yesterday‘s posting regarding coordinate-shortcuts. Thanks for programming, but there is a little issue: the shortcut bring the element into the place as they should, but the text-fields for x and y are not updated - stay 0.0.
  • Hi
    Yeah, did see it, thanks. Is fixed in the next release...
    Regards
    Erich
