HMs DIY #1-6
Store Link
Because I want to keep this datafield and the app free for use I would be very grateful about a small donation to PayPal
A detailed description of how to use it can be found here:
HMs_DIY_GUIDANCE.pdf
HMs_DIY_ANLEITUNG.pdf
Thanks very much to mcinner1 for putting so much time into this documentation!
Designer download
You can contribute on my github page.
You can upload your layout so others can use it as well.
Also any changes to the fonts.txt can be updated there as well.
Garmin_HMsDIY
RELEASE NOTES
3.9.1
* switched to new SDK 9.3.0
* added devices: Approach S72 43mm, Approach S72 47mm, D2 Mach 2 Pro, Edge 1060, Edge Explore 3, Edge Explore 3 Plus, Enduro 4, fenix 9 43mm, fenix 9 47mm, fenix 9 Pro 43mm, fenix 9 Pro 47mm, fenix 9 Pro 51mm,
fenix 9 Pro Solar 47mm, fenix 9 Pro Solar 51mm, Forerunner 70, Forerunner 170, Forerunner 170 Music, MARQ (Gen 3)
3.8.3
* fixed problem with backslash in configuration string
3.8.1
* switched to new SDK 8.3.0
* added devices: Approach S50, D2 Mach 2, Descent G2, Edge 550, Edge 850, Edge MTB, eTrex Touch, fēnix 8 Pro 47mm / 51mm / MicroLED, Forerunner 970, Forerunner 570 42mm, Forerunner 570 47mm,
GPSMAP H1, Instinct 3 AMOLED 45mm, Instinct 3 AMOLED 50mm, Instinct 3 Solar 45mm / 50mm, Instinct Crossover AMOLED, Instinct E 40mm, Instinct E 45mm, Venu 4 41mm, Venu 4 45mm / D2 Air X15, Venu X1, vívoactive 6
for full releasenotes see: releasenotes.txt
  • NEW ELEMENT % in HR Zone
    For years I used an IQ-datafield "Heart Rate Zones Chart" by ronnywinkler. Thanks  now it was possible to build my own datafield using DIY - what I did based on the previously mentioned data field. The picture shows the DIY data field and below the one I used so far.
    If you want to use a progress-bar for the Current HR (like in my layout), the width of the bars must correspond to the individual zones, otherwise the progress-bar does not exactly match the zone boundaries.
    <?xml version="1.0" encoding="UTF-8"?>
    <DIYLayout>
        <Device name="Edge 1030"/>
        <LayoutElement type="1" color="FFFFFF" x="0" y="0" x2="282" y2="94" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="3" text="*** BOTTOM-ELEMENTS   ***"/>
        <LayoutElement type="1" color="000000" x="0" y="86" x2="282" y2="86" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="C0C0C0" x="10" y="87" x2="76" y2="94" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="38C8F8" x="77" y="87" x2="123" y2="94" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="00F500" x="124" y="87" x2="170" y2="94" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF8080" x="171" y="87" x2="225" y2="94" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="226" y="87" x2="272" y2="94" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="3" text="***   HR-ZONE % BARS   ***"/>
        <LayoutElement type="3" text="***   Zone 1 ***"/>
        <LayoutElement type="1" color="C0C0C1" x="10" y="3" x2="76" y2="87" eletype="RV" valuetype="P1" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="45" y="69" fixedtext="false" eletype="P1" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C0C1" valDC00="1000" colDC00="C0C0C0" valDC01="1" colDC01="C0C0C0" invertcolor="false"/>
        <LayoutElement type="3" text="***   Zone 2   ***"/>
        <LayoutElement type="1" color="38C8F9" x="77" y="3" x2="123" y2="87" eletype="RV" valuetype="P2" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="388" y="81" fixedtext="false" eletype="T2" text="$M:$S" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="101" y="69" fixedtext="false" eletype="P2" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="2" replDC="38C8F9" valDC00="1000" colDC00="38C8F8" valDC01="1" colDC01="38C8F8" invertcolor="false"/>
        <LayoutElement type="3" text="***   Zone 3 ***"/>
        <LayoutElement type="1" color="00F501" x="124" y="3" x2="170" y2="87" eletype="RV" valuetype="P3" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="148" y="69" fixedtext="false" eletype="P3" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="2" replDC="00F501" valDC00="1000" colDC00="00F500" valDC01="1" colDC01="00F500" invertcolor="false"/>
        <LayoutElement type="3" text="***   Zone 4   ***"/>
        <LayoutElement type="1" color="FF8081" x="171" y="3" x2="225" y2="87" eletype="RV" valuetype="P4" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="199" y="69" fixedtext="false" eletype="P4" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="2" replDC="FF8081" valDC00="1000" colDC00="FF8080" valDC01="1" colDC01="FF8080" invertcolor="false"/>
        <LayoutElement type="3" text="***   Zone 5   ***"/>
        <LayoutElement type="1" color="FF0001" x="226" y="3" x2="272" y2="87" eletype="RV" valuetype="P5" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="251" y="69" fixedtext="false" eletype="P5" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="2" replDC="FF0001" valDC00="1000" colDC00="FF0000" valDC01="1" colDC01="FF0000" invertcolor="false"/>
        <LayoutElement type="3" text="***   HR CURRENT   ***"/>
        <LayoutElement type="0" color="FFFFFF" x="138" y="10" fixedtext="false" eletype="HR" text="$V" font="NR_MEDIUM" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="142" y="10" fixedtext="false" eletype="HR" text="$V" font="NR_MEDIUM" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="138" y="14" fixedtext="false" eletype="HR" text="$V" font="NR_MEDIUM" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="141" y="14" fixedtext="false" eletype="HR" text="$V" font="NR_MEDIUM" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="140" y="12" fixedtext="false" eletype="HR" text="$V" font="NR_MEDIUM" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="271" y="7" fixedtext="false" eletype="HZ" text="Z $V" font="SMALL" halignment="0" precision="1" nr_values="1"/>
        <LayoutElement type="3" text="***   HR-BAR   ***"/>
        <LayoutElement type="1" color="000001" x="10" y="87" x2="272" y2="94" eletype="RH" valuetype="HR" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="000001" valDC00="1830" colDC00="000011" valDC01="980" colDC01="000011" invertcolor="false"/>
        <LayoutElement type="3" text="***   HEART-PIC   ***"/>
        <LayoutElement type="1" color="FF0000" x="14" y="14" x2="0" y2="0" eletype="CF" valuetype="FX" radius="7" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="26" y="14" x2="0" y2="0" eletype="CF" valuetype="FX" radius="7" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="20" y="20" x2="0" y2="0" eletype="CF" valuetype="FX" radius="7" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="10" y="18" x2="19" y2="28" eletype="LN" valuetype="FX" radius="7" stroke="3" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="29" y="19" x2="19" y2="30" eletype="LN" valuetype="FX" radius="7" stroke="3" nr_values="1"/>
    </DIYLayout>
  • Thank you, I have not seen that field. I have just filled. Today I could see how it works.  This afternoon I am going to try understand your layout about the colors bar ( bpm and watt ) . I don't understand why you use so many colors to the same rate. I had done using only one color for each rate but I am learning with all of you.
  • Colorbars:
    this layout you are using is obsolete. Nowadays there is the element „arcs“ available. The best would be to use another example of the samples-collection.
  • Which one is it, I will remove it from the examples file ?
  •  :  it is "Charts_ProgArcs_mcinner1.xml"
  • Please wait a view minutes - I will release a new layout with English text for the example-collection.
  • Find below the layout, which can be used to replace the obsolete one in the examples-collection:
    <DIYLayout>
        <LayoutElement type="1" color="FFFFFF" x="0" y="0" x2="282" y2="470" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="3" text="***   DATAFIELD LINES   ***"/>
        <LayoutElement type="1" color="000000" x="141" y="575" x2="180" y2="360" eletype="AC" valuetype="FX" radius="500" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="148" x2="282" y2="148" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="205" x2="282" y2="205" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="354" x2="282" y2="354" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="411" x2="282" y2="411" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="141" y="148" x2="141" y2="205" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="141" y="354" x2="141" y2="410" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="94" y="412" x2="94" y2="470" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="188" y="412" x2="188" y2="470" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="3" text="***   BATTERY   ***"/>
        <LayoutElement type="1" color="000000" x="14" y="15" x2="46" y2="29" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="46" y="18" x2="50" y2="26" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="16" y="17" x2="44" y2="27" eletype="RF" valuetype="BV" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="16" y="17" x2="19" y2="27" eletype="RF" valuetype="BV" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="00B001" x="16" y="17" x2="44" y2="27" eletype="RH" valuetype="BV" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="00B001" valDC00="1000" colDC00="00E000" valDC01="200" colDC01="00E000" valDC02="110" colDC02="F8C840" valDC03="1" colDC03="FF0000" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="38" y="33" fixedtext="false" eletype="BV" text="$V" font="SMALL" halignment="0" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="38" y="33" fixedtext="true" eletype="FX" text="%" font="SMALL" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="3" text="***   TEMPERATUR   ***"/>
        <LayoutElement type="0" color="000000" x="141" y="5" fixedtext="false" eletype="TM" text="$V °C" font="SMALL" halignment="1" precision="1" nr_values="1"/>
        <LayoutElement type="3" text="***   GPS   ***"/>
        <LayoutElement type="0" color="000000" x="256" y="11" fixedtext="true" eletype="FX" text="GPS" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="257" y="39" x2="0" y2="0" eletype="CR" valuetype="FX" radius="10" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF000E" x="257" y="39" x2="0" y2="0" eletype="CF" valuetype="GA" radius="9" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="FF000E" valDC00="40" colDC00="00A800" valDC01="30" colDC01="00FC00" valDC02="20" colDC02="F8C840" valDC03="10" colDC03="F80000" valDC04="1" colDC04="FFFFFF" invertcolor="false"/>
        <LayoutElement type="3" text="***   DATA FIELS IN UPPER REGION   ***"/>
        <LayoutElement type="0" color="000000" x="141" y="36" fixedtext="false" eletype="CC" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="173" y="45" fixedtext="true" eletype="FX" text="rpm" font="TINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="88" y="93" fixedtext="true" eletype="FX" text="Speed" font="TINY" halignment="0" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="144" y="83" fixedtext="false" eletype="CS" text="$V" font="NR_MEDIUM" halignment="1" precision="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="191" y="94" fixedtext="true" eletype="FX" text="km/h" font="TINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="53" y="121" fixedtext="false" eletype="AS" text="$V" font="MEDIUM" halignment="0" precision="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="52" y="121" fixedtext="false" eletype="AS" text="$V" font="MEDIUM" halignment="0" precision="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="58" y="124" fixedtext="true" eletype="FX" text="km/h" font="TINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="145" y="124" fixedtext="true" eletype="FX" text="avg." font="TINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="233" y="121" fixedtext="false" eletype="AC" text="$V" font="MEDIUM" halignment="0" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="234" y="121" fixedtext="false" eletype="AC" text="$V" font="MEDIUM" halignment="0" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="272" y="124" fixedtext="true" eletype="FX" text="rpm" font="TINY" halignment="0" precision="0" nr_values="1"/>
        <LayoutElement type="3" text="***   TIMER AND DISTANCE   ***"/>
        <LayoutElement type="0" color="000000" x="10" y="151" fixedtext="true" eletype="FX" text="Timer" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="61" y="151" fixedtext="false" eletype="TV" text="to go  $H:$M:$C" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="77" y="170" fixedtext="false" eletype="TT" text="$H:$M:$C" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="150" y="151" fixedtext="true" eletype="FX" text="Distance" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="211" y="151" fixedtext="false" eletype="DD" text="to go  $V" font="XTINY" halignment="2" precision="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="238" y="170" fixedtext="false" eletype="DS" text="$V" font="NR_MILD" halignment="0" precision="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="258" y="178" fixedtext="true" eletype="FX" text="km" font="SMALL" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="3" text="***   TRAININGS EFFEKT   ***"/>
        <LayoutElement type="1" color="000000" x="94" y="205" x2="188" y2="233" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="130" y="208" fixedtext="true" eletype="FX" text="TE" font="SMALL" halignment="0" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="148" y="208" fixedtext="false" eletype="TE" text="$V" font="SMALL" halignment="2" precision="1" nr_values="1"/>
        <LayoutElement type="3" text="***   HEART PICTURE   ***"/>
        <LayoutElement type="1" color="F80001" x="67" y="218" x2="0" y2="0" eletype="CF" valuetype="FX" radius="7" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="F80001" x="78" y="218" x2="0" y2="0" eletype="CF" valuetype="FX" radius="7" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="F80001" x="73" y="224" x2="0" y2="0" eletype="CF" valuetype="FX" radius="6" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="F80001" x="62" y="221" x2="74" y2="232" eletype="LN" valuetype="FX" radius="6" stroke="3" nr_values="1"/>
        <LayoutElement type="1" color="F80001" x="83" y="221" x2="72" y2="232" eletype="LN" valuetype="FX" radius="6" stroke="3" nr_values="1"/>
        <LayoutElement type="3" text="***   POWER PICTURE   ***"/>
        <LayoutElement type="1" color="0F4FFF" x="209" y="212" x2="220" y2="221" eletype="LN" valuetype="FX" radius="0" stroke="7" nr_values="1"/>
        <LayoutElement type="1" color="0F4FFF" x="200" y="223" x2="211" y2="232" eletype="LN" valuetype="FX" radius="0" stroke="7" nr_values="1"/>
        <LayoutElement type="1" color="0F4FFF" x="212" y="218" x2="207" y2="225" eletype="LN" valuetype="FX" radius="0" stroke="5" nr_values="1"/>
        <LayoutElement type="3" text="***   HEARTRATE   ***"/>
        <LayoutElement type="0" color="000000" x="79" y="238" fixedtext="true" eletype="FX" text="bpm" font="SMALL" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="34" y="216" fixedtext="true" eletype="FX" text="200" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="1" color="D0D0D0" x="141" y="283" x2="157" y2="204" eletype="AC" valuetype="FX" radius="122" stroke="20" nr_values="1"/>
        <LayoutElement type="1" color="F80001" x="141" y="283" x2="158" y2="203" eletype="AF" valuetype="HR" radius="122" stroke="16" nr_values="1"/>
        <LayoutElement type="1" color="FF000A" x="141" y="283" x2="158" y2="203" eletype="AF" valuetype="AH" radius="106" stroke="8" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="141" y="283" x2="158" y2="203" eletype="AC" valuetype="FX" radius="102" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="FF000A" valDC00="2000" colDC00="AA0000" valDC01="1550" colDC01="F80000" valDC02="1350" colDC02="00C000" valDC03="1200" colDC03="38A8F8" valDC04="600" colDC04="C0C0C0" invertcolor="false"/>
        <LayoutElement type="2" replDC="F80001" valDC00="2000" colDC00="F80000" valDC01="600" colDC01="F80000" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="32" y="334" fixedtext="true" eletype="FX" text="60" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="78" y="272" fixedtext="false" eletype="HR" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="78" y="321" fixedtext="false" eletype="AH" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="79" y="321" fixedtext="false" eletype="AH" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="3" text="***   POWER   ***"/>
        <LayoutElement type="0" color="000000" x="205" y="238" fixedtext="true" eletype="FX" text="Watt" font="SMALL" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="248" y="216" fixedtext="true" eletype="FX" text="300" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="1" color="D0D0D0" x="141" y="283" x2="384" y2="336" eletype="AC" valuetype="FX" radius="122" stroke="20" nr_values="1"/>
        <LayoutElement type="1" color="F80002" x="141" y="283" x2="383" y2="337" eletype="AF" valuetype="CB" radius="122" stroke="16" nr_values="1"/>
        <LayoutElement type="1" color="007FFA" x="141" y="283" x2="383" y2="337" eletype="AF" valuetype="AB" radius="106" stroke="8" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="141" y="283" x2="383" y2="337" eletype="AC" valuetype="FX" radius="102" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="007FFA" valDC00="3000" colDC00="AA0000" valDC01="1500" colDC01="F80000" valDC02="1130" colDC02="00A800" valDC03="800" colDC03="0F82F8" valDC04="1" colDC04="F8C840" invertcolor="false"/>
        <LayoutElement type="2" replDC="F80002" valDC00="3000" colDC00="F80000" valDC01="1" colDC01="F80000" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="250" y="334" fixedtext="true" eletype="FX" text="0" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="205" y="272" fixedtext="false" eletype="CB" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="3"/>
        <LayoutElement type="0" color="000000" x="205" y="321" fixedtext="false" eletype="AB" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="206" y="321" fixedtext="false" eletype="AB" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="3" text="***   COPYRIGHT   ***"/>
        <LayoutElement type="0" color="000000" x="141" y="240" fixedtext="true" eletype="FX" text="© HM-DIY" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="3" text="***   GEAR   ***"/>
        <LayoutElement type="1" color="E86224" x="141" y="302" x2="0" y2="0" eletype="CF" valuetype="FX" radius="21" stroke="5" nr_values="1"/>
        <LayoutElement type="1" color="E86224" x="119" y="287" x2="164" y2="316" eletype="LN" valuetype="FX" radius="13" stroke="7" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="141" y="302" x2="0" y2="0" eletype="CF" valuetype="FX" radius="16" stroke="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="142" y="289" fixedtext="false" eletype="BG" text="220;30;10;12;14;16;18;21;24;28;32;36;42;50" font="MEDIUM" halignment="1" precision="0" nr_values="3"/>
        <LayoutElement type="0" color="000000" x="142" y="327" fixedtext="true" eletype="FX" text="Gear" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="3" text="***   DATA FIELS IN BOTTOM REGION   ***"/>
        <LayoutElement type="0" color="000000" x="10" y="358" fixedtext="true" eletype="FX" text="Clock" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="70" y="358" fixedtext="false" eletype="EV" text="ETA  $H:$M:$C" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="75" y="375" fixedtext="false" eletype="CT" text="$H:$M" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="150" y="358" fixedtext="true" eletype="FX" text="Lap " font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="267" y="358" fixedtext="false" eletype="LD" text="$V km" font="XTINY" halignment="0" precision="2" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="149" y="379" fixedtext="false" eletype="LR" text="$V" font="MEDIUM" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="224" y="375" fixedtext="false" eletype="LT" text="$H:$M:$C" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="10" y="415" fixedtext="true" eletype="FX" text="kCal" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="49" y="433" fixedtext="false" eletype="CA" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="105" y="415" fixedtext="true" eletype="FX" text="Ascend" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="141" y="433" fixedtext="false" eletype="TA" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="198" y="415" fixedtext="true" eletype="FX" text="Gradient" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="248" y="433" fixedtext="false" eletype="GR" text="$V" font="NR_MILD" halignment="0" precision="0" nr_values="16"/>
        <LayoutElement type="0" color="000000" x="264" y="439" fixedtext="true" eletype="FX" text="%" font="MEDIUM" halignment="1" precision="0" nr_values="1"/>
    </DIYLayout>
  • at the settings of the widget you can set different strings for "Default", "Running" and "Biking" - do you know a way to switch bettween the different values at Edge 1030 devices?
    Can you set a value (e.g. activity type) at a profile to make either one or the other active?
    Or is it totally useless for Edge devices and only the default string will be used?
  • I have to admit - I don‘t know. But I‘m thinking it‘s only for watches.
    Maybe HM can tell us.
  • Hi
    I told Bodenseematze to ask you (-:
    Sorry, I dont know the edge devices. On watches you have a bunch of apps for all different types of activities. If you choose the "running" app, the sport type is set to running and the running layout is chosen.
    regards
    Erich
