HMs DIY #1-6
Store Link
Because I want to keep this datafield and the app free for use I would be very grateful about a small donation to PayPal
A detailed description of how to use it can be found here:
HMs_DIY_GUIDANCE.pdf
HMs_DIY_ANLEITUNG.pdf
Thanks very much to mcinner1 for putting so much time into this documentation!
Designer download
You can contribute on my github page.
You can upload your layout so others can use it as well.
Also any changes to the fonts.txt can be updated there as well.
Garmin_HMsDIY
RELEASE NOTES
3.6.2
* switched to new SDK 7.2.1
* added devices: Approach S7 42mm, Descent Mk3 43mm /Mk3i 43mm, Descent Mk3i 51mm, Edge 1050, epix Pro Gen2 42mm, epix Pro Gen2 47mm / quatix 7 pro, epix Pro Gen2 51mm / D2 mach 1 pro / tactix 7
Fenix 7 Pro, Fenix 7 Pro Solar, Fenix 7S Pro, Fenix 7X Pro, Fenix 7xPro Solar, Forerunner 165, Forerunner 165M, Venu 3, Venu 3S, Vivoactive 5
3.5.1
* switched to new SDK 4.2.4
* added devices: FR265, FR265S, FR965, GPSMAP 67/67i, Marq (Gen 2), Marq (Gen 2) Aviator, EDGE 540, EDGE 840, Instinct 2x Solar
* added two new font types GLANCE, GLANCENR (only available if device supports it!)
for full releasenotes see: releasenotes.txt
    Former Member over 5 years ago in reply to hundsmiachn
    Yes, Speed works
    I erased and re-installed the app. I noticed that when I start the activity, it showed 0:00 for half a second and it then jumped to 19:59.
    This only happens the first time after changing the configuration
  • thanks for your tests - of course you're right about the replacement need for some of the special characters (e.g."<") to store them in an XML file - in case of "<" and ">" this is always needed - regardless of the encoding ;-)
    Would be interesting, which encoding the device itself uses...
  • am I right that "Elapsed time" includes all the pause times? If yes, is there a field, which only shows the time "in speed"?
    And "Current pause time" only shows a value if you're currently standing? If yes, is there a field for "Total pause time"?
    And another thing: which value range should I use for GPS accuracy (I want to color it with a dynamic color)? Is it going from 0.0 (no GPS) to 10.0 (optimal GPS) - and therefore the dynamic color values are going from 0...100?
    Or is the GPS accuray in percent and going from 0...100% (and therefore the color values from 0...1000)?
  • Hi
    Currently there is no value Total pause time available, but in the next release it will (-:
    GPS accuracy ranges from 0-4 as the SDK provides it (0: no GPS 4: best signal).
    I added an additional field "GPS high acc indicator" which is set to 1 when you stand still and the speed shown is also zero, that means that the GPS got the best fix. Because sometimes GPS accuracy of 4 is still not the best. I hope I explained it understandable.
    regards
    Erich
  • new version 2.3.5 on clone #4
    Designer:
    http://public.stattegg.info/HM_DIYD_2.3.5.zip
    2.3.5
    * new value: total pause time
    * hr zone times are now reset correctly
    * 2 new shortcuts:
    Ctrl+Shift+A sets the current cursor coordinates to x/y of the current selected element
    Ctrl+Shift+Y sets the current cursor coordinates to x2/y2 of the current selected element
    regards
    Erich
  • Thanks - you're incredible!
    Working on a new layout having the estimated coordinates now is very helpful!
    But please excuse that I give my wishes drop by drop and piece by piece... but on working, following came into my mind:
    After adding the new element (highlighted element), pointing at the place of x/y and then click a extraordinary key-combination for pasting the coordinates on their place in the element-list would be amazing! Let's say Shift+LeftMouse->x and y, and Shift+RightMouse->x2 and y2 (if there are any).
    Please just consider it as an idea - only do it if you think it makes sense and it is not a lot of effort.
    Thanks a lot!
  • Its already available, didn't you see it ;-))
  • Sorry I didn't express my comment well.
    Yes, I have seen it (thanks a lot) and it is really very helpful when adding new elements.
    But during my work (with the help seeing x/y) the idea above came in my mind - as addition to showing the coordinates.
  • There is a twinker smiley at the end...
    I added the shortcuts for setting x/y and x2/y2 right after your post and updated the 2.3.5 designer.
