HMs DIY #1-6
Store Link
Because I want to keep this datafield and the app free for use I would be very grateful about a small donation to PayPal
A detailed description of how to use it can be found here:
HMs_DIY_GUIDANCE.pdf
HMs_DIY_ANLEITUNG.pdf
Thanks very much to mcinner1 for putting so much time into this documentation!
Designer download
You can contribute on my github page.
You can upload your layout so others can use it as well.
Also any changes to the fonts.txt can be updated there as well.
Garmin_HMsDIY
RELEASE NOTES
3.6.2
* switched to new SDK 7.2.1
* added devices: Approach S7 42mm, Descent Mk3 43mm /Mk3i 43mm, Descent Mk3i 51mm, Edge 1050, epix Pro Gen2 42mm, epix Pro Gen2 47mm / quatix 7 pro, epix Pro Gen2 51mm / D2 mach 1 pro / tactix 7
Fenix 7 Pro, Fenix 7 Pro Solar, Fenix 7S Pro, Fenix 7X Pro, Fenix 7xPro Solar, Forerunner 165, Forerunner 165M, Venu 3, Venu 3S, Vivoactive 5
3.5.1
* switched to new SDK 4.2.4
* added devices: FR265, FR265S, FR965, GPSMAP 67/67i, Marq (Gen 2), Marq (Gen 2) Aviator, EDGE 540, EDGE 840, Instinct 2x Solar
* added two new font types GLANCE, GLANCENR (only available if device supports it!)
for full releasenotes see: releasenotes.txt
  • Might it be helpful to add Text Box with free Text (f. E.: Description), or even better for small Screenshot, in the Settings to keep Track by 6 Data Fields already?
  • A strange behaviour of Notification count:
    On my today's tour my Edge told me: Notification count = 1.
    Of course I checked the lock screen on my iPhone - No message.
    I checked the Notification widget on my Edge - No notification.
    I tried all I can think of to get rid of this "1".
    I disconnected my phone - Notification remained 1
    I booted my Edge, booted my iPhone - Notification came up with 1.
    I simply cannot get rid of this "1".
    So, I think it is maybe a not so difficult possibility to get the Notification counter empty (set to 0) when the phone connection becomes 0 (not connected)?
  • Does it clear if you change to a different activity profile?
  • Yes, I tried that - to no avail.
    But when I‘m thinking of it: after reboot of my Edge, the counter must have been got empty - but has been filled from my iPhone again.
    There must ba a „hidden“ message on my iPhone...
    Edit: and wrote once that he takes the value directly from SDK. So, there is nothing to empty...
  • Something very strange happening there. I don't have an iPhone so don't know how the notifications work. I know on android you can have notifications that don't display on the phone I wonder you've disabled notifications for an app but GCM still sees them
  • On my Edge I have enabled notifications for:
    -phonecalls
    -SMS
    -multimedia like Whatsapp
    I disabled notifications for e-mails.
    This works as set on my Edge‘s notification widget.
    But the SDK notification count „takes it all“. Lockscreen messages like:
    -Edge device has connected to GCM
    -Edge device has unlocked from GCM
    -Honeywell sensor reports high humidity in your cellar
    -short parking zone ends in 15 min
    and so on...
    (which I don't normally have a problem with. That's okay. )
    Edit:
    now I have managed to get rid of that one „unknown“ message. I opened all apps on my iPhone which are allowed to send messages and kicked them off from the memory.
    But what I don‘t get is: even when I disconnected my iPhone - and this was confirmed by „phone connected = 0“ - the notification count remained at 1.
  • Glad you got rid of the offending message.
    I know my fenix shows a standing notification even if the BT is disconnected though you have to reconnect to the phone to see the content. I didn't realise the edge did something similar. One thing I have noticed on the edge is that if you have a standing notification & put the edge to sleep, when you wake it up again the notification is still there even if it's been cleared from the phone itself. I think it clears eventually though
  • New version 2.9.6 available on all clones:
    http://public.stattegg.info/HM_DIYD_2.9.6.zip
    2.9.6
    * added datafield setting "Description". It is not used in the datafield, just for better overview of the different layouts.
  • Well, there are always unexplainable things...
    But thank God these aren't real problems.
    This HMs DIY is the best thing in the whole store! Relaxed
