So, Garmin solved the problem with LTH simply by not recording anymore LTH?!
I had no more LTH since 10 days....
All,
As I'm sure you've seen, we have a fix for this in Beta 15.09. Please see Enrolling in and Learning About Garmin Beta Software Program for instructions to enroll.
I am going to go ahead and…
This is a basic functionality problem in a premium watch that has existed since the release in one form or another. Shame on you Garmin! This should have been taken care of a long time ago by a dedicated…
Thank you all for your comments, we definitely read them and are aware of the on-going concern. We are still planning on releasing a fix in an upcoming Beta. We will make sure and announce when it is available…
I have been missing LTH updates since the 23rd of December (back then on 13.22 firmware, currently on 14.15). I am running with my 955 7days per week, 2 of them being higher HR workouts (tempo, threshold…
194, lactate treshold 183 laboratory tested
You must not run above your heart rate of 155bpm for more than 20% of your total run. Example: The run lasts 100 minutes. 20 minutes above 155bmp is the threshold. It will be a basic run under 20 minutes.
And I didn't, that was strange for me...
When you reset the zones according to Garmin, you must not be longer than 20% in the sum of 4 and 5 zones.
Yes, but you have to spend some time warming up.
Can you give me the link where did you get this information?
I have no source. Experience and constant staring at Connect. A lot of my runs were borderline and I didn't know why one run was a threshold run and the other was a base run.
I ran a very similar run today as a controlled lactate threshold test and no update.
https://connect.garmin.com/modern/activity/10666971999?share_unique_id=31
I also informed Garmin-Sierra about this.
