Hi guys!
After update 12.23 gps track has been disappointingly inaccurate.
Before update gps track was incredibly smooth!
What do you think?
Maybe opaque autumn clouds?
On pic below: after update and before.
All,
After reviewing the information provided (in this thread and via email) by many of you, I am having a difficult time finding examples of when the watch is recording a GPS position outside of the 3…
In addition to my comment below, we would like to know if any of you are experiencing the symptoms mentioned in:
Not maintaining GPS Lock in GPS Only mode
If so, please comment on that thread.
All,
We have had various GPS improvements since the 12.23 update. After updating to 13.15 (which is the current beta software), are any of you seeing GPS issues either during your recorded activity or…
Then I’m not crazy. I am losing my mind, to understand, as it is possible, that a watch of this kind, does worse, than a watch, much cheaper and with less GPS systems! Today I tried again, with all systems…
Hi Kevin, after updating to 13.21 nothing changes:
Run on 22.11.22 at 19:08 SW:13.21 GPS: Smart; GPS-mode: auto-select, Problem at Minute 1:30-2:00
I suspect we're seeing two different things here.
There is undoubtedly GPS jamming in evidence in the tracks recorded in Moscow. They're accurate until they pass close to certain landmarks, then become…
Hi Kevin, after 13.15 update nothing changed on the first activity.
(first is track, then pace and last is distance)
i don't run a pace at 3:25 km/h.
Hi Kevin, here are four activities, hope this can help
1. Running with V. 11.12 All Systems + Multiband GPS Mode smart, all was wonderfully
https://connect.garmin.com/modern/activity/9356172355
2. Running with V. 11.12.All Systems + Multiband GPS Mode smart, all was wonderfully
https://connect.garmin.com/modern/activity/9388168785
3. Running with V. 12.23. Auto-Select GPS Mode smart, at minute 5:30 GPS running wild, after minute 8:00 all is back to normal.
https://connect.garmin.com/modern/activity/9555493047
3. Running with V. 12.23 Auto-Select GPS Mode smart, at minute 5:00 GPS running wild, after minute 8:00 all is back to normal
https://connect.garmin.com/modern/activity/9573897661
i grand you access/view to my Garmin Connect account.
Today I installed 13.21 and was hoping that it would help, but its still the same terrible line. This is so sad.
I even removed completely the HRM Pro paired from watch and from connect app, and didn't use or paired it today. In case it had something to do.
Also I removed the map screen and iq store data fields from the activity. None of this helped.
One thing I just noticed in today's activities is that the speed graph data is mostly every 3 seconds. But my whatch is configured to record every second.
Hi SMR thanks for your answer.
I've tried all gps settings, but I mostly use "all systems". In the lake there is no obstruction to the sky so I believe multi band is not necessary.
Before the 955 I have used other Garmin watches in the same lake and conditions:
Vivoactive 3, FR 745, Fenix7 standard and even a Vivosport band which is old and has GPS only. All of them gave me smooth and straight lines with more steady speed.
I only have this issue with the FR955. It is like this in all outdoor activities other than running and walking. In my runnings the line seems ok.
