Hi guys!
After update 12.23 gps track has been disappointingly inaccurate.
Before update gps track was incredibly smooth!
What do you think?
Maybe opaque autumn clouds?
On pic below: after update and before.
All,
After reviewing the information provided (in this thread and via email) by many of you, I am having a difficult time finding examples of when the watch is recording a GPS position outside of the 3…
In addition to my comment below, we would like to know if any of you are experiencing the symptoms mentioned in:
Not maintaining GPS Lock in GPS Only mode
If so, please comment on that thread.
All,
We have had various GPS improvements since the 12.23 update. After updating to 13.15 (which is the current beta software), are any of you seeing GPS issues either during your recorded activity or…
Then I’m not crazy. I am losing my mind, to understand, as it is possible, that a watch of this kind, does worse, than a watch, much cheaper and with less GPS systems! Today I tried again, with all systems…
Hi Kevin, after updating to 13.21 nothing changes:
Run on 22.11.22 at 19:08 SW:13.21 GPS: Smart; GPS-mode: auto-select, Problem at Minute 1:30-2:00
I suspect we're seeing two different things here.
There is undoubtedly GPS jamming in evidence in the tracks recorded in Moscow. They're accurate until they pass close to certain landmarks, then become…
I usually use multi and while not as bad as yours I’ve noticed it is not as accurate as before the update as well. It was darn near perfect before. While still not bad, it does seem off a bit and seems to wobble more than it did before the update to 12.23. I thought at first it was just the conditions but it’s doing it over every activity no matter what the weather conditions are from rain to full on clear skies.
SA
Then I’m not crazy. I am losing my mind, to understand, as it is possible, that a watch of this kind, does worse, than a watch, much cheaper and with less GPS systems! Today I tried again, with all systems active, and multi-frequency, and really am disappointed with the quality of the track.
The track is very shaky, inaccurate at times, it goes very far off the track. And yesterday I also tried to connect to Garmin Express, to see if it could improve something. But unfortunately it doesn’t seem to be improved. I am very annoyed by this. I bought, this watch of 600 euros, just because I wanted a track, I do not say perfect to the millimeter, but at least, done well, satisfactory
https://connect.garmin.com/modern/activity/9526014311?share_unique_id=26
https://connect.garmin.com/modern/activity/9519119458?share_unique_id=32
Garmin-KevinGarmin-Kevin
Garmin-Adrian)
Garmin-Dan
