Weather widget not updating
Hi all, I’ve received yesterday my fenix 6 pro titanium.
I’d like to know whether it’s just me or there are some update issue with the weather widget?
Yesterday while setting up for the first time the watch I could get weather widget info.
Todays I cannot get any into although it’s currently connected to my phone (Android) and I even tried to perform a couple of manual sync.
Anuone else?
Thanks in advance
    0 Former Member in reply to Cytokrom C
    Worked for me on Fenix pro sapphire. Good tip to check the ‘weatherSetting : Yes.
    0 Former Member in reply to Former Member
    To sort the temperature problem for the time been i have installed free watch face SC8 this has a free gps temp gauge which is accurate and reliable in fact i like this face and may end up running it even if Garmin sort out there temp problem
  • Garmin Connect -> Settings -> App Diagnostics
    I have no information on what it means except that mine is set NO and weather does not update for me.
    Thank you very much - very helpful info.
  • Yes, this looks to be the issue. The weather widget worked on my F6 sapphire with fw 6.00 until I upgraded to iOS 13.3.1. Removing and reinstalling Connect acc. to the procedure mentioned somwhere in this thread does not solve it (only one time/one day) for me. So it seems if you update iOS you can expect things to break until a new Connect mobile app is released. Thanks to Garmin for looking into this and providing an update soon.
  • the problem still exists for me, any solution?
  • I use a samsung S10+ and I get the same problem
    Can anyone tell me if there is an update for the weather widget. Went from working properly to not. I'm using an Android running connect app 4.27. Just want this to work. I'm using the pre installed watch face that came with the Fenix 6 Sapphire.
    Thanks.
    Scroll up and try Cytokrom C's fix from about a month ago. On my screen it's in a green box. He got it from Garmin and it worked.
  • Most often when the weather app is wrong or showing wrong city cit me.  The fix is to beging to start some activity that will aquire GPS.
    You don't HAVE to actually start the activity only allow the GPS to acquire.     After that, with a sync to the phone. Updates the weather
    With all the recent updates I've seen the weather get "stuck" and the above worked each time.
    Hope it works for you
    Come on... We pay for garmin 800$ and you (developers/testers) didn't test it? Or even you did not, you could not fix this error for a 5 months?
