I am trying to figure out where to set my default music player. I read online that it should be an option under "Settings," but I don't see it there. I've hunted around a bit, and can't seem to locate it.
Trying to pair with Fenix5s
Control phone music with Fenix 6x Pro.
This is good steps did work for me just I had to do a little bit different I believe becouse of a diferend handset and OS beeing updated frequently.
I'm using Garmin…
I have not used AIMP, but for all media players, the latest versions of GCM no longer have a setting for a default player, so you have to launch the app you are going use, then start the playback on the app widget from your phone. Once the playback has been started, the controls on the Music Player widget will work. If you do not start the playback, it seems the app GCM selects and the widget it controls is unpredictable.
I have confirmed that the setting for Default Music Player was removed as part of the 4.2 app update. The device will now be able to control whatever media player is currently active on the phone.
We apologize for the confusion.
Active music player should be the most recent music/media player used on the phone.
