Watchface: Glance
NEWS UPDATE:
HANDY IQ:
https://apps.garmin.com/apps/3d167441-94f1-4b67-953f-e3ff6c272406
BIG EASY IQ:
https://apps.garmin.com/en-US/apps/1c8d4883-b4b2-49f3-b30c-954698cef794
EASY+:
https://apps.garmin.com/apps/7c993e2b-70b3-459a-bbe0-db48a89af5a8?tid=0
With introduction of Garmin Pay, I am starting to add a new payment option for some of my apps. The system is not flexible enough to just add Garmin Pay to existing apps, so I'll publish a copy of an app, with the same functionality but Garmin Pay as the payment provider.
The first one out is Glance Ultra (a copy of Glance Dual Screen):
https://apps.garmin.com/apps/1bed8f69-2e34-46e4-9786-3166fa3c6ab2?tid=0
EASY Round - 2023 #1 watch face of the year (by Garmin):
apps.garmin.com/.../9a619d99-3e5b-4eec-81e7-006655d797cc
EASY Round
GLANCE WATCH FACE app won THE BEST NEW WATCH FACE APP OF 2022 ! At the Developers conference Garmin announced nominees and winners for the best apps in different categories. Glance Watch Face was nominated and won in the best new watch face category Slight smile! Garmin didn't post the video from the conference yet, but it was already reported by other websites: https://the5krunner.com/2022/10/12/garmin-app-watchface-of-the-year-2022-ciq-winners-and-nominees-announced/
The idea for this app is simple:
- Use only large fonts, so that all data are visible at a glance (hence the name of the app: Glance   )
- Put as much data on the screen as possible, without sacrificing font size above
- Make all data fields customizeable to your needs
- Make colors customizeable as much as possible, so users can create their own design
The "Glance Watch Face" app is 100% FREE - no hidden restrictions, nagging, or expiration:
https://apps.garmin.com/en-US/apps/07ae ... 07e8035fae
There is also a mostly free app - BIG EASY: apps.garmin.com/.../86ec352b-da01-4806-8972-770c6d32a5e8
There are also two paid versions of this app - "Glance Pro":
https://apps.garmin.com/en-US/apps/ac4be3ce-f0f3-4c49-be01-5fa52614ab2b
and "Glance Dual Screen":
https://apps.garmin.com/en-US/apps/5c0fe72b-f045-4366-a878-d3e67c600868
Paid versions are identical to the free version (so no worries, FREE doesn't mean bad!), but have a lot of extra features features:
  • Open Weather Map support
  • Setting for TIME font weight
  • New way to use shared color themes
  • Support for many new metrics (like Body Battery, Stress Level, and lots more)
  • Extra progress bars and Graphs (in Dual Screen only)
  • Two separate data screens (in Dual Screen only)
  • A lot more - see apps description for the full list
  • You have an opportunity (and a small incentive) to support the development Slight smile
Unique feature of the Glance apps - you can save your own Color Themes and quicly switch between them righ on the watch.
NEW: Now you can SHARE your Color Theme! You can also quickly apply Color Themes shared with you. Here is a full description of how it all works: https://www.mobiledriveway.com/glance.html#color
Here is the current Color Themes Gallery: https://www.mobiledriveway.com/glance_gallery.html
Color themes are compatible between "Glance" and "Glance Pro" (except for "inactive status icons color", which became obsolete in "Pro").
I'd love to see all color combinations you came up with. Please post your themes in the Reviews and I'll add them to the gallery!
Questions and suggestions are welcome!
  • Suggestion:  can you add a second complication field to big easy IQ please?
    I made a simple app that pulls openweather high/low and POP data and publishes it as complication.   I want to use that to replace the less accurate Garmin high/low and POP fields but big easy IQ only supports displaying 1 complication from what I can see.
    Good work and great idea!
    If there is a second complication field then users can display more accurate openweather data for current weather,  high/low, and POP.
    Why don't you switch to the OWM in the app? Granted, it won't have POP, but the rest of the weather data will be more accurate.
  • I did at first but both the POP and high/low are Garmin weather only.  So I loose the most relevant data aside from current temp with built in openweather.
  • Sorry, Just a couple more thoughts on this.
    If you do decide to update at some point in the future, 4 complications would be ideal because then users could replace the built in weather options with fully custom ones.  (and ideally be able to disable the built in weather API calls that are not being used to reduce network/battery usage.).
    Another thought. The large fonts are great for older eyes or when not wearing glasses, but the smaller data fields can still be hard to read.  What if the second screen had an option to disable the large time display, leaving the whole screen to display the data fields in a much larger font?
  • I love this watchface. Amazing work!
    I have a feature request/suggestion, and I don’t know if this is possible. It would be great if the AOD L1 (Time only) setting could make the size of the time increase. I often glance (!) at the watch at an angle to check the time; having the clock even bigger in this mode would help, while keeping the size normal outside of AOD.
    Again, great work!
  • I have a feature request/suggestion, and I don’t know if this is possible. It would be great if the AOD L1 (Time only) setting could make the size of the time increase. I often glance (!) at the watch at an angle to check the time; having the clock even bigger in this mode would help, while keeping the size normal outside of AOD.
    Again, great work!
    Good idea, I'll keep it in mind. Not easily implemented though. Also, L1 AOD is not very popular.
  • I may be a minority, but I use L1 all the time. very clean and also (perhaps overly cautious) removes extra elements that might lead to burn in down the road.
    but I'm very content with the size of L1 time.
  • Is there anyway to get the Dexcom or GGlance complication on this watch face somewhere so I can see my blood sugar in realtime? For some reason it won’t allow me to add as a custom complication.
  • For some reason it won’t allow me to add as a custom complication.
    What exactly happens when you try?
    • Love the watch face, could we have Training Readiness option added to the selectable data fields for Glance Pro?
