HMs DIY #1-6
Store Link
Because I want to keep this datafield and the app free for use I would be very grateful about a small donation to PayPal
A detailed description of how to use it can be found here:
HMs_DIY_GUIDANCE.pdf
HMs_DIY_ANLEITUNG.pdf
Thanks very much to mcinner1 for putting so much time into this documentation!
Designer download
You can contribute on my github page.
You can upload your layout so others can use it as well.
Also any changes to the fonts.txt can be updated there as well.
Garmin_HMsDIY
RELEASE NOTES
3.9.1
* switched to new SDK 9.3.0
* added devices: Approach S72 43mm, Approach S72 47mm, D2 Mach 2 Pro, Edge 1060, Edge Explore 3, Edge Explore 3 Plus, Enduro 4, fenix 9 43mm, fenix 9 47mm, fenix 9 Pro 43mm, fenix 9 Pro 47mm, fenix 9 Pro 51mm,
fenix 9 Pro Solar 47mm, fenix 9 Pro Solar 51mm, Forerunner 70, Forerunner 170, Forerunner 170 Music, MARQ (Gen 3)
3.8.3
* fixed problem with backslash in configuration string
3.8.1
* switched to new SDK 8.3.0
* added devices: Approach S50, D2 Mach 2, Descent G2, Edge 550, Edge 850, Edge MTB, eTrex Touch, fēnix 8 Pro 47mm / 51mm / MicroLED, Forerunner 970, Forerunner 570 42mm, Forerunner 570 47mm,
GPSMAP H1, Instinct 3 AMOLED 45mm, Instinct 3 AMOLED 50mm, Instinct 3 Solar 45mm / 50mm, Instinct Crossover AMOLED, Instinct E 40mm, Instinct E 45mm, Venu 4 41mm, Venu 4 45mm / D2 Air X15, Venu X1, vívoactive 6
for full releasenotes see: releasenotes.txt
  • Great to see all those ANT+ values now being available for the datafield. However, I tried to add my Di2 values for battery and gear indexes or gear sizes to the DIY4 datafield and have only zero values (with or without an activity started). Did anyone get those values up and running?
  • Hi
    Did you connect the device before opening the datafield?
    Which version did you use (datatfield and designer)?
    Please post your xml file.
    Maybe it was connected via bluetooth?
  • It's a rather huge XML :) I used designer 2.6.0 and DIY Datafield #4 Version 2.6.1. Here's my XML. I only connect bluetooth occasionally (never to be precise, because the shimano app ain't nice :)) I tried both, connecting Di2 before and after adding or starting the datafield. It's Dura-Ace Di2 9150 by the way, but that shouldn't matter.
    <?xml version="1.0" encoding="UTF-8"?>
    <DIYLayout>
        <Device name="Edge 1030"/>
        <LayoutElement type="1" color="FFFFFF" x="0" y="0" x2="282" y2="470" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="3" text="***   DATAFIELD LINES   ***"/>
        <LayoutElement type="1" color="000000" x="0" y="148" x2="282" y2="148" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="205" x2="282" y2="205" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="354" x2="282" y2="354" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="411" x2="282" y2="411" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="141" y="148" x2="141" y2="205" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="141" y="354" x2="141" y2="410" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="86" y="412" x2="86" y2="470" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="196" y="412" x2="196" y2="470" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="3" text="*** NAVIGATION ***"/>
        <LayoutElement type="0" color="000000" x="141" y="4" fixedtext="false" eletype="NN" text="Eribor" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="Eribor"/>
        <LayoutElement type="0" color="000000" x="141" y="30" fixedtext="true" eletype="FX" text="/" font="SMALL" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="151" y="30" fixedtext="false" eletype="NC" text="$M:$S" font="SMALL" halignment="2" precision="0" nr_values="1" sampletext="425"/>
        <LayoutElement type="0" color="000000" x="131" y="30" fixedtext="false" eletype="DN" text="$V" font="SMALL" halignment="0" precision="2" nr_values="1" sampletext="28.34"/>
        <LayoutElement type="3" text="***   BATTERY   ***"/>
        <LayoutElement type="1" color="000000" x="38" y="40" x2="56" y2="52" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="56" y="42" x2="58" y2="50" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="40" y="42" x2="54" y2="50" eletype="RF" valuetype="BV" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="40" y="42" x2="54" y2="50" eletype="RF" valuetype="BV" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="00B001" x="40" y="42" x2="54" y2="50" eletype="RH" valuetype="BV" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="00B001" valDC00="1000" colDC00="00E000" hideDC00="false" valDC01="200" colDC01="00E000" hideDC01="false" valDC02="110" colDC02="F8C840" hideDC02="false" valDC03="1" colDC03="FF0000" hideDC03="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="35" y="40" fixedtext="false" eletype="BV" text="$V%" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="87"/>
        <LayoutElement type="0" color="000000" x="35" y="24" fixedtext="false" eletype="D1" text="$V%" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="90"/>
        <LayoutElement type="0" color="000000" x="37" y="24" fixedtext="true" eletype="FX" text="Di2" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="3" text="***   GPS   ***"/>
        <LayoutElement type="0" color="000000" x="270" y="40" fixedtext="true" eletype="FX" text="GPS" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="1" color="000000" x="236" y="46" x2="0" y2="0" eletype="CR" valuetype="FX" radius="8" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF000E" x="236" y="46" x2="0" y2="0" eletype="CF" valuetype="GA" radius="7" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="FF000E" valDC00="40" colDC00="00A800" hideDC00="false" valDC01="30" colDC01="00FC00" hideDC01="false" valDC02="20" colDC02="F8C840" hideDC02="false" valDC03="10" colDC03="F80000" hideDC03="false" valDC04="1" colDC04="FFFFFF" hideDC04="false" invertcolor="false"/>
        <LayoutElement type="3" text="***   DATA FIELDS IN UPPER REGION   ***"/>
        <LayoutElement type="1" color="C0C0C0" x="0" y="60" x2="282" y2="70" eletype="RF" valuetype="FX" radius="500" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="804040" x="0" y="60" x2="282" y2="70" eletype="RH" valuetype="CS" radius="500" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="804040" valDC00="600" colDC00="804040" hideDC00="false" valDC01="0" colDC01="804040" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="141" y="75" fixedtext="true" eletype="FX" text="gear" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="121" y="70" fixedtext="false" eletype="D2" text="$V" font="SMALL" halignment="0" precision="0" nr_values="1" sampletext="2"/>
        <LayoutElement type="0" color="000000" x="160" y="70" fixedtext="false" eletype="D5" text="$V" font="SMALL" halignment="2" precision="0" nr_values="1" sampletext="2"/>
        <LayoutElement type="0" color="000000" x="141" y="100" fixedtext="true" eletype="FX" text="(c) km/h (a)" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="12" y="80" fixedtext="false" eletype="CS" text="$V" font="NR_MEDIUM" halignment="2" precision="1" nr_values="1" sampletext="45.34"/>
        <LayoutElement type="0" color="000000" x="270" y="80" fixedtext="false" eletype="AS" text="$V" font="NR_MEDIUM" halignment="0" precision="1" nr_values="1" sampletext="34.76"/>
        <LayoutElement type="0" color="000000" x="141" y="124" fixedtext="true" eletype="FX" text="(c) rpm (a)" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="270" y="120" fixedtext="false" eletype="AC" text="$V" font="MEDIUM" halignment="0" precision="0" nr_values="1" sampletext="188.45"/>
        <LayoutElement type="0" color="000000" x="12" y="120" fixedtext="false" eletype="CC" text="$V" font="MEDIUM" halignment="2" precision="0" nr_values="1" sampletext="167.34"/>
        <LayoutElement type="3" text="***   TIMER AND DISTANCE   ***"/>
        <LayoutElement type="0" color="000000" x="12" y="151" fixedtext="true" eletype="FX" text="Timer" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="131" y="151" fixedtext="false" eletype="TV" text="noch  $H:$M:$C" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="825"/>
        <LayoutElement type="0" color="000000" x="12" y="170" fixedtext="false" eletype="TT" text="$H:$M:$C" font="NR_MILD" halignment="2" precision="0" nr_values="1" sampletext="4374"/>
        <LayoutElement type="0" color="000000" x="151" y="151" fixedtext="true" eletype="FX" text="Distanz" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="270" y="151" fixedtext="false" eletype="DD" text="noch $V" font="XTINY" halignment="0" precision="1" nr_values="1" sampletext="25.56"/>
        <LayoutElement type="0" color="000000" x="238" y="170" fixedtext="false" eletype="DS" text="$V" font="NR_MILD" halignment="0" precision="1" nr_values="1" sampletext="12.56"/>
        <LayoutElement type="0" color="000000" x="270" y="178" fixedtext="true" eletype="FX" text="km" font="SMALL" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="3" text="***   TRAININGS EFFEKT   ***"/>
        <LayoutElement type="1" color="E2C7C7" x="91" y="206" x2="191" y2="234" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="141" y="212" fixedtext="true" eletype="FX" text="zone" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="106" y="207" fixedtext="false" eletype="HZ" text="$V" font="MEDIUM" halignment="2" precision="0" nr_values="5" sampletext="4"/>
        <LayoutElement type="0" color="000000" x="176" y="207" fixedtext="false" eletype="PZ" text="$V" font="MEDIUM" halignment="0" precision="0" nr_values="5" sampletext="4"/>
        <LayoutElement type="3" text="***   HEART PICTURE   ***"/>
        <LayoutElement type="1" color="F80001" x="67" y="218" x2="0" y2="0" eletype="CF" valuetype="FX" radius="7" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="F80001" x="78" y="218" x2="0" y2="0" eletype="CF" valuetype="FX" radius="7" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="F80001" x="73" y="224" x2="0" y2="0" eletype="CF" valuetype="FX" radius="6" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="F80001" x="62" y="221" x2="74" y2="232" eletype="LN" valuetype="FX" radius="6" stroke="3" nr_values="1"/>
        <LayoutElement type="1" color="F80001" x="83" y="221" x2="72" y2="232" eletype="LN" valuetype="FX" radius="6" stroke="3" nr_values="1"/>
        <LayoutElement type="3" text="***   POWER PICTURE   ***"/>
        <LayoutElement type="1" color="0F4FFF" x="209" y="212" x2="220" y2="221" eletype="LN" valuetype="FX" radius="0" stroke="7" nr_values="1"/>
        <LayoutElement type="1" color="0F4FFF" x="200" y="223" x2="211" y2="232" eletype="LN" valuetype="FX" radius="0" stroke="7" nr_values="1"/>
        <LayoutElement type="1" color="0F4FFF" x="212" y="218" x2="207" y2="225" eletype="LN" valuetype="FX" radius="0" stroke="5" nr_values="1"/>
        <LayoutElement type="3" text="***   HEARTRATE   ***"/>
        <LayoutElement type="0" color="000000" x="71" y="238" fixedtext="true" eletype="FX" text="bpm" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="34" y="216" fixedtext="true" eletype="FX" text="200" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="1" color="D0D0D0" x="141" y="283" x2="157" y2="204" eletype="AC" valuetype="FX" radius="122" stroke="20" nr_values="1"/>
        <LayoutElement type="1" color="F80001" x="141" y="283" x2="158" y2="203" eletype="AF" valuetype="HR" radius="122" stroke="16" nr_values="1"/>
        <LayoutElement type="1" color="FF000A" x="141" y="283" x2="158" y2="203" eletype="AF" valuetype="AH" radius="106" stroke="8" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="141" y="283" x2="158" y2="203" eletype="AC" valuetype="FX" radius="102" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="FF000A" valDC00="2000" colDC00="AA0000" hideDC00="false" valDC01="1550" colDC01="F80000" hideDC01="false" valDC02="1350" colDC02="00C000" hideDC02="false" valDC03="1200" colDC03="38A8F8" hideDC03="false" valDC04="500" colDC04="C0C0C0" hideDC04="false" invertcolor="false"/>
        <LayoutElement type="2" replDC="F80001" valDC00="2000" colDC00="F80000" hideDC00="false" valDC01="500" colDC01="F80000" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="32" y="334" fixedtext="true" eletype="FX" text="50" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="78" y="272" fixedtext="false" eletype="HR" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1" sampletext="183.55"/>
        <LayoutElement type="0" color="000000" x="43" y="325" fixedtext="false" eletype="AH" text="$V" font="MEDIUM" halignment="2" precision="0" nr_values="1" sampletext="222"/>
        <LayoutElement type="3" text="***   POWER   ***"/>
        <LayoutElement type="0" color="000000" x="211" y="238" fixedtext="true" eletype="FX" text="Watt" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="248" y="216" fixedtext="true" eletype="FX" text="400" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="1" color="D0D0D0" x="141" y="283" x2="384" y2="336" eletype="AC" valuetype="FX" radius="122" stroke="20" nr_values="1"/>
        <LayoutElement type="1" color="F80002" x="141" y="283" x2="383" y2="337" eletype="AF" valuetype="CB" radius="122" stroke="16" nr_values="1"/>
        <LayoutElement type="1" color="007FFA" x="141" y="283" x2="383" y2="337" eletype="AF" valuetype="AB" radius="106" stroke="8" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="141" y="283" x2="383" y2="337" eletype="AC" valuetype="FX" radius="102" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="007FFA" valDC00="4000" colDC00="800080" hideDC00="false" valDC01="3000" colDC01="F80000" hideDC01="false" valDC02="2000" colDC02="00A800" hideDC02="false" valDC03="1000" colDC03="0F82F8" hideDC03="false" valDC04="1" colDC04="F8C840" hideDC04="false" invertcolor="false"/>
        <LayoutElement type="2" replDC="F80002" valDC00="4000" colDC00="F80000" hideDC00="false" valDC01="10" colDC01="F80000" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="250" y="334" fixedtext="true" eletype="FX" text="0" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="205" y="272" fixedtext="false" eletype="CB" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="5" sampletext="455.34"/>
        <LayoutElement type="0" color="000000" x="237" y="325" fixedtext="false" eletype="AB" text="$V" font="MEDIUM" halignment="0" precision="0" nr_values="1" sampletext="222"/>
        <LayoutElement type="3" text="***   GEAR   ***"/>
        <LayoutElement type="1" color="E2C7C7" x="141" y="270" x2="0" y2="0" eletype="CF" valuetype="FX" radius="32" stroke="5" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="141" y="273" x2="0" y2="0" eletype="CF" valuetype="FX" radius="28" stroke="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="141" y="258" fixedtext="false" eletype="TE" text="$V" font="NR_MILD" halignment="1" precision="1" nr_values="3" sampletext="4.2"/>
        <LayoutElement type="0" color="000000" x="142" y="304" fixedtext="true" eletype="FX" text="TE" font="TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="141" y="327" fixedtext="true" eletype="FX" text="-" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="136" y="328" fixedtext="false" eletype="E9" text="$V%" font="TINY" halignment="0" precision="0" nr_values="1" sampletext="100"/>
        <LayoutElement type="0" color="000000" x="146" y="328" fixedtext="false" eletype="F1" text="$V%" font="TINY" halignment="2" precision="0" nr_values="1" sampletext="100"/>
        <LayoutElement type="3" text="***   DATA FIELDS IN BOTTOM REGION   ***"/>
        <LayoutElement type="0" color="000000" x="10" y="358" fixedtext="true" eletype="FX" text="Uhrzeit" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="131" y="358" fixedtext="false" eletype="EV" text="ETA  $H:$M:$C" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="2334"/>
        <LayoutElement type="0" color="000000" x="10" y="375" fixedtext="false" eletype="CT" text="$H:$M" font="NR_MILD" halignment="2" precision="0" nr_values="1" sampletext="63312"/>
        <LayoutElement type="0" color="000000" x="131" y="380" fixedtext="false" eletype="TM" text="$V" font="MEDIUM" halignment="0" precision="0" nr_values="1" sampletext="18.4"/>
        <LayoutElement type="0" color="000000" x="138" y="381" fixedtext="true" eletype="FX" text="°" font="TINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="151" y="358" fixedtext="true" eletype="FX" text="Runde" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="270" y="358" fixedtext="false" eletype="LD" text="$V km" font="XTINY" halignment="0" precision="2" nr_values="1" sampletext="2.23"/>
        <LayoutElement type="0" color="000000" x="151" y="380" fixedtext="false" eletype="LR" text="$V" font="MEDIUM" halignment="2" precision="0" nr_values="1" sampletext="17"/>
        <LayoutElement type="0" color="000000" x="270" y="375" fixedtext="false" eletype="LT" text="$H:$M:$C" font="NR_MILD" halignment="0" precision="0" nr_values="1" sampletext="1326"/>
        <LayoutElement type="0" color="000000" x="12" y="415" fixedtext="true" eletype="FX" text="kCal" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="12" y="433" fixedtext="false" eletype="CA" text="$V" font="NR_MILD" halignment="2" precision="0" nr_values="1" sampletext="1563.77"/>
        <LayoutElement type="0" color="000000" x="141" y="415" fixedtext="false" eletype="CL" text="Anstieg ($Vm)" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="478.22"/>
        <LayoutElement type="0" color="000000" x="141" y="433" fixedtext="false" eletype="TA" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1" sampletext="423.66"/>
        <LayoutElement type="0" color="000000" x="270" y="415" fixedtext="true" eletype="FX" text="Neigung" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="272" y="433" fixedtext="false" eletype="GR" text="$V%" font="NR_MILD" halignment="0" precision="0" nr_values="16" sampletext="6.69"/>
    </DIYLayout>
  • Hi
    I fear that the DI2 will not work at all.
    https://developer.garmin.com/downloads/connect-iq/monkey-c/doc/Toybox/AntPlus/Shifting.html#getShiftingStatus-instance_method
    >>>> Get current shifting system status Will not provide status for Shimano shifting systems.
    Are there any other datafields which support DI2 other than Shimano one?
  • I actually did not read the "not" in this sentence. What a pity! :( No there are no connectiq fields for Di2, you're right. There are only datafields which are provided by Garmin itself. Strange enough. So maybe the shifting status is only for SRAM eTap?!
  • Actually it seems to be here, not in AntPlus:
    developer.garmin.com/.../Info.html
    as quoted in another forum thread:
    "I can't comment on getShiftingStatus, but I use info.rearDerailleurSize in compute() to find out what cassette gear I'm currently in and display in my App."
  • Hi
    I am sorry for that. I cant really do much about that, other to hope the Garmin will implement it in the future.
  • Ah, these values are no problem, will add them in the next release
  • Can confirm that SRAM eTap works
