HMs DIY #1-6
Store Link
Because I want to keep this datafield and the app free for use I would be very grateful about a small donation to PayPal
A detailed description of how to use it can be found here:
HMs_DIY_GUIDANCE.pdf
HMs_DIY_ANLEITUNG.pdf
Thanks very much to mcinner1 for putting so much time into this documentation!
Designer download
You can contribute on my github page.
You can upload your layout so others can use it as well.
Also any changes to the fonts.txt can be updated there as well.
Garmin_HMsDIY
RELEASE NOTES
3.9.1
* switched to new SDK 9.3.0
* added devices: Approach S72 43mm, Approach S72 47mm, D2 Mach 2 Pro, Edge 1060, Edge Explore 3, Edge Explore 3 Plus, Enduro 4, fenix 9 43mm, fenix 9 47mm, fenix 9 Pro 43mm, fenix 9 Pro 47mm, fenix 9 Pro 51mm,
fenix 9 Pro Solar 47mm, fenix 9 Pro Solar 51mm, Forerunner 70, Forerunner 170, Forerunner 170 Music, MARQ (Gen 3)
3.8.3
* fixed problem with backslash in configuration string
3.8.1
* switched to new SDK 8.3.0
* added devices: Approach S50, D2 Mach 2, Descent G2, Edge 550, Edge 850, Edge MTB, eTrex Touch, fēnix 8 Pro 47mm / 51mm / MicroLED, Forerunner 970, Forerunner 570 42mm, Forerunner 570 47mm,
GPSMAP H1, Instinct 3 AMOLED 45mm, Instinct 3 AMOLED 50mm, Instinct 3 Solar 45mm / 50mm, Instinct Crossover AMOLED, Instinct E 40mm, Instinct E 45mm, Venu 4 41mm, Venu 4 45mm / D2 Air X15, Venu X1, vívoactive 6
for full releasenotes see: releasenotes.txt
  • Changed it back, until I find a better working solution....
  • New version 2.6.1 is available on clone #4
    http://public.stattegg.info/HM_DIYD_2.6.0.zip
    2.6.1 (datafield only)
    * fixed crash when using ant running dynamics fields on devices that dont support them
    2.6.0
    * VAM total avg calculation reverted to first implementation
    * new values: ANT device types: BikePower, FitnessEquipment, RunningDynamics
    * added some safety checks for ant devices
  • Just for fun, I counted the number of available values. There are now 167 different values available ((-:
  • ...and today it is 5 months that you released the first version!
    Truly remarkable!
    Many thanks for that fantastic work!
  • Hi There, I have a DIY field that uses only the bottom half part of the edge1030 screen, but when I load it, select the 2 fields layout in the edge1030, and choose the DIY field for the bottom one, nothing is shown.
    Am I missing something?
    thank you
  • Hi
    Did you design the layout in the bottom half of the designer? Coordinates are absolute in the designer!
    regards
    Erich
  • Yes I did
    Please see code below:
    <?xml version="1.0" encoding="UTF-8"?>
    <DIYLayout>
        <Device name="Edge 1030"/>
        <LayoutElement type="1" color="FFFFFF" x="0" y="235" x2="282" y2="470" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="3" text="***   DATAFIELD LINES   ***"/>
        <LayoutElement type="3" text="*** Power Bars (325-395 px) ***"/>
        <LayoutElement type="1" color="000000" x="0" y="235" x2="282" y2="255" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="141" y="236" fixedtext="true" eletype="AS" text="POWER" font="TINY" halignment="1" precision="1" nr_values="1" sampletext="34.76"/>
        <LayoutElement type="3" text="***  Z0 (0-10w) ***"/>
        <LayoutElement type="3" text="***  Z1 (10-144w) ***"/>
        <LayoutElement type="1" color="C0C0C1" x="0" y="255" x2="47" y2="355" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="C0C0C1" x="0" y="255" x2="47" y2="355" eletype="RV" valuetype="S1" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C0C1" valDC00="1000" colDC00="C0C0C0" hideDC00="false" valDC01="1" colDC01="C0C0C0" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="24" y="320" fixedtext="false" eletype="H1" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="2560"/>
        <LayoutElement type="0" color="000000" x="24" y="260" fixedtext="false" eletype="S1" text="$V%" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="15"/>
        <LayoutElement type="3" text="*** Z2 (144-197w) ***"/>
        <LayoutElement type="1" color="38C8F8" x="47" y="255" x2="94" y2="355" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="38C8F8" x="47" y="255" x2="94" y2="355" eletype="RV" valuetype="S2" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="38C8F8" valDC00="1000" colDC00="38C8F9" hideDC00="false" valDC01="1" colDC01="38C8F9" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="72" y="320" fixedtext="false" eletype="H2" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="1825"/>
        <LayoutElement type="0" color="000000" x="72" y="260" fixedtext="false" eletype="S2" text="$V%" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="20"/>
        <LayoutElement type="3" text="***Z3 (197-236w) ***"/>
        <LayoutElement type="1" color="80FF80" x="94" y="255" x2="141" y2="355" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="80FF80" x="94" y="255" x2="141" y2="355" eletype="RV" valuetype="S3" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="80FF80" valDC00="1000" colDC00="00FF40" hideDC00="false" valDC01="1" colDC01="00FF40" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="118" y="320" fixedtext="false" eletype="H3" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="2190"/>
        <LayoutElement type="0" color="000000" x="118" y="260" fixedtext="false" eletype="S3" text="$V%" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="17"/>
        <LayoutElement type="3" text="*** Z4 (236-275w) ***"/>
        <LayoutElement type="1" color="FF8041" x="141" y="255" x2="188" y2="355" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF8041" x="141" y="255" x2="188" y2="355" eletype="RV" valuetype="S4" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="FF8041" valDC00="1000" colDC00="FF8040" hideDC00="false" valDC01="1" colDC01="FF8040" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="166" y="320" fixedtext="false" eletype="H4" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="1260"/>
        <LayoutElement type="0" color="000000" x="166" y="260" fixedtext="false" eletype="S4" text="$V%" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="3"/>
        <LayoutElement type="3" text="*** Z5 (275-415w) ***"/>
        <LayoutElement type="1" color="FF0001" x="188" y="255" x2="235" y2="355" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0001" x="188" y="255" x2="235" y2="355" eletype="RV" valuetype="S5" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="FF0001" valDC00="1000" colDC00="FF0000" hideDC00="false" valDC01="1" colDC01="FF0000" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="212" y="320" fixedtext="false" eletype="H5" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="1210"/>
        <LayoutElement type="0" color="000000" x="212" y="260" fixedtext="false" eletype="S5" text="$V%" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="19"/>
        <LayoutElement type="3" text="*** Z6 (415-1200w) ***"/>
        <LayoutElement type="1" color="FF00F1" x="235" y="255" x2="282" y2="355" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF00F1" x="235" y="255" x2="282" y2="355" eletype="RV" valuetype="S6" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="FF00F1" valDC00="1000" colDC00="FF00FF" hideDC00="false" valDC01="1" colDC01="FF00FF" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="260" y="320" fixedtext="false" eletype="H6" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="721"/>
        <LayoutElement type="0" color="000000" x="260" y="260" fixedtext="false" eletype="S6" text="$V%" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="1"/>
        <LayoutElement type="3" text="*** HR Bars (400-470 px) ***"/>
        <LayoutElement type="1" color="000000" x="0" y="355" x2="282" y2="375" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="141" y="356" fixedtext="true" eletype="AS" text="HR" font="TINY" halignment="1" precision="1" nr_values="1" sampletext="34.76"/>
        <LayoutElement type="3" text="***   Zone 1 ***"/>
        <LayoutElement type="1" color="C0C0C1" x="1" y="375" x2="57" y2="470" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="C0C0C1" x="1" y="375" x2="57" y2="470" eletype="RV" valuetype="P1" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="28" y="380" fixedtext="false" eletype="P1" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="25"/>
        <LayoutElement type="0" color="000000" x="28" y="440" fixedtext="false" eletype="T1" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="425"/>
        <LayoutElement type="3" text="***   Zone 2   ***"/>
        <LayoutElement type="1" color="38C8F9" x="57" y="375" x2="113" y2="470" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="38C8F9" x="57" y="375" x2="113" y2="470" eletype="RV" valuetype="P2" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="38C8F9" valDC00="1000" colDC00="38C8F8" hideDC00="false" valDC01="1" colDC01="38C8F8" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="85" y="380" fixedtext="false" eletype="P2" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="10"/>
        <LayoutElement type="0" color="000000" x="85" y="440" fixedtext="false" eletype="T2" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="528"/>
        <LayoutElement type="3" text="***   Zone 3 ***"/>
        <LayoutElement type="1" color="00F501" x="113" y="375" x2="169" y2="470" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="00F501" x="113" y="375" x2="169" y2="470" eletype="RV" valuetype="P3" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="00F501" valDC00="1000" colDC00="00F500" hideDC00="false" valDC01="1" colDC01="00F500" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="141" y="380" fixedtext="false" eletype="P3" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="18"/>
        <LayoutElement type="0" color="000000" x="141" y="440" fixedtext="false" eletype="T3" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="719"/>
        <LayoutElement type="3" text="***   Zone 4   ***"/>
        <LayoutElement type="1" color="FF8041" x="169" y="375" x2="225" y2="470" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF8041" x="169" y="375" x2="225" y2="470" eletype="RV" valuetype="P4" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="197" y="380" fixedtext="false" eletype="P4" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="13"/>
        <LayoutElement type="0" color="000000" x="197" y="440" fixedtext="false" eletype="T4" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="126"/>
        <LayoutElement type="3" text="***   Zone 5   ***"/>
        <LayoutElement type="1" color="FF80C1" x="225" y="375" x2="281" y2="470" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF80C1" x="225" y="375" x2="281" y2="470" eletype="RV" valuetype="P5" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="FF80C1" valDC00="1000" colDC00="FF80C0" hideDC00="false" valDC01="1" colDC01="FF80C0" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="253" y="380" fixedtext="false" eletype="P5" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="19"/>
        <LayoutElement type="0" color="000000" x="253" y="440" fixedtext="false" eletype="T5" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="621"/>
        <LayoutElement type="3" text="***   FIN   ***"/>
    </DIYLayout>
  • Every layout has to be startet at 0/0 in the designer - regardless where the datafield is situated on your display.
    Find here your code - moved to the right place.
    (I wrote a small program to do this work)
    <DIYLayout>
        <LayoutElement type="1" color="FFFFFF" x="0" y="0" x2="282" y2="235" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="0" x2="282" y2="20" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="141" y="1" fixedtext="true" eletype="AS" text="POWER" font="TINY" halignment="1" precision="1" nr_values="1" sampletext="34.76"/>
        <LayoutElement type="1" color="C0C0C1" x="0" y="20" x2="47" y2="120" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="C0C0C1" x="0" y="20" x2="47" y2="120" eletype="RV" valuetype="S1" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="24" y="85" fixedtext="false" eletype="H1" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="2560"/>
        <LayoutElement type="0" color="000000" x="24" y="25" fixedtext="false" eletype="S1" text="$V%" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="15"/>
        <LayoutElement type="1" color="38C8F8" x="47" y="20" x2="94" y2="120" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="38C8F8" x="47" y="20" x2="94" y2="120" eletype="RV" valuetype="S2" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="72" y="85" fixedtext="false" eletype="H2" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="1825"/>
        <LayoutElement type="0" color="000000" x="72" y="25" fixedtext="false" eletype="S2" text="$V%" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="20"/>
        <LayoutElement type="1" color="80FF80" x="94" y="20" x2="141" y2="120" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="80FF80" x="94" y="20" x2="141" y2="120" eletype="RV" valuetype="S3" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="118" y="85" fixedtext="false" eletype="H3" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="2190"/>
        <LayoutElement type="0" color="000000" x="118" y="25" fixedtext="false" eletype="S3" text="$V%" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="17"/>
        <LayoutElement type="1" color="FF8041" x="141" y="20" x2="188" y2="120" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF8041" x="141" y="20" x2="188" y2="120" eletype="RV" valuetype="S4" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="166" y="85" fixedtext="false" eletype="H4" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="1260"/>
        <LayoutElement type="0" color="000000" x="166" y="25" fixedtext="false" eletype="S4" text="$V%" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="3"/>
        <LayoutElement type="1" color="FF0001" x="188" y="20" x2="235" y2="120" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0001" x="188" y="20" x2="235" y2="120" eletype="RV" valuetype="S5" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="212" y="85" fixedtext="false" eletype="H5" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="1210"/>
        <LayoutElement type="0" color="000000" x="212" y="25" fixedtext="false" eletype="S5" text="$V%" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="19"/>
        <LayoutElement type="1" color="FF00F1" x="235" y="20" x2="282" y2="120" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF00F1" x="235" y="20" x2="282" y2="120" eletype="RV" valuetype="S6" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="260" y="85" fixedtext="false" eletype="H6" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="721"/>
        <LayoutElement type="0" color="000000" x="260" y="25" fixedtext="false" eletype="S6" text="$V%" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="1"/>
        <LayoutElement type="1" color="000000" x="0" y="120" x2="282" y2="140" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="141" y="121" fixedtext="true" eletype="AS" text="HR" font="TINY" halignment="1" precision="1" nr_values="1" sampletext="34.76"/>
        <LayoutElement type="1" color="C0C0C1" x="1" y="140" x2="57" y2="235" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="C0C0C1" x="1" y="140" x2="57" y2="235" eletype="RV" valuetype="P1" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="28" y="145" fixedtext="false" eletype="P1" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="25"/>
        <LayoutElement type="0" color="000000" x="28" y="205" fixedtext="false" eletype="T1" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="425"/>
        <LayoutElement type="1" color="38C8F9" x="57" y="140" x2="113" y2="235" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="38C8F9" x="57" y="140" x2="113" y2="235" eletype="RV" valuetype="P2" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="85" y="145" fixedtext="false" eletype="P2" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="10"/>
        <LayoutElement type="0" color="000000" x="85" y="205" fixedtext="false" eletype="T2" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="528"/>
        <LayoutElement type="1" color="00F501" x="113" y="140" x2="169" y2="235" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="00F501" x="113" y="140" x2="169" y2="235" eletype="RV" valuetype="P3" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="141" y="145" fixedtext="false" eletype="P3" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="18"/>
        <LayoutElement type="0" color="000000" x="141" y="205" fixedtext="false" eletype="T3" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="719"/>
        <LayoutElement type="1" color="FF8041" x="169" y="140" x2="225" y2="235" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF8041" x="169" y="140" x2="225" y2="235" eletype="RV" valuetype="P4" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="197" y="145" fixedtext="false" eletype="P4" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="13"/>
        <LayoutElement type="0" color="000000" x="197" y="205" fixedtext="false" eletype="T4" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="126"/>
        <LayoutElement type="1" color="FF80C1" x="225" y="140" x2="281" y2="235" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF80C1" x="225" y="140" x2="281" y2="235" eletype="RV" valuetype="P5" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="253" y="145" fixedtext="false" eletype="P5" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="19"/>
        <LayoutElement type="0" color="000000" x="253" y="205" fixedtext="false" eletype="T5" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="621"/>
    </DIYLayout>
  • Nice, it worked llike a charm.... and saved me some work
    thank you!
