HMs DIY #1-6
Store Link
Because I want to keep this datafield and the app free for use I would be very grateful about a small donation to PayPal
A detailed description of how to use it can be found here:
HMs_DIY_GUIDANCE.pdf
HMs_DIY_ANLEITUNG.pdf
Thanks very much to mcinner1 for putting so much time into this documentation!
Designer download
You can contribute on my github page.
You can upload your layout so others can use it as well.
Also any changes to the fonts.txt can be updated there as well.
Garmin_HMsDIY
RELEASE NOTES
3.9.1
* switched to new SDK 9.3.0
* added devices: Approach S72 43mm, Approach S72 47mm, D2 Mach 2 Pro, Edge 1060, Edge Explore 3, Edge Explore 3 Plus, Enduro 4, fenix 9 43mm, fenix 9 47mm, fenix 9 Pro 43mm, fenix 9 Pro 47mm, fenix 9 Pro 51mm,
fenix 9 Pro Solar 47mm, fenix 9 Pro Solar 51mm, Forerunner 70, Forerunner 170, Forerunner 170 Music, MARQ (Gen 3)
3.8.3
* fixed problem with backslash in configuration string
3.8.1
* switched to new SDK 8.3.0
* added devices: Approach S50, D2 Mach 2, Descent G2, Edge 550, Edge 850, Edge MTB, eTrex Touch, fēnix 8 Pro 47mm / 51mm / MicroLED, Forerunner 970, Forerunner 570 42mm, Forerunner 570 47mm,
GPSMAP H1, Instinct 3 AMOLED 45mm, Instinct 3 AMOLED 50mm, Instinct 3 Solar 45mm / 50mm, Instinct Crossover AMOLED, Instinct E 40mm, Instinct E 45mm, Venu 4 41mm, Venu 4 45mm / D2 Air X15, Venu X1, vívoactive 6
for full releasenotes see: releasenotes.txt
  • Deleting a loaded screen is easy, just highlight the "Elements" in the Elements menu and click on remove. But, you may want to keep some of the elements for your own design and just move them about.
    Yes, you can build a white rectangle over the black background, but you could also build up smaller rectangles and colour them different to go behind the data screens. What you can also do if building an intricate screen is build up the background later over an existing element and then when you have it right, move it to the background so that the data field moves to the front and displays over the background.
    Also don't forget to have a colour for both day and night when you are creating elements.
    Also constantly save and rename your copies, ie once you have deleted a loaded design,  rename it and save it. Then you will always have that "Blank Template " for future projects and still have the loaded design you started from unmodified,
  • I'm building my first layout from scratch for an Edge 520 plus but when I try to add an element in the layout below, I get the message "You have reached the maximum number of elements for this device!". I don't know if I'm missing something as I can see other layouts full of data and graphics...
    <?xml version="1.0" encoding="UTF-8"?>
    <DIYLayout>
        <Device name="Edge 520 Plus"/>
        <Designer time="18.12.2022 20:43" ver="3.4.2" ifver="C"/>
        <LayoutElement type="1" color="FFFFFF" x="0" y="0" x2="200" y2="265" eletype="RF" valuetype="FX" minval="false" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="3" text="----------------- Seperator ------------------"/>
        <LayoutElement type="1" color="000000" x="0" y="25" x2="265" y2="25" eletype="LN" valuetype="FX" minval="false" maxonly="false" daynight="false" radius="0" stroke="2" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="49" y="5" fixedtext="false" maxonly="false" daynight="false" eletype="CT" text="$H:$M" font="MEDIUM" halignment="0" precision="0" nr_values="1" sampletext="63312"/>
        <LayoutElement type="0" color="000000" x="103" y="5" fixedtext="false" maxonly="false" daynight="false" eletype="TM" text="$V" font="MEDIUM" halignment="0" precision="1" nr_values="1" sampletext="18.4"/>
        <LayoutElement type="0" color="000000" x="113" y="4" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="º" font="SMALL" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="168" y="5" fixedtext="false" maxonly="false" daynight="false" eletype="BV" text="$V%" font="MEDIUM" halignment="0" precision="0" nr_values="1" sampletext="87"/>
        <LayoutElement type="0" color="000000" x="192" y="5" fixedtext="false" maxonly="false" daynight="false" eletype="GA" text="$V" font="MEDIUM" halignment="0" precision="0" nr_values="1" sampletext="3"/>
        <LayoutElement type="1" color="000000" x="0" y="82" x2="265" y2="82" eletype="LN" valuetype="FX" minval="false" maxonly="false" daynight="false" radius="0" stroke="2" nr_values="1"/>
        <LayoutElement type="0" color="0000FF" x="46" y="34" fixedtext="false" maxonly="false" daynight="false" eletype="CS" text="$V" font="NR_THAI_HOT" halignment="0" precision="0" nr_values="1" sampletext="37"/>
        <LayoutElement type="0" color="000000" x="52" y="35" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="k" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="53" y="46" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="p" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="53" y="62" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="h" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="80" y="43" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="max" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FF0000" x="80" y="57" fixedtext="false" maxonly="false" daynight="false" eletype="MS" text="$V" font="MEDIUM" halignment="0" precision="0" nr_values="1" sampletext="65.34"/>
        <LayoutElement type="0" color="000000" x="183" y="34" fixedtext="false" maxonly="false" daynight="false" eletype="DS" text="$V" font="NR_THAI_HOT" halignment="0" precision="1" nr_values="1" sampletext="45.2"/>
        <LayoutElement type="0" color="000000" x="192" y="44" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="k" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="195" y="55" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="m" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="60" y="86" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="ASC" font="TINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="146" y="86" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="ELE" font="TINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="190" y="86" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="%" font="TINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="72" y="90" fixedtext="false" maxonly="false" daynight="false" eletype="TA" text="$V" font="NR_HOT" halignment="0" precision="0" nr_values="1" sampletext="560"/>
        <LayoutElement type="0" color="000000" x="158" y="90" fixedtext="false" maxonly="false" daynight="false" eletype="CL" text="$V" font="NR_HOT" halignment="0" precision="0" nr_values="1" sampletext="1253"/>
        <LayoutElement type="0" color="000000" x="203" y="90" fixedtext="false" maxonly="false" daynight="false" eletype="TA" text="$V" font="NR_HOT" halignment="0" precision="0" nr_values="1" sampletext="12"/>
        <LayoutElement type="1" color="000000" x="0" y="135" x2="265" y2="134" eletype="LN" valuetype="FX" minval="false" maxonly="false" daynight="false" radius="0" stroke="2" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="53" y="140" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="BPS" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="132" y="140" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="PWR" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="194" y="140" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="CAD" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="64" y="141" fixedtext="false" maxonly="false" daynight="false" eletype="HR" text="$V" font="NR_HOT" halignment="0" precision="0" nr_values="1" sampletext="183.55"/>
        <LayoutElement type="0" color="000000" x="141" y="141" fixedtext="false" maxonly="false" daynight="false" eletype="CB" text="$V" font="NR_HOT" halignment="0" precision="0" nr_values="1" sampletext="455.34"/>
        <LayoutElement type="0" color="000000" x="204" y="141" fixedtext="false" maxonly="false" daynight="false" eletype="CC" text="$V" font="NR_HOT" halignment="0" precision="0" nr_values="1" sampletext="75"/>
        <LayoutElement type="0" color="000000" x="20" y="188" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="AV" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="17" y="209" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="Z5" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="53" y="184" fixedtext="false" maxonly="false" daynight="false" eletype="AH" text="$V" font="SMALL" halignment="0" precision="0" nr_values="1" sampletext="154.49"/>
        <LayoutElement type="0" color="000000" x="57" y="206" fixedtext="false" maxonly="false" daynight="false" eletype="T5" text="$M:$S" font="SMALL" halignment="0" precision="0" nr_values="1" sampletext="621"/>
        <LayoutElement type="1" color="000000" x="0" y="227" x2="265" y2="227" eletype="LN" valuetype="FX" minval="false" maxonly="false" daynight="false" radius="0" stroke="2" nr_values="1"/>
    </DIYLayout>
  • Your device does not have enough memory for more elements. Not every device does have the same amount of memory a datafield can use.
  • hello does anyone have examples of data fields in hms DiY for a garmin edge explore I am a beginner, it is not to start from 0 thank youV️V️V️V️V️
  • You can just load a layout from another device, EDGE 830 for example, switch the device to Edge Explore and click "Scale to device".
  • but it is that the configuration of edge 830 brings for potentiometer and edge explore no, so the data will not give the same that's why I ask the edge explore does anyone have designs
  • Is the 5 minute update interval of temperature a limitation by SDK or by the app?
  • Hi,
    my girlfriend and me have the forerunners 255S and 955.
    Currently I'm adapting the fonts.txt and in priciple it works.
    But I have some questions.
    According to this page 255 / 255S / 955 have the same fonts.
    developer.garmin.com/.../
    Question 1:
    In the fonts.txt most fonts are identical between 255 and 955.
    But at some there are differences.
    e.g.
    "Forerunner 255" - "NR_THAI_HOT" ==> FNT_006B402400_ROBOTO_BLACK_NUMBER_FONT_57
    "Forerunner 955 / Solar" - "NR_THAI_HOT" ==> FNT_NOTO_SANS_BOLD_NMBR_94PX
    "Forerunner 955 / Solar" - "S_NR_THAI_HOT" ==> FNT_006B402400_ROBOTO_BLACK_NUMBER_FONT_57
    "S_NR_THAI_HOT" seems to be ok. But normally "NR_THAI_HOT" and "S_NR_THAI_HOT" should be identical, or not?
    If I change at 955 "FNT_NOTO_SANS_BOLD_NMBR_94PX" to "FNT_006B402400_ROBOTO_BLACK_NUMBER_FONT_57", the designer shows nothing.
    If I change to 255 in the designer, it works well. On the forerunner it works also well.
    Questions 2:
    In the fonts.txt the font numbers e.g. ..._57 are different to the linked page.
    Is there an interning mapping at the datafield?
    Question 3:
    Is there an intermediate size between medium and hot. The jump is very big.
    I am still happy with the data field, but would like to understand the above.
    After the adjustment I can upload the fonts.txt for 255S/255/955. But I want to be sure that everything is ok then.
    Thanks, Christian
  • Hello,
    is there a possibility to display only hours or minutes of the time? I would like to arrange hours and minutes one below the other. If I use $m or $M, the minutes count >60.
    Currently I hide the rest with a rectangle, but this cuts off other elements.
    Christian
