HMs DIY #1-6
Store Link
Because I want to keep this datafield and the app free for use I would be very grateful about a small donation to PayPal
A detailed description of how to use it can be found here:
HMs_DIY_GUIDANCE.pdf
HMs_DIY_ANLEITUNG.pdf
Thanks very much to mcinner1 for putting so much time into this documentation!
Designer download
You can contribute on my github page.
You can upload your layout so others can use it as well.
Also any changes to the fonts.txt can be updated there as well.
Garmin_HMsDIY
RELEASE NOTES
3.9.1
* switched to new SDK 9.3.0
* added devices: Approach S72 43mm, Approach S72 47mm, D2 Mach 2 Pro, Edge 1060, Edge Explore 3, Edge Explore 3 Plus, Enduro 4, fenix 9 43mm, fenix 9 47mm, fenix 9 Pro 43mm, fenix 9 Pro 47mm, fenix 9 Pro 51mm,
fenix 9 Pro Solar 47mm, fenix 9 Pro Solar 51mm, Forerunner 70, Forerunner 170, Forerunner 170 Music, MARQ (Gen 3)
3.8.3
* fixed problem with backslash in configuration string
3.8.1
* switched to new SDK 8.3.0
* added devices: Approach S50, D2 Mach 2, Descent G2, Edge 550, Edge 850, Edge MTB, eTrex Touch, fēnix 8 Pro 47mm / 51mm / MicroLED, Forerunner 970, Forerunner 570 42mm, Forerunner 570 47mm,
GPSMAP H1, Instinct 3 AMOLED 45mm, Instinct 3 AMOLED 50mm, Instinct 3 Solar 45mm / 50mm, Instinct Crossover AMOLED, Instinct E 40mm, Instinct E 45mm, Venu 4 41mm, Venu 4 45mm / D2 Air X15, Venu X1, vívoactive 6
for full releasenotes see: releasenotes.txt
  • i have a question: when i touch the screen of my edge 1000 in any data page (not custom ones) it shows a Home icon shortcut , so i can load segments during a ride. Can i do the same in your custom screens?
  • I can do that on my Edge 1030. On the "other" DIY you could NOT do that
    I would like to display an indicator next to my current speed that shows if I'm riding at a speed that is greater than or less than my average speed. If my Current speed ≥ Average + X (where X is a fixed value in the range of 0 to 2) then I would like to display a "+" or up arrow. I 'd *** to display "-" or down arrow if my Current speed ≤ Average - X.
    I read to documentation and I don't see any why to perform a mathematical comparison to set dynamic colors. Am I missing something? Can this functionality be added to DIY?
  • Dear hundsmiachn. I am also a fan of mathematical (and some logical) expressions. It would be great that we could calculate some functions that we created, like previous DIY App or maybe like AppBuilder5. Have you planned that? If not, is it possible to add that function feature to ToDo list? :)
    Hi,
    I'm using the datafield on my Forerunner 935 and it works well.
    Now I tested it on the Forerunner 235 but the fonts are wrong. (only capital letters and font size only 30%)
    Has someone a ready fonts.txt for the FR235?
    Thanks in advance.
    Christian
  • Hi
    Every layout looks different on each device, so you have to adjust your layout on the fr235. Keep in mind that you have not all values available on the fr235, because it is a low mem one. Fonts should already look ok on the fr235.
  • Just to inform you guys about ANT battery state for sensors:
    I've been running tests on the Garmin magnet-less speed and cadence sensors.
    Only the new generation 2 Garmin speed and cadence sensors provide the current battery status values via the DIY ANT values types.
    And there is no way yet to get battery state from a HR-belt.
  • +1 on the HR belt. I even have a new Garmin Dual and can't figure out how to see that one.
    I've got older and newer Garmin magnet-less speed and cadence sensors AND even two GSC-10 speed/cadence sensors and they're all seen in the ANT battery values for me. So far I've seen NEW, GOOD, and OK. Waiting for one to go down to see what it says then, LOW perhaps?
  • Is the Garmin Varia RTL-510's battery status possible? I mean, see the remaining percentage?
  • There is an ANT value type available in DIY (ANT BikeRadar battery), but I am not able to test it - I have no Varia RTL.
    But you‘ll get not the remaining percentage but the battery status: 0: INVALID, 1: NEW, 2: GOOD, 3: OK, 4: LOW, 5: CRITICAL
