HMs DIY #1-6
Store Link
Because I want to keep this datafield and the app free for use I would be very grateful about a small donation to PayPal
A detailed description of how to use it can be found here:
HMs_DIY_GUIDANCE.pdf
HMs_DIY_ANLEITUNG.pdf
Thanks very much to mcinner1 for putting so much time into this documentation!
Designer download
You can contribute on my github page.
You can upload your layout so others can use it as well.
Also any changes to the fonts.txt can be updated there as well.
Garmin_HMsDIY
RELEASE NOTES
3.6.2
* switched to new SDK 7.2.1
* added devices: Approach S7 42mm, Descent Mk3 43mm /Mk3i 43mm, Descent Mk3i 51mm, Edge 1050, epix Pro Gen2 42mm, epix Pro Gen2 47mm / quatix 7 pro, epix Pro Gen2 51mm / D2 mach 1 pro / tactix 7
Fenix 7 Pro, Fenix 7 Pro Solar, Fenix 7S Pro, Fenix 7X Pro, Fenix 7xPro Solar, Forerunner 165, Forerunner 165M, Venu 3, Venu 3S, Vivoactive 5
3.5.1
* switched to new SDK 4.2.4
* added devices: FR265, FR265S, FR965, GPSMAP 67/67i, Marq (Gen 2), Marq (Gen 2) Aviator, EDGE 540, EDGE 840, Instinct 2x Solar
* added two new font types GLANCE, GLANCENR (only available if device supports it!)
for full releasenotes see: releasenotes.txt
  • Hi @All
    Because I have done a complete rework of the datafield, I need some beta testers to check if everything works as before.
    For this I have uploaded a version 2.0.1 to the #3 clone.
    New designer must be downloaded here:
    public.stattegg.info/HM_DIYD_2.0.1.zip
    Please be aware that the config string structure has completely changed, so you will have to copy the string again into your datafield settings!
    Dont be confused if the string looks strange, I am using a ASCII85 style encoding, so I get better compression out of it, but it won't be readable anymore.
    Just for comparsion, with the old version you can add about 25 elements into a datafield for the "medium" memory devices (32kb). With the new version you can add up to 80!
    With higher memory devices I stopped testing at about 500 elements.
    If the number of elements is greater than about 50 you will see a loading screen at start to avoid running into "max codeline limits". So, If you have some hundreds elements it can take a few seconds to load the layout!
    If nothing major comes up, I will rollout the version to the other clones.
    Any testing is appreciated!
    regards
    Erich
  • Will test tomorrow (Sunday)! Looking forward to see what will hapen ,-)
  • I am sorry, I made a mistake when exporting the new version.
    Version 2.0.3 of the datafield should be ok now!
  • Hi. I would do a test but the link only downloads designer 1.3.3 and not 2.1.1.
  • Designer downloaded, but dynamic colors do not work on DIY HMs # 3.
  • I checked everything and I don't work.
    01 Z łukami Cadence i Heart.xml
    <?xml version="1.0" encoding="UTF-8"?>
    <DIYLayout>
        <Device name="Edge 830"/>
        <LayoutElement type="2" replDC="FF000E" valDC00="40" colDC00="00A800" valDC01="30" colDC01="00FC00" valDC02="20" colDC02="E86224" valDC03="10" colDC03="F80000" invertcolor="false"/>
        <LayoutElement type="2" replDC="FF0009" valDC00="1000" colDC00="330066" valDC01="1" colDC01="D7D7D7" invertcolor="false"/>
        <LayoutElement type="2" replDC="FF0008" valDC00="1000" colDC00="330066" valDC01="950" colDC01="800000" valDC02="1" colDC02="D7D7D7" invertcolor="false"/>
        <LayoutElement type="2" replDC="FF0007" valDC00="1000" colDC00="330066" valDC01="950" colDC01="800000" valDC02="900" colDC02="CC0000" valDC03="1" colDC03="D7D7D7" invertcolor="false"/>
        <LayoutElement type="2" replDC="FF0006" valDC00="1000" colDC00="330066" valDC01="950" colDC01="800000" valDC02="900" colDC02="CC0000" valDC03="850" colDC03="FF0000" valDC04="1" colDC04="D7D7D7" invertcolor="false"/>
        <LayoutElement type="2" replDC="FF0005" valDC00="1000" colDC00="330066" valDC01="950" colDC01="800000" valDC02="900" colDC02="CC0000" valDC03="850" colDC03="FF0000" valDC04="800" colDC04="FF8000" valDC05="1" colDC05="D7D7D7" invertcolor="false"/>
        <LayoutElement type="2" replDC="FF0004" valDC00="1000" colDC00="330066" valDC01="950" colDC01="800000" valDC02="900" colDC02="CC0000" valDC03="850" colDC03="FF0000" valDC04="800" colDC04="FF8000" valDC05="750" colDC05="8080FF" valDC06="1" colDC06="D7D7D7" invertcolor="false"/>
        <LayoutElement type="2" replDC="FF0003" valDC00="1000" colDC00="330066" valDC01="950" colDC01="800000" valDC02="900" colDC02="CC0000" valDC03="850" colDC03="FF0000" valDC04="800" colDC04="FF8000" valDC05="750" colDC05="8080FF" valDC06="700" colDC06="00FF40" valDC07="1" colDC07="D7D7D7" invertcolor="false"/>
        <LayoutElement type="2" replDC="FF0002" valDC00="1000" colDC00="330066" valDC01="950" colDC01="800000" valDC02="900" colDC02="CC0000" valDC03="850" colDC03="FF0000" valDC04="800" colDC04="FF8000" valDC05="750" colDC05="8080FF" valDC06="700" colDC06="00FF40" valDC07="650" colDC07="FFFF00" valDC08="1" colDC08="D7D7D7" invertcolor="false"/>
        <LayoutElement type="2" replDC="FF0001" valDC00="1000" colDC00="330066" valDC01="950" colDC01="800000" valDC02="900" colDC02="CC0000" valDC03="850" colDC03="FF0000" valDC04="800" colDC04="FF8000" valDC05="750" colDC05="8080FF" valDC06="700" colDC06="00FF40" valDC07="650" colDC07="FFFF00" valDC08="600" colDC08="C0C0C0" valDC09="1" colDC09="D7D7D7" invertcolor="false"/>
        <LayoutElement type="2" replDC="80FF87" valDC00="1901" colDC00="000099" valDC01="100" colDC01="D7D7D7" invertcolor="false"/>
        <LayoutElement type="2" replDC="80FF86" valDC00="1901" colDC00="000099" valDC01="1760" colDC01="800000" valDC02="100" colDC02="D7D7D7" invertcolor="false"/>
        <LayoutElement type="2" replDC="80FF85" valDC00="1901" colDC00="000099" valDC01="1760" colDC01="800000" valDC02="1620" colDC02="F40000" valDC03="100" colDC03="D7D7D7" invertcolor="false"/>
        <LayoutElement type="2" replDC="80FF84" valDC00="1901" colDC00="000099" valDC01="1760" colDC01="800000" valDC02="1620" colDC02="F40000" valDC03="1480" colDC03="FF8040" valDC04="100" colDC04="D7D7D7" invertcolor="false"/>
        <LayoutElement type="2" replDC="80FF83" valDC00="1901" colDC00="000099" valDC01="1760" colDC01="800000" valDC02="1620" colDC02="F40000" valDC03="1480" colDC03="FF8040" valDC04="1340" colDC04="FFFF00" valDC05="100" colDC05="D7D7D7" invertcolor="false"/>
        <LayoutElement type="2" replDC="80FF82" valDC00="1901" colDC00="000099" valDC01="1760" colDC01="800000" valDC02="1620" colDC02="F40000" valDC03="1480" colDC03="FF8040" valDC04="1340" colDC04="FFFF00" valDC05="1200" colDC05="00E800" valDC06="100" colDC06="D7D7D7" invertcolor="false"/>
        <LayoutElement type="2" replDC="80FF81" valDC00="1901" colDC00="000099" valDC01="1760" colDC01="800000" valDC02="1620" colDC02="F40000" valDC03="1480" colDC03="FF8040" valDC04="1340" colDC04="FFFF00" valDC05="1200" colDC05="00E800" valDC06="500" colDC06="00FFFF" valDC07="100" colDC07="D7D7D7" invertcolor="false"/>
        <LayoutElement type="1" color="FFFFFF" x="0" y="0" x2="246" y2="322" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="C0C0C0" x="246" y="5" x2="0" y2="5" eletype="LN" valuetype="FX" radius="0" stroke="28" nr_values="1"/>
        <LayoutElement type="2" replDC="FF00F1" valDC00="380" colDC00="0000FF" valDC01="10" colDC01="FFFFEA" invertcolor="false"/>
        <LayoutElement type="2" replDC="FF00F0" valDC00="361" colDC00="0080FF" valDC01="10" colDC01="FFFFEA" invertcolor="false"/>
        <LayoutElement type="1" color="FF0009" x="123" y="159" x2="4" y2="107" eletype="LN" valuetype="CC" radius="0" stroke="12" nr_values="1"/>
        <LayoutElement type="1" color="FF0008" x="123" y="159" x2="4" y2="121" eletype="LN" valuetype="CC" radius="0" stroke="12" nr_values="1"/>
        <LayoutElement type="1" color="FF0007" x="123" y="159" x2="3" y2="133" eletype="LN" valuetype="CC" radius="0" stroke="12" nr_values="1"/>
        <LayoutElement type="1" color="FF0006" x="123" y="159" x2="2" y2="145" eletype="LN" valuetype="CC" radius="0" stroke="12" nr_values="1"/>
        <LayoutElement type="1" color="FF0005" x="123" y="159" x2="0" y2="157" eletype="LN" valuetype="CC" radius="0" stroke="13" nr_values="1"/>
        <LayoutElement type="1" color="FF0004" x="123" y="165" x2="1" y2="170" eletype="LN" valuetype="CC" radius="0" stroke="13" nr_values="1"/>
        <LayoutElement type="1" color="FF0003" x="123" y="159" x2="3" y2="182" eletype="LN" valuetype="CC" radius="0" stroke="12" nr_values="1"/>
        <LayoutElement type="1" color="FF0002" x="123" y="159" x2="3" y2="194" eletype="LN" valuetype="CC" radius="0" stroke="11" nr_values="1"/>
        <LayoutElement type="1" color="FF0001" x="124" y="161" x2="3" y2="207" eletype="LN" valuetype="CC" radius="0" stroke="12" nr_values="1"/>
        <LayoutElement type="1" color="80FF87" x="123" y="159" x2="241" y2="110" eletype="LN" valuetype="HR" radius="0" stroke="15" nr_values="1"/>
        <LayoutElement type="1" color="80FF86" x="123" y="159" x2="241" y2="126" eletype="LN" valuetype="HR" radius="0" stroke="15" nr_values="1"/>
        <LayoutElement type="1" color="80FF85" x="123" y="159" x2="242" y2="141" eletype="LN" valuetype="HR" radius="0" stroke="15" nr_values="1"/>
        <LayoutElement type="1" color="80FF84" x="123" y="158" x2="243" y2="156" eletype="LN" valuetype="HR" radius="0" stroke="16" nr_values="1"/>
        <LayoutElement type="1" color="80FF83" x="123" y="159" x2="244" y2="173" eletype="LN" valuetype="HR" radius="0" stroke="16" nr_values="1"/>
        <LayoutElement type="1" color="80FF82" x="123" y="159" x2="242" y2="188" eletype="LN" valuetype="HR" radius="0" stroke="15" nr_values="1"/>
        <LayoutElement type="1" color="80FF81" x="123" y="159" x2="242" y2="205" eletype="LN" valuetype="HR" radius="0" stroke="15" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="123" y="159" x2="0" y2="0" eletype="CF" valuetype="FX" radius="105" stroke="22" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="123" y="159" x2="0" y2="0" eletype="CR" valuetype="FX" radius="127" stroke="12" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="72" y="178" x2="72" y2="138" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="173" y="178" x2="173" y2="138" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="FF80F8" valDC00="360" colDC00="3399FF" valDC01="10" colDC01="FFFFEA" invertcolor="false"/>
        <LayoutElement type="2" replDC="FF80F7" valDC00="360" colDC00="3399FF" valDC01="330" colDC01="33CCFF" valDC02="10" colDC02="FFFFEA" invertcolor="false"/>
        <LayoutElement type="2" replDC="FF80F6" valDC00="360" colDC00="3399FF" valDC01="330" colDC01="33CCFF" valDC02="300" colDC02="66FFFF" valDC03="10" colDC03="FFFFEA" invertcolor="false"/>
        <LayoutElement type="2" replDC="FF80F5" valDC00="360" colDC00="3399FF" valDC01="330" colDC01="33CCFF" valDC02="300" colDC02="66FFFF" valDC03="270" colDC03="00FF66" valDC04="10" colDC04="FFFFEA" invertcolor="false"/>
        <LayoutElement type="2" replDC="FF80F4" valDC00="360" colDC00="3399FF" valDC01="330" colDC01="33CCFF" valDC02="300" colDC02="66FFFF" valDC03="270" colDC03="00FF66" valDC04="240" colDC04="99FF33" valDC05="10" colDC05="FFFFEA" invertcolor="false"/>
        <LayoutElement type="2" replDC="FF80F3" valDC00="360" colDC00="3399FF" valDC01="330" colDC01="33CCFF" valDC02="300" colDC02="66FFFF" valDC03="270" colDC03="00FF66" valDC04="240" colDC04="99FF33" valDC05="210" colDC05="FFCC00" valDC06="10" colDC06="FFFFEA" invertcolor="false"/>
        <LayoutElement type="2" replDC="FF80F2" valDC00="360" colDC00="3399FF" valDC01="330" colDC01="33CCFF" valDC02="300" colDC02="66FFFF" valDC03="270" colDC03="00FF66" valDC04="240" colDC04="99FF33" valDC05="210" colDC05="FFCC00" valDC06="180" colDC06="FFCC66" valDC07="10" colDC07="FFFFEA" invertcolor="false"/>
        <LayoutElement type="2" replDC="FF80F1" valDC00="360" colDC00="3399FF" valDC01="330" colDC01="33CCFF" valDC02="300" colDC02="66FFFF" valDC03="270" colDC03="00FF66" valDC04="240" colDC04="99FF33" valDC05="210" colDC05="FFCC00" valDC06="180" colDC06="FFCC66" valDC07="150" colDC07="FFFF00" valDC08="10" colDC08="FFFFEA" invertcolor="false"/>
        <LayoutElement type="2" replDC="FF80F0" valDC00="360" colDC00="3399FF" valDC01="330" colDC01="33CCFF" valDC02="300" colDC02="66FFFF" valDC03="270" colDC03="00FF66" valDC04="240" colDC04="99FF33" valDC05="210" colDC05="FFCC00" valDC06="180" colDC06="FFCC66" valDC07="150" colDC07="FFFF00" valDC08="120" colDC08="FFFF9B" valDC09="10" colDC09="FFFFEA" invertcolor="false"/>
        <LayoutElement type="1" color="FF00F1" x="157" y="214" x2="172" y2="214" eletype="LN" valuetype="CS" radius="0" stroke="5" nr_values="1"/>
        <LayoutElement type="1" color="FF00F1" x="74" y="214" x2="89" y2="214" eletype="LN" valuetype="CS" radius="0" stroke="5" nr_values="1"/>
        <LayoutElement type="1" color="FF00F0" x="158" y="220" x2="172" y2="220" eletype="LN" valuetype="CS" radius="0" stroke="5" nr_values="1"/>
        <LayoutElement type="1" color="FF00F0" x="74" y="220" x2="88" y2="220" eletype="LN" valuetype="CS" radius="0" stroke="5" nr_values="1"/>
        <LayoutElement type="1" color="FF80F8" x="159" y="226" x2="172" y2="226" eletype="LN" valuetype="CS" radius="0" stroke="5" nr_values="1"/>
        <LayoutElement type="1" color="FF80F8" x="74" y="226" x2="87" y2="226" eletype="LN" valuetype="CS" radius="0" stroke="5" nr_values="1"/>
        <LayoutElement type="1" color="FF80F7" x="160" y="232" x2="173" y2="232" eletype="LN" valuetype="CS" radius="0" stroke="4" nr_values="1"/>
        <LayoutElement type="1" color="FF80F7" x="74" y="232" x2="86" y2="232" eletype="LN" valuetype="CS" radius="0" stroke="4" nr_values="1"/>
        <LayoutElement type="1" color="FF80F6" x="161" y="237" x2="173" y2="237" eletype="LN" valuetype="CS" radius="0" stroke="4" nr_values="1"/>
        <LayoutElement type="1" color="FF80F6" x="74" y="237" x2="85" y2="237" eletype="LN" valuetype="CS" radius="0" stroke="4" nr_values="1"/>
        <LayoutElement type="1" color="FF80F5" x="162" y="242" x2="173" y2="242" eletype="LN" valuetype="CS" radius="0" stroke="4" nr_values="1"/>
        <LayoutElement type="1" color="FF80F5" x="74" y="242" x2="84" y2="242" eletype="LN" valuetype="CS" radius="0" stroke="4" nr_values="1"/>
        <LayoutElement type="1" color="FF80F4" x="163" y="247" x2="173" y2="247" eletype="LN" valuetype="CS" radius="0" stroke="4" nr_values="1"/>
        <LayoutElement type="1" color="FF80F4" x="74" y="247" x2="83" y2="247" eletype="LN" valuetype="CS" radius="0" stroke="4" nr_values="1"/>
        <LayoutElement type="1" color="FF80F3" x="164" y="252" x2="173" y2="252" eletype="LN" valuetype="CS" radius="0" stroke="4" nr_values="1"/>
        <LayoutElement type="1" color="FF80F3" x="74" y="252" x2="82" y2="252" eletype="LN" valuetype="CS" radius="0" stroke="4" nr_values="1"/>
        <LayoutElement type="1" color="FF80F2" x="165" y="257" x2="173" y2="257" eletype="LN" valuetype="CS" radius="0" stroke="4" nr_values="1"/>
        <LayoutElement type="1" color="FF80F2" x="74" y="257" x2="81" y2="257" eletype="LN" valuetype="CS" radius="0" stroke="4" nr_values="1"/>
        <LayoutElement type="1" color="FF80F1" x="166" y="262" x2="173" y2="262" eletype="LN" valuetype="CS" radius="0" stroke="4" nr_values="1"/>
        <LayoutElement type="1" color="FF80F1" x="74" y="262" x2="80" y2="262" eletype="LN" valuetype="CS" radius="0" stroke="4" nr_values="1"/>
        <LayoutElement type="1" color="FF80F0" x="167" y="267" x2="172" y2="267" eletype="LN" valuetype="CS" radius="0" stroke="5" nr_values="1"/>
        <LayoutElement type="1" color="FF80F0" x="74" y="267" x2="79" y2="267" eletype="LN" valuetype="CS" radius="0" stroke="5" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="104" x2="246" y2="104" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="210" x2="245" y2="210" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="2" y="269" x2="243" y2="269" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="0080FF" x="120" y="27" x2="120" y2="51" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="123" y="65" x2="123" y2="100" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="244" y="0" fixedtext="false" eletype="BV" text="$V%" font="TINY" halignment="0" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="122" y="222" fixedtext="false" eletype="CS" text="$V" font="NR_MEDIUM" halignment="1" precision="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="122" y="252" fixedtext="false" eletype="CP" text="$M:$S" font="TINY" halignment="1" precision="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="124" y="210" fixedtext="true" eletype="FX" text="SPEED (km/h)" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="1216CD" x="37" y="210" fixedtext="true" eletype="FX" text="AVG SPEED M" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="0000FF" x="211" y="210" fixedtext="true" eletype="FX" text="AVG SPEED E" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="1216CD" x="39" y="223" fixedtext="false" eletype="AS" text="$V " font="NR_MILD" halignment="1" precision="1" nr_values="1"/>
        <LayoutElement type="0" color="0000FF" x="210" y="223" fixedtext="false" eletype="AD" text="$V" font="NR_MILD" halignment="1" precision="1" nr_values="1"/>
        <LayoutElement type="0" color="0000FF" x="210" y="250" fixedtext="false" eletype="EP" text="$M:$S" font="TINY" halignment="1" precision="1" nr_values="1"/>
        <LayoutElement type="0" color="1216CD" x="37" y="250" fixedtext="false" eletype="AP" text="$M:$S" font="TINY" halignment="1" precision="1" nr_values="1"/>
        <LayoutElement type="0" color="D20000" x="123" y="279" fixedtext="false" eletype="MS" text="$V" font="NR_MILD" halignment="1" precision="1" nr_values="1"/>
        <LayoutElement type="0" color="D20000" x="122" y="304" fixedtext="false" eletype="MP" text="$M:$S" font="TINY" halignment="1" precision="1" nr_values="1"/>
        <LayoutElement type="0" color="D20000" x="189" y="107" fixedtext="false" eletype="MH" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="201" y="145" fixedtext="false" eletype="HR" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="62" y="78" fixedtext="false" eletype="TT" text="$H:$M:$S" font="MEDIUM" halignment="1" precision="2" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="183" y="78" fixedtext="false" eletype="ET" text="$H:$M:$S" font="MEDIUM" halignment="1" precision="2" nr_values="1"/>
        <LayoutElement type="0" color="D20000" x="123" y="103" fixedtext="true" eletype="FX" text="MAX" font="TINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="D20000" x="123" y="268" fixedtext="true" eletype="FX" text="speed                max" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="0000FF" x="123" y="187" fixedtext="true" eletype="FX" text="AVG" font="SMALL" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="44" y="145" fixedtext="false" eletype="CC" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="0" y="63" fixedtext="true" eletype="FX" text="           Czas Jazdy                     Czas Ca�kowity" font="XTINY" halignment="2" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="0000FF" x="184" y="181" fixedtext="false" eletype="AH" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="D20000" x="57" y="107" fixedtext="false" eletype="MC" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="0000FF" x="62" y="181" fixedtext="false" eletype="AC" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="121" y="0" fixedtext="false" eletype="CT" text="$H:$M" font="TINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="24" y="34" fixedtext="false" eletype="TA" text="$V" font="SMALL" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="216" y="34" fixedtext="false" eletype="TD" text="$V" font="SMALL" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="156" y="32" fixedtext="false" eletype="GR" text="$V%" font="MEDIUM" halignment="1" precision="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="88" y="32" fixedtext="false" eletype="CL" text="$VM" font="MEDIUM" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="123" y="151" fixedtext="false" eletype="DS" text="$V" font="NR_MILD" halignment="1" precision="2" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="125" y="137" fixedtext="true" eletype="FX" text="Dystans (km)" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="246" y="60" x2="0" y2="60" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="72" y="212" x2="72" y2="322" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="173" y="212" x2="173" y2="322" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="121" y="19" fixedtext="true" eletype="FX" text=" Ca�k.SPD   WYSOKOSC      NACHYL        Ca�k.WZN" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="121" y="122" fixedtext="true" eletype="FX" text="  RYTM- -PULS" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="212" y="273" fixedtext="false" eletype="HP" text="$V%" font="SMALL" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="210" y="297" fixedtext="false" eletype="TE" text="$V T.E" font="SMALL" halignment="1" precision="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="37" y="273" fixedtext="false" eletype="HZ" text="$V  zone" font="SMALL" halignment="1" precision="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="37" y="297" fixedtext="false" eletype="CA" text="$V ca" font="SMALL" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="1" color="FF8080" x="28" y="137" x2="216" y2="137" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="0080FF" x="28" y="179" x2="216" y2="179" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="8080FF" x="55" y="27" x2="55" y2="51" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="8080FF" x="189" y="27" x2="189" y2="51" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF000E" x="14" y="9" x2="0" y2="0" eletype="CF" valuetype="GA" radius="8" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="241" y="40" fixedtext="true" eletype="FX" text="M" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="51" y="40" fixedtext="true" eletype="FX" text="M" font="XTINY" halignment="1" precision="0" nr_values="1"/>
    </DIYLayout>
  • Ok, found the problem, thanks for that....
  • updated clone #3, dynamic coloring for graphics works now.
