HMs DIY #1-6
Store Link
Because I want to keep this datafield and the app free for use I would be very grateful about a small donation to PayPal
A detailed description of how to use it can be found here:
HMs_DIY_GUIDANCE.pdf
HMs_DIY_ANLEITUNG.pdf
Thanks very much to mcinner1 for putting so much time into this documentation!
Designer download
You can contribute on my github page.
You can upload your layout so others can use it as well.
Also any changes to the fonts.txt can be updated there as well.
Garmin_HMsDIY
RELEASE NOTES
3.9.1
* switched to new SDK 9.3.0
* added devices: Approach S72 43mm, Approach S72 47mm, D2 Mach 2 Pro, Edge 1060, Edge Explore 3, Edge Explore 3 Plus, Enduro 4, fenix 9 43mm, fenix 9 47mm, fenix 9 Pro 43mm, fenix 9 Pro 47mm, fenix 9 Pro 51mm,
fenix 9 Pro Solar 47mm, fenix 9 Pro Solar 51mm, Forerunner 70, Forerunner 170, Forerunner 170 Music, MARQ (Gen 3)
3.8.3
* fixed problem with backslash in configuration string
3.8.1
* switched to new SDK 8.3.0
* added devices: Approach S50, D2 Mach 2, Descent G2, Edge 550, Edge 850, Edge MTB, eTrex Touch, fēnix 8 Pro 47mm / 51mm / MicroLED, Forerunner 970, Forerunner 570 42mm, Forerunner 570 47mm,
GPSMAP H1, Instinct 3 AMOLED 45mm, Instinct 3 AMOLED 50mm, Instinct 3 Solar 45mm / 50mm, Instinct Crossover AMOLED, Instinct E 40mm, Instinct E 45mm, Venu 4 41mm, Venu 4 45mm / D2 Air X15, Venu X1, vívoactive 6
for full releasenotes see: releasenotes.txt
  • <?xml version="1.0" encoding="UTF-8"?>
    <DIYLayout>
        <Device name="fenix 5S Plus"/>
        <LayoutElement type="1" color="FFFFFF" x="120" y="120" x2="0" y2="0" eletype="CF" valuetype="FX" radius="120" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="120" y="9" eletype="TT" text="$H:$M:$S" font="S_NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="1" color="808080" x="0" y="47" x2="240" y2="47" eletype="LN" valuetype="FX" radius="0" stroke="4" nr_values="1"/>
        <LayoutElement type="1" color="616161" x="0" y="104" x2="240" y2="104" eletype="LN" valuetype="FX" radius="0" stroke="4" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="119" y="55" eletype="DS" text="" font="NR_MEDIUM" halignment="0" precision="2" nr_values="1"/>
        <LayoutElement type="0" color="808080" x="221" y="43" eletype="TE" text="" font="MEDIUM" halignment="0" precision="1" nr_values="2"/>
        <LayoutElement type="0" color="000000" x="149" y="45" eletype="FX" text="TE" font="TINY" halignment="2" precision="1" nr_values="2"/>
        <LayoutElement type="0" color="000000" x="124" y="72" eletype="FX" text="TTD" font="TINY" halignment="2" precision="1" nr_values="2"/>
        <LayoutElement type="0" color="808080" x="235" y="69" eletype="TV" text="$M:$S" font="MEDIUM" halignment="0" precision="1" nr_values="2"/>
        <LayoutElement type="0" color="000000" x="146" y="110" eletype="CP" text="$M:$S" font="NR_HOT" halignment="0" precision="1" nr_values="2"/>
        <LayoutElement type="0" color="808080" x="242" y="117" eletype="AP" text="$M:$S" font="NR_MEDIUM" halignment="0" precision="1" nr_values="2"/>
        <LayoutElement type="2" replDC="FFFFFA" valDC00="2400" colDC00="FF0000" valDC01="3120" colDC01="FF8000" valDC02="3420" colDC02="008000" valDC03="3900" colDC03="8080FF" invertcolor="true"/>
        <LayoutElement type="1" color="FFFFFA" x="133" y="109" x2="235" y2="163" eletype="RC" valuetype="FX" radius="0" stroke="7" nr_values="1"/>
        <LayoutElement type="0" color="FF80C0" x="142" y="168" eletype="HR" text="" font="NR_HOT" halignment="0" precision="0" nr_values="1"/>
        <LayoutElement type="2" replDC="FF80C0" valDC00="1600" colDC00="FF0000" valDC01="1470" colDC01="FF8000" valDC02="1390" colDC02="00FF40" valDC03="1270" colDC03="0000FF" valDC04="100" colDC04="000000" invertcolor="false"/>
        <LayoutElement type="1" color="008040" x="130" y="167" x2="230" y2="219" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="008040" valDC00="1600" colDC00="FF0000" valDC01="1470" colDC01="FF8000" valDC02="1390" colDC02="00FF40" valDC03="1270" colDC03="80FFFF" valDC04="10" colDC04="000000" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="208" y="172" eletype="AH" text="" font="NR_MEDIUM" halignment="0" precision="0" nr_values="1"/>
    </DIYLayout>
  • Another check I forgot. You set a dynamic color for a graphics element and set the value type to fixed text. It must be a value, fixed text does not work. You have it twice in your layout.
    Will add a check to my todo list.
  • >>>if you create a filled rectangle that is greater than 281 wide or 469 high, which I've used to replicate a white background then the rectangle turns black
    The first element of my 1030-layout is a white filled rectangle over the whole screen and it doesn‘t make any problem.
    <Device name="Edge 1030"/>
    <LayoutElement type="1" color="FFFFFF" x="0" y="0" x2="282" y2="470" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
    Strange - or did I got you wrong?
  • >>>1.1.3 I created a course to follow and I selected Time to Dest - and it showed 00:00 (Garmin's filed was right). It must be said though that I started the course after I had begun with the workout. I wonder if this is related to the previous "all values are now reset on activity start"?
    I have set DIST_DESTINATION, TIME_DESTINATION and ETA to my layout and testet it by loading a stored course and by riding with my NEO. All calculated by avg. speed.
    After loading the course the layout shows right figure for DIST_DESTINATION. TIME and ETA are shown as „00“.
    After pressing the start-button on the Edge, the figures for DIST and ETA come to life. Since there is no valid value for avg. speed at the very beginning, it takes some seconds to get reasonable figures.
    But as far I can say - it works perfectly!
  • I just did a run (hence the radio silence :-) )
    I loaded a course on my Fenix 5+ before I started the activity, still I got 00:00 for "Time to dest (avg speed)" - for the whole run. To be honest I had the same issue with this field on the original DIY field.
  • Have you set avg.speed and distance and timer.time as elements on your display, too, so you can check, if they deliver reasonable values after starting your activity?
    (orig DIY worked for me, too)
  • The original Garmin fields work without issues. I have both timer and avg pace and distance. They're all fine.
  • Here is a section of a screenshot of my 1030 during the test-activity:
    HM DIY v1.1.3
    avg. speed = 23.5 km/h
    Timer is at 2 min : 39 sec
    above reads time left = 1 h : 57 min
    Distance (right field) = 1.0 km
    above reads distance left = 46 km
    ETA shows 13:09 (1:09 pm)
    Clock shows 11:12
    I haven't calculated this numbers, but my feeling says: yes - that's ok!
    If you want - let me/us download your XML I will make a test on my NEO.
    (XMLs are all the same for all devices - so I can test on my Edge)
  • You can just use the XML I posted 2 hours ago.
