HMs DIY #1-6
Store Link
Because I want to keep this datafield and the app free for use I would be very grateful about a small donation to PayPal
A detailed description of how to use it can be found here:
HMs_DIY_GUIDANCE.pdf
HMs_DIY_ANLEITUNG.pdf
Thanks very much to mcinner1 for putting so much time into this documentation!
Designer download
You can contribute on my github page.
You can upload your layout so others can use it as well.
Also any changes to the fonts.txt can be updated there as well.
Garmin_HMsDIY
RELEASE NOTES
3.9.1
* switched to new SDK 9.3.0
* added devices: Approach S72 43mm, Approach S72 47mm, D2 Mach 2 Pro, Edge 1060, Edge Explore 3, Edge Explore 3 Plus, Enduro 4, fenix 9 43mm, fenix 9 47mm, fenix 9 Pro 43mm, fenix 9 Pro 47mm, fenix 9 Pro 51mm,
fenix 9 Pro Solar 47mm, fenix 9 Pro Solar 51mm, Forerunner 70, Forerunner 170, Forerunner 170 Music, MARQ (Gen 3)
3.8.3
* fixed problem with backslash in configuration string
3.8.1
* switched to new SDK 8.3.0
* added devices: Approach S50, D2 Mach 2, Descent G2, Edge 550, Edge 850, Edge MTB, eTrex Touch, fēnix 8 Pro 47mm / 51mm / MicroLED, Forerunner 970, Forerunner 570 42mm, Forerunner 570 47mm,
GPSMAP H1, Instinct 3 AMOLED 45mm, Instinct 3 AMOLED 50mm, Instinct 3 Solar 45mm / 50mm, Instinct Crossover AMOLED, Instinct E 40mm, Instinct E 45mm, Venu 4 41mm, Venu 4 45mm / D2 Air X15, Venu X1, vívoactive 6
for full releasenotes see: releasenotes.txt
  • One more info:
    Only If the order is reversed ("highest" color is lowest value [for example pace]) you have to put the lowest value first and check the "invert color order"!
    regards
    Erich
    • 1.1.4 On initial open of software, my custom file I was working on is shown - but the filename in the title bar shows layout.xml (my file is called "F5 Plus font test 2.xml"). Wait. It appears it automatically saved a new file called layout.xml on exiting 1.1.3?
    • 1.1.3 I created a course to follow and I selected Time to Dest - and it showed 00:00 (Garmin's filed was right). It must be said though that I started the course after I had begun with the workout. I wonder if this is related to the previous "all values are now reset on activity start"?
    Note: When updating/testing for fonts I found that you need to exit the activity between string updates since the custom field string does not seem to update when you are already in the activity.
  • Can you make a pace format without leading zero  - 0:00 instead of 00:00 - to take up less space?
  • yes, the previous version saved to layout.xml on exit. I have reworked the handling, it was a little bit confusing.
    Will add the custom time format with no leading zero to my todo list.
    One more thing that came to my mind for the next release is a "Add" button, which will add an xml file to an already
    opened one, instead of replacing the existing one. Then you can save some templates, for example dynamic colors.
    Regarding fonts.txt: yes, the file is only loaded on startup, so you have to restart the app to see the changes.
  • Thanks!
    I was unclear. I meant when updating strings on the watch, you need to exit the activity before you see the changes. That's on my Fenix 5 Plus
  • Enjoying following the apps development. Almost all the functions that I used from the DIY field have been added. If you are still looking for features that haven't been ported over yet, some I'm missing are
    Elapsed Time
    Current Lap Time
    Dynamically colour fixed text based on a data value as you can do now for graphic elements
    Combine Data Values & Text in the same field so they can be aligned together (ie add % to the Gradient)
    There is a small issue for the Edge 1030 layouts in the designer. The screen size on the Edge 1030 is 282 x 470. However if you create a filled rectangle that is greater than 281 wide or 469 high, which I've used to replicate a white background then the rectangle turns black & if the text/data elements are black they are effectively invisible.
    This actually exists in the Edge 1030 example in 1.1.4 which also replicates the white background by having a full screen filled rectangle that is 282 x 470
    Thumbs up for the work so far in such a short space of time
  • If I add the following string:
    GCFFXFFFFFF01012001200120@$VTTTT00000001012000091401$H:$M:$S@$GLNFX80808001000000470240004704@$GLNFX61616101000001040240010404@$VDSDS00000001011900550620@$VTETE80808002022100430310@$VFXFX00000002014900450112TE@$VFXFX00000002012400720112TTD@$VTVTV80808002023500690310$M:$S@$VCPCP00000002014601100710$M:$S@$VAPAP80808002024201170610$M:$S@$CFFFFFA12400FF00003120FF8000342000800039008080FF@$GRCFXFFFFFA01013301090102005407@$VHRHRFF80C001014201680700@$CFF80C001600FF00001470FF8000139000FF4012700000FF0100000000@$GRFFX008040010130016701000052@$C00804001600FF00001470FF8000139000FF40127080FFFF0010000000@$VAHAH00000001020801720600
    My Fenix crashes.
    This one (without dynamic fields) works:
    GCFFXFFFFFF01012001200120@$VTTTT00000001012000091401$H:$M:$S@$GLNFX80808001000000470240004704@$GLNFX61616101000001040240010404@$VDSDS00000001011900550620@$VTETE80808002022100430310@$VFXFX00000002014900450112TE@$VFXFX00000002012400720112TTD@$VTVTV80808002023500690310$M:$S@$VCPCP00000002014601100710$M:$S@$VAPAP80808002024201170610$M:$S@$GRCFXFFFFFA01013301090102005407@$VHRHRFF80C001014201680700@$CFF80C001600FF00001470FF8000139000FF4012700000FF0100000000@$VAHAH00000001020801720600
    Let me know if you need the XMLs
    In addition, I have changed some font settings marked as done - this way they fit better on my F5+. I am mentioning this FYI.
  • yes, please post the xml file...
