HMs DIY #1-6
Store Link
Because I want to keep this datafield and the app free for use I would be very grateful about a small donation to PayPal
A detailed description of how to use it can be found here:
HMs_DIY_GUIDANCE.pdf
HMs_DIY_ANLEITUNG.pdf
Thanks very much to mcinner1 for putting so much time into this documentation!
Designer download
You can contribute on my github page.
You can upload your layout so others can use it as well.
Also any changes to the fonts.txt can be updated there as well.
Garmin_HMsDIY
RELEASE NOTES
3.9.1
* switched to new SDK 9.3.0
* added devices: Approach S72 43mm, Approach S72 47mm, D2 Mach 2 Pro, Edge 1060, Edge Explore 3, Edge Explore 3 Plus, Enduro 4, fenix 9 43mm, fenix 9 47mm, fenix 9 Pro 43mm, fenix 9 Pro 47mm, fenix 9 Pro 51mm,
fenix 9 Pro Solar 47mm, fenix 9 Pro Solar 51mm, Forerunner 70, Forerunner 170, Forerunner 170 Music, MARQ (Gen 3)
3.8.3
* fixed problem with backslash in configuration string
3.8.1
* switched to new SDK 8.3.0
* added devices: Approach S50, D2 Mach 2, Descent G2, Edge 550, Edge 850, Edge MTB, eTrex Touch, fēnix 8 Pro 47mm / 51mm / MicroLED, Forerunner 970, Forerunner 570 42mm, Forerunner 570 47mm,
GPSMAP H1, Instinct 3 AMOLED 45mm, Instinct 3 AMOLED 50mm, Instinct 3 Solar 45mm / 50mm, Instinct Crossover AMOLED, Instinct E 40mm, Instinct E 45mm, Venu 4 41mm, Venu 4 45mm / D2 Air X15, Venu X1, vívoactive 6
for full releasenotes see: releasenotes.txt
  • Hi
    When I insert an Arc(X=123, Y=642, Start A.=258, End A.=282, Radius=600) on Edge 830 the layout becomes distorted. With Circle with same parameters is OK.
    Can you please check.
  • It might be the known bug in Garmins SDK.
    Please read the postings from 9 month ago in that thread:
    https://forums.garmin.com/developer/connect-iq/f/showcase/206277/hms-diy-1-6/995859#995859
  • Glad to hear someone else observes this.  Are you using miles or kilometers?  I was thinking as most users of this data field seem to be using kilometers we would have heard of this before if it happens to both.
  • I use miles. I'm super good at the conversion. 1609.344 is etched in my brain, meters per mile!!
  • Hi
    Has anyone managed to adjust fonts for Edge 830. I have a little bit problems with XTINY, TINY fonts.
    Thanks
  • Time and Temperature values doesn't show, if they have negative Y axes  (and maybe all other values too)
  • Here is my file
    <?xml version="1.0" encoding="UTF-8"?>
    <DIYLayout>
        <Device name="Edge 830"/>
        <Designer time="25.09.2020 20:41" ver="3.0.2" ifver="B"/>
        <LayoutElement type="3" text="----------------- Background ------------------"/>
        <LayoutElement type="1" color="C0C0C0" x="0" y="0" x2="246" y2="17" eletype="RF" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="0" y="18" x2="246" y2="55" eletype="RF" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="17" x2="322" y2="17" eletype="LN" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="BBFFDD" x="123" y="639" x2="258" y2="282" eletype="CF" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="599" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="123" y="640" x2="258" y2="282" eletype="CR" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="600" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="0" y="98" x2="246" y2="322" eletype="RF" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="97" x2="322" y2="97" eletype="LN" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="99" x2="322" y2="99" eletype="LN" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="123" y="107" x2="123" y2="132" eletype="LN" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="10" y="140" x2="236" y2="140" eletype="LN" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="123" y="148" x2="123" y2="176" eletype="LN" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="10" y="184" x2="236" y2="184" eletype="LN" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="82" y="192" x2="82" y2="220" eletype="LN" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="164" y="192" x2="164" y2="220" eletype="LN" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="50" y="226" x2="196" y2="226" eletype="LN" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="50" y="228" x2="196" y2="228" eletype="LN" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="50" y="273" x2="196" y2="273" eletype="LN" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="50" y="271" x2="196" y2="271" eletype="LN" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="50" y="326" x2="239" y2="270" eletype="AC" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="100" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="50" y="328" x2="239" y2="270" eletype="AC" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="100" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="196" y="326" x2="270" y2="301" eletype="AC" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="100" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="196" y="328" x2="270" y2="301" eletype="AC" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="100" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="50" y="371" x2="239" y2="270" eletype="AC" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="100" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="50" y="373" x2="239" y2="270" eletype="AC" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="100" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="196" y="373" x2="270" y2="301" eletype="AC" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="100" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="196" y="371" x2="270" y2="301" eletype="AC" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="100" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="82" y="283" x2="82" y2="312" eletype="LN" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="164" y="283" x2="164" y2="312" eletype="LN" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="3" text="----------------- Battery ------------------"/>
        <LayoutElement type="1" color="000000" x="4" y="1" x2="30" y2="16" eletype="RF" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="30" y="4" x2="34" y2="13" eletype="RF" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="6" y="3" x2="28" y2="14" eletype="RF" valuetype="BV" minval="false" maxonly="false" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="6" y="3" x2="9" y2="14" eletype="RF" valuetype="BV" minval="false" maxonly="false" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="00B001" x="6" y="3" x2="28" y2="14" eletype="RH" valuetype="BV" minval="false" maxonly="false" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="12" y="4" fixedtext="false" maxonly="false" daynight="true" eletype="BV" text="$V" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext="89"/>
        <LayoutElement type="2" replDC="00B001" valDC00="1000" colDC00="000000" hideDC00="false" blinkDC00="false" valDC01="200" colDC01="00E000" hideDC01="false" blinkDC01="false" valDC02="110" colDC02="F8C840" hideDC02="false" blinkDC02="false" valDC03="1" colDC03="FF0000" hideDC03="false" blinkDC03="false" invertcolor="false"/>
        <LayoutElement type="3" text="----------------- Time ------------------"/>
        <LayoutElement type="0" color="000000" x="242" y="-3" fixedtext="false" maxonly="false" daynight="true" eletype="CT" text="$h:$M" font="TINY" halignment="0" precision="0" nr_values="1" sampletext="23455"/>
        <LayoutElement type="3" text="----------------- Temperature ------------------"/>
        <LayoutElement type="0" color="000000" x="123" y="-3" fixedtext="false" maxonly="false" daynight="true" eletype="TM" text="$V °C" font="TINY" halignment="1" precision="1" nr_values="1" sampletext="18.4"/>
        <LayoutElement type="3" text="----------------- Speed ------------------"/>
        <LayoutElement type="0" color="000000" x="85" y="52" fixedtext="true" maxonly="false" daynight="true" eletype="FX" text="Speed" font="SMALL" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="158" y="52" fixedtext="true" maxonly="false" daynight="true" eletype="FX" text="km/h" font="SMALL" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="123" y="43" fixedtext="false" maxonly="false" daynight="true" eletype="C2" text="$V" font="NR_MILD" halignment="1" precision="1" nr_values="1" sampletext="23.5"/>
        <LayoutElement type="0" color="000000" x="85" y="76" fixedtext="true" maxonly="false" daynight="true" eletype="FX" text="Avg." font="TINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="158" y="76" fixedtext="true" maxonly="false" daynight="true" eletype="FX" text="km/h" font="TINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="123" y="77" fixedtext="false" maxonly="false" daynight="true" eletype="AS" text="$V" font="SMALL" halignment="1" precision="2" nr_values="1" sampletext="34.76"/>
        <LayoutElement type="3" text="----------------- Heart Rate ------------------"/>
        <LayoutElement type="0" color="000000" x="61" y="100" fixedtext="true" maxonly="false" daynight="true" eletype="FX" text="Heart Rate" font="TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="61" y="117" fixedtext="false" maxonly="false" daynight="true" eletype="HR" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="183.55"/>
        <LayoutElement type="0" color="000000" x="184" y="100" fixedtext="true" maxonly="false" daynight="true" eletype="FX" text="Avg. HR" font="TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="185" y="117" fixedtext="false" maxonly="false" daynight="true" eletype="AH" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="154.49"/>
        <LayoutElement type="3" text="----------------- Timer $  Distance ------------------"/>
        <LayoutElement type="0" color="000000" x="61" y="141" fixedtext="true" maxonly="false" daynight="true" eletype="FX" text="Timer" font="TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="79" y="163" fixedtext="false" maxonly="false" daynight="true" eletype="TT" text="$H:$M:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="3600"/>
        <LayoutElement type="1" color="FFFFFF" x="53" y="167" x2="90" y2="180" eletype="RF" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="61" y="159" fixedtext="false" maxonly="false" daynight="true" eletype="TT" text="$H:$M:$C" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="3600"/>
        <LayoutElement type="0" color="000000" x="184" y="141" fixedtext="true" maxonly="false" daynight="true" eletype="FX" text="Distance" font="TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="185" y="159" fixedtext="false" maxonly="false" daynight="true" eletype="C3" text="$V" font="MEDIUM" halignment="1" precision="2" nr_values="1" sampletext="25.3"/>
        <LayoutElement type="3" text="----------------- Lap ------------------"/>
        <LayoutElement type="0" color="000000" x="41" y="186" fixedtext="true" maxonly="false" daynight="true" eletype="FX" text="Curent Lap" font="TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="41" y="207" fixedtext="false" maxonly="false" daynight="true" eletype="LT" text="$H:$M:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="1326"/>
        <LayoutElement type="0" color="000000" x="123" y="186" fixedtext="true" maxonly="false" daynight="true" eletype="FX" text="Lap Speed" font="TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="123" y="207" fixedtext="false" maxonly="false" daynight="true" eletype="CV" text="$V" font="TINY" halignment="1" precision="2" nr_values="1" sampletext="32.2"/>
        <LayoutElement type="0" color="000000" x="205" y="186" fixedtext="true" maxonly="false" daynight="true" eletype="FX" text="Lap Dist." font="TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="205" y="207" fixedtext="false" maxonly="false" daynight="true" eletype="LD" text="$V km" font="TINY" halignment="1" precision="2" nr_values="1" sampletext="2.23"/>
        <LayoutElement type="3" text="----------------- Elevation ------------------"/>
        <LayoutElement type="0" color="000000" x="41" y="280" fixedtext="true" maxonly="false" daynight="true" eletype="FX" text="Ascent" font="TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="41" y="299" fixedtext="false" maxonly="false" daynight="true" eletype="TA" text="$V" font="SMALL" halignment="1" precision="0" nr_values="1" sampletext="50"/>
        <LayoutElement type="0" color="000000" x="123" y="274" fixedtext="true" maxonly="false" daynight="true" eletype="FX" text="30s VAM" font="TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="123" y="293" fixedtext="false" maxonly="false" daynight="true" eletype="VC" text="$V" font="SMALL" halignment="1" precision="0" nr_values="30" sampletext="50"/>
        <LayoutElement type="0" color="000000" x="205" y="280" fixedtext="true" maxonly="false" daynight="true" eletype="FX" text="Elevation" font="TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="205" y="299" fixedtext="false" maxonly="false" daynight="true" eletype="CL" text="$V" font="SMALL" halignment="1" precision="0" nr_values="1" sampletext="50"/>
        <LayoutElement type="3" text="----------------- Logo ------------------"/>
        <LayoutElement type="0" color="0080FF" x="123" y="19" fixedtext="true" maxonly="false" daynight="true" eletype="FX" text="ORBEA OIZ" font="SMALL" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="0080FF" x="122" y="20" fixedtext="true" maxonly="false" daynight="true" eletype="FX" text="ORBEA OIZ" font="SMALL" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="0080FF" x="124" y="19" fixedtext="true" maxonly="false" daynight="true" eletype="FX" text="ORBEA OIZ" font="SMALL" halignment="1" precision="0" nr_values="1" sampletext=""/>
    </DIYLayout>
  • At the moment it is not possible to use negative values for coordinates altough you can enter them in the designer. It will be fixed in the next version (will come today).
