HMs DIY #1-6
Store Link
Because I want to keep this datafield and the app free for use I would be very grateful about a small donation to PayPal
A detailed description of how to use it can be found here:
HMs_DIY_GUIDANCE.pdf
HMs_DIY_ANLEITUNG.pdf
Thanks very much to mcinner1 for putting so much time into this documentation!
Designer download
You can contribute on my github page.
You can upload your layout so others can use it as well.
Also any changes to the fonts.txt can be updated there as well.
Garmin_HMsDIY
RELEASE NOTES
3.9.1
* switched to new SDK 9.3.0
* added devices: Approach S72 43mm, Approach S72 47mm, D2 Mach 2 Pro, Edge 1060, Edge Explore 3, Edge Explore 3 Plus, Enduro 4, fenix 9 43mm, fenix 9 47mm, fenix 9 Pro 43mm, fenix 9 Pro 47mm, fenix 9 Pro 51mm,
fenix 9 Pro Solar 47mm, fenix 9 Pro Solar 51mm, Forerunner 70, Forerunner 170, Forerunner 170 Music, MARQ (Gen 3)
3.8.3
* fixed problem with backslash in configuration string
3.8.1
* switched to new SDK 8.3.0
* added devices: Approach S50, D2 Mach 2, Descent G2, Edge 550, Edge 850, Edge MTB, eTrex Touch, fēnix 8 Pro 47mm / 51mm / MicroLED, Forerunner 970, Forerunner 570 42mm, Forerunner 570 47mm,
GPSMAP H1, Instinct 3 AMOLED 45mm, Instinct 3 AMOLED 50mm, Instinct 3 Solar 45mm / 50mm, Instinct Crossover AMOLED, Instinct E 40mm, Instinct E 45mm, Venu 4 41mm, Venu 4 45mm / D2 Air X15, Venu X1, vívoactive 6
for full releasenotes see: releasenotes.txt
  • Hi
    Ijust changed BikeSpeed bat status to voltage! All other ant bat fields are still bat status. So, even Voltage is not shown for BikeSpeed?
  • Sorry - my mistake with ANT power.
    No, battery status/Voltage for ANT bikespeed battery remains 0.
  • There must be some ANT communication from the Garmin hub speed sensor to the head unit:
  • For the Stages powermeter ANT bikepower battery works perfectly! After placing a new battery I've got battery status 1 which is new.
    ...but on the other hand - if it works perfectly with my power sensor, there can't be anything wrong with the code...?
  • Hi. Strange situation in designer 2.7.8 and 2.7.9 I can't load my layouts, for example. Regards
    <?xml version="1.0" encoding="UTF-8"?>
    <DIYLayout>
        <Device name="Edge 830"/>
        <LayoutElement type="1" color="DFDFDF" x="246" y="5" x2="0" y2="5" eletype="LN" valuetype="FX" radius="0" stroke="27" nr_values="1"/>
        <LayoutElement type="1" color="BBFFDD" x="0" y="19" x2="246" y2="54" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="0" y="53" x2="246" y2="324" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="80FFFF" x="123" y="178" x2="178" y2="362" eletype="AC" valuetype="FX" radius="115" stroke="17" nr_values="1"/>
        <LayoutElement type="1" color="F8F8F6" x="123" y="178" x2="178" y2="362" eletype="AF" valuetype="CS" radius="115" stroke="17" nr_values="1"/>
        <LayoutElement type="1" color="F8F8F5" x="123" y="178" x2="178" y2="362" eletype="AF" valuetype="AS" radius="115" stroke="4" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="53" x2="246" y2="53" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="25" y="249" x2="66" y2="249" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="180" y="249" x2="224" y2="249" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="75" y="259" x2="169" y2="259" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="0000FF" x="25" y="291" x2="66" y2="291" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="0000FF" x="180" y="291" x2="224" y2="291" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="44" y="124" x2="202" y2="124" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="181" x2="246" y2="181" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="215" x2="246" y2="215" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="72" y="320" x2="72" y2="218" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="86" y="177" x2="86" y2="128" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="92" y="181" x2="152" y2="215" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="104" y="215" x2="142" y2="229" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="160" y="177" x2="160" y2="128" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="172" y="320" x2="172" y2="218" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="55" y="20" x2="55" y2="52" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="189" y="20" x2="189" y2="52" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="123" y="20" x2="123" y2="52" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="123" y="136" fixedtext="false" eletype="CP" text="$M:$S" font="TINY" halignment="1" precision="1" nr_values="1" sampletext="280"/>
        <LayoutElement type="0" color="EA0000" x="123" y="78" fixedtext="false" eletype="MP" text="$M:$S" font="TINY" halignment="1" precision="1" nr_values="1" sampletext="211"/>
        <LayoutElement type="0" color="0000FF" x="54" y="136" fixedtext="false" eletype="AP" text="$M:$S" font="TINY" halignment="1" precision="1" nr_values="1" sampletext="254"/>
        <LayoutElement type="0" color="0080FF" x="193" y="136" fixedtext="false" eletype="EP" text="$M:$S" font="TINY" halignment="1" precision="1" nr_values="1" sampletext="254"/>
        <LayoutElement type="0" color="000000" x="123" y="153" fixedtext="false" eletype="CS" text="$V" font="NR_MILD" halignment="1" precision="1" nr_values="1" sampletext="45.34"/>
        <LayoutElement type="0" color="EA0000" x="123" y="95" fixedtext="false" eletype="MS" text="$V" font="NR_MILD" halignment="1" precision="1" nr_values="1" sampletext="65.34"/>
        <LayoutElement type="0" color="0000FF" x="54" y="153" fixedtext="false" eletype="AS" text="$V" font="NR_MILD" halignment="1" precision="1" nr_values="1" sampletext="34.76"/>
        <LayoutElement type="0" color="0080FF" x="194" y="153" fixedtext="false" eletype="AD" text="$V" font="NR_MILD" halignment="1" precision="1" nr_values="1" sampletext="14.36"/>
        <LayoutElement type="0" color="EA0000" x="201" y="226" fixedtext="false" eletype="MH" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="204.79"/>
        <LayoutElement type="0" color="000000" x="201" y="262" fixedtext="false" eletype="HR" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1" sampletext="183.55"/>
        <LayoutElement type="0" color="0000FF" x="200" y="300" fixedtext="false" eletype="AH" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="154.49"/>
        <LayoutElement type="0" color="EA0000" x="45" y="226" fixedtext="false" eletype="MC" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="210.55"/>
        <LayoutElement type="0" color="000000" x="44" y="262" fixedtext="false" eletype="CC" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1" sampletext="167.34"/>
        <LayoutElement type="0" color="0000FF" x="46" y="300" fixedtext="false" eletype="AC" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="188.45"/>
        <LayoutElement type="0" color="000000" x="150" y="0" fixedtext="false" eletype="CT" text="$H:$M" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="63312"/>
        <LayoutElement type="0" color="000000" x="227" y="0" fixedtext="false" eletype="BV" text="$V %" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="87"/>
        <LayoutElement type="0" color="000000" x="200" y="193" fixedtext="false" eletype="ET" text="$H:$M:$S" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="3356"/>
        <LayoutElement type="0" color="000000" x="46" y="193" fixedtext="false" eletype="TT" text="$H:$M:$S" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="4374"/>
        <LayoutElement type="0" color="000000" x="123" y="230" fixedtext="false" eletype="DS" text="$V" font="NR_MILD" halignment="1" precision="2" nr_values="1" sampletext="12.56"/>
        <LayoutElement type="0" color="000000" x="123" y="212" fixedtext="false" eletype="OM" text="$V" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="1121.21"/>
        <LayoutElement type="0" color="000000" x="216" y="30" fixedtext="false" eletype="TA" text="$V" font="SMALL" halignment="1" precision="0" nr_values="1" sampletext="423.66"/>
        <LayoutElement type="0" color="000000" x="24" y="30" fixedtext="false" eletype="TD" text="$V" font="SMALL" halignment="1" precision="0" nr_values="1" sampletext="457.21"/>
        <LayoutElement type="0" color="000000" x="89" y="29" fixedtext="false" eletype="CL" text="$VM" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="478.22"/>
        <LayoutElement type="0" color="000000" x="157" y="29" fixedtext="false" eletype="GR" text="$V%" font="MEDIUM" halignment="1" precision="1" nr_values="16" sampletext="6.69"/>
        <LayoutElement type="0" color="000000" x="186" y="104" fixedtext="false" eletype="HP" text="$V%" font="SMALL" halignment="1" precision="0" nr_values="1" sampletext="84.12"/>
        <LayoutElement type="0" color="000000" x="62" y="104" fixedtext="false" eletype="CA" text="$Vc" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="1563.77"/>
        <LayoutElement type="0" color="000000" x="123" y="202" fixedtext="false" eletype="PT" text="$H:$M:$S" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="374"/>
        <LayoutElement type="0" color="000000" x="123" y="181" fixedtext="false" eletype="TI" text="$H:$M:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="374"/>
        <LayoutElement type="0" color="EA0000" x="44" y="216" fixedtext="true" eletype="FX" text="MAX" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="EA0000" x="200" y="216" fixedtext="true" eletype="FX" text="MAX" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="200" y="249" fixedtext="true" eletype="FX" text="bpm" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="45" y="249" fixedtext="true" eletype="FX" text="rpm" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="123" y="125" fixedtext="true" eletype="FX" text="SPEED (KM/H)" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="0000FF" x="55" y="124" fixedtext="true" eletype="FX" text="AVG  M" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="0000FF" x="48" y="291" fixedtext="true" eletype="FX" text="AVG " font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="0000FF" x="202" y="291" fixedtext="true" eletype="FX" text="AVG " font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="0080FF" x="191" y="124" fixedtext="true" eletype="FX" text="AVG  E" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="86" y="216" fixedtext="true" eletype="FX" text="Dyst." font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="163" y="216" fixedtext="true" eletype="FX" text="Km" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FF0000" x="123" y="69" fixedtext="true" eletype="FX" text="MAX" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="46" y="182" fixedtext="true" eletype="FX" text="Czas Jazdy." font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="200" y="182" fixedtext="true" eletype="FX" text="Czas Ca�ko." font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="121" y="18" fixedtext="true" eletype="FX" text="   Ca�k.SPD   WYSOKOSC      NACHYL      Ca�k.WZN" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="1" color="E9E9E9" x="0" y="216" x2="13" y2="323" eletype="RF" valuetype="FX" radius="0" stroke="10" nr_values="1"/>
        <LayoutElement type="1" color="E9E9E9" x="233" y="216" x2="246" y2="323" eletype="RF" valuetype="FX" radius="0" stroke="7" nr_values="1"/>
        <LayoutElement type="1" color="CAFFF0" x="0" y="216" x2="13" y2="323" eletype="RV" valuetype="CC" radius="0" stroke="10" nr_values="1"/>
        <LayoutElement type="1" color="E9E9E0" x="233" y="216" x2="246" y2="323" eletype="RV" valuetype="HR" radius="0" stroke="7" nr_values="1"/>
        <LayoutElement type="2" replDC="CAFFF0" valDC00="950" colDC00="330066" hideDC00="false" valDC01="900" colDC01="800000" hideDC01="false" valDC02="850" colDC02="CC0000" hideDC02="false" valDC03="800" colDC03="FF0000" hideDC03="false" valDC04="750" colDC04="FF8000" hideDC04="false" valDC05="700" colDC05="8080FF" hideDC05="false" valDC06="650" colDC06="00FFFF" hideDC06="false" valDC07="600" colDC07="00FF40" hideDC07="false" valDC08="550" colDC08="FFFF00" hideDC08="false" invertcolor="false"/>
        <LayoutElement type="2" replDC="E9E9E0" valDC00="1900" colDC00="800000" hideDC00="false" valDC01="1710" colDC01="800000" hideDC01="false" valDC02="1520" colDC02="FF0000" hideDC02="false" valDC03="1330" colDC03="EAA000" hideDC03="false" valDC04="1140" colDC04="0080FF" hideDC04="false" valDC05="950" colDC05="00D200" hideDC05="false" valDC06="550" colDC06="FFFF00" hideDC06="false" invertcolor="false"/>
        <LayoutElement type="1" color="FF000E" x="14" y="9" x2="0" y2="0" eletype="CF" valuetype="GA" radius="8" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="FF000E" valDC00="40" colDC00="00A800" hideDC00="false" valDC01="30" colDC01="00FC00" hideDC01="false" valDC02="20" colDC02="E86224" hideDC02="false" valDC03="10" colDC03="F80000" hideDC03="false" invertcolor="false"/>
        <LayoutElement type="3" text="----------------- Seperator ------------------"/>
        <LayoutElement type="0" color="000000" x="123" y="258" fixedtext="true" eletype="FX" text="ZONE BAR" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="1" color="E9E9E9" x="75" y="270" x2="90" y2="322" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="E9E9E9" x="91" y="270" x2="106" y2="322" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="E9E9E9" x="107" y="270" x2="122" y2="322" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="E9E9E9" x="123" y="270" x2="138" y2="322" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="E9E9E9" x="139" y="270" x2="154" y2="322" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="E9E9E9" x="155" y="270" x2="170" y2="322" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="E9E9E0" x="75" y="270" x2="90" y2="322" eletype="RV" valuetype="P0" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="E9E9E1" x="91" y="270" x2="106" y2="322" eletype="RV" valuetype="P1" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="E9E9E2" x="107" y="270" x2="122" y2="322" eletype="RV" valuetype="P2" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="E9E9E3" x="123" y="270" x2="138" y2="322" eletype="RV" valuetype="P3" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="E9E9E4" x="139" y="270" x2="154" y2="322" eletype="RV" valuetype="P4" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="E9E9E5" x="155" y="270" x2="170" y2="322" eletype="RV" valuetype="P5" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="E9E9E0" valDC00="1000" colDC00="FFFF00" hideDC00="false" valDC01="1" colDC01="FFFF00" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="2" replDC="E9E9E1" valDC00="1000" colDC00="00D200" hideDC00="false" valDC01="1" colDC01="00D200" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="2" replDC="E9E9E2" valDC00="1000" colDC00="0080FF" hideDC00="false" valDC01="1" colDC01="0080FF" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="2" replDC="E9E9E3" valDC00="1000" colDC00="EAA000" hideDC00="false" valDC01="1" colDC01="EAA000" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="2" replDC="E9E9E4" valDC00="1000" colDC00="FF0000" hideDC00="false" valDC01="1" colDC01="FF0000" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="2" replDC="E9E9E5" valDC00="1000" colDC00="800000" hideDC00="false" valDC01="1" colDC01="800000" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="80" y="304" fixedtext="false" eletype="P0" text="$V" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="15"/>
        <LayoutElement type="0" color="000000" x="97" y="304" fixedtext="false" eletype="P1" text="$V" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="25"/>
        <LayoutElement type="0" color="000000" x="114" y="304" fixedtext="false" eletype="P2" text="$V" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="10"/>
        <LayoutElement type="0" color="000000" x="130" y="304" fixedtext="false" eletype="P3" text="$V" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="18"/>
        <LayoutElement type="0" color="000000" x="145" y="304" fixedtext="false" eletype="P4" text="$V" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="13"/>
        <LayoutElement type="0" color="000000" x="162" y="304" fixedtext="false" eletype="P5" text="$V" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="19"/>
        <LayoutElement type="0" color="000000" x="87" y="266" fixedtext="false" eletype="HZ" text="$V z" font="TINY" halignment="1" precision="1" nr_values="1" sampletext="4"/>
        <LayoutElement type="0" color="000000" x="151" y="266" fixedtext="false" eletype="TE" text="$VT.E" font="TINY" halignment="1" precision="1" nr_values="1" sampletext="4.2"/>
        <LayoutElement type="0" color="000000" x="75" y="0" fixedtext="false" eletype="TM" text="$V�C" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="18.4"/>
        <LayoutElement type="2" replDC="F8F8F6" valDC00="500" colDC00="0000A0" hideDC00="false" valDC01="10" colDC01="0000A0" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="2" replDC="F8F8F5" valDC00="530" colDC00="00FF40" hideDC00="false" valDC01="200" colDC01="00FF40" hideDC01="false" valDC02="199" colDC02="FF8080" hideDC02="false" valDC03="1" colDC03="FF8080" hideDC03="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="241" y="39" fixedtext="true" eletype="FX" text="M" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="51" y="39" fixedtext="true" eletype="FX" text="M" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
    </DIYLayout>
    Regards
  • Hi
    Do you mean the special characters? I corrected to designer to read/write correctly as UTF8. Please edit the special characters, and it will be ok in the future..
    There was a problem with storing speical characters in the designer before, this is fixed now.
    Please remove special characters from filename!
    regards
    Erich
  • I could load it with no problems, but your special characters "Ca?k SPD) got lost during up- and download in this forum.
    You should upload your zipped XML file, so we can check.
