HMs DIY #1-6
Store Link
Because I want to keep this datafield and the app free for use I would be very grateful about a small donation to PayPal
A detailed description of how to use it can be found here:
HMs_DIY_GUIDANCE.pdf
HMs_DIY_ANLEITUNG.pdf
Thanks very much to mcinner1 for putting so much time into this documentation!
Designer download
You can contribute on my github page.
You can upload your layout so others can use it as well.
Also any changes to the fonts.txt can be updated there as well.
Garmin_HMsDIY
RELEASE NOTES
3.6.2
* switched to new SDK 7.2.1
* added devices: Approach S7 42mm, Descent Mk3 43mm /Mk3i 43mm, Descent Mk3i 51mm, Edge 1050, epix Pro Gen2 42mm, epix Pro Gen2 47mm / quatix 7 pro, epix Pro Gen2 51mm / D2 mach 1 pro / tactix 7
Fenix 7 Pro, Fenix 7 Pro Solar, Fenix 7S Pro, Fenix 7X Pro, Fenix 7xPro Solar, Forerunner 165, Forerunner 165M, Venu 3, Venu 3S, Vivoactive 5
3.5.1
* switched to new SDK 4.2.4
* added devices: FR265, FR265S, FR965, GPSMAP 67/67i, Marq (Gen 2), Marq (Gen 2) Aviator, EDGE 540, EDGE 840, Instinct 2x Solar
* added two new font types GLANCE, GLANCENR (only available if device supports it!)
for full releasenotes see: releasenotes.txt
  • Changed it back, until I find a better working solution....
  • New version 2.6.1 is available on clone #4
    http://public.stattegg.info/HM_DIYD_2.6.0.zip
    2.6.1 (datafield only)
    * fixed crash when using ant running dynamics fields on devices that dont support them
    2.6.0
    * VAM total avg calculation reverted to first implementation
    * new values: ANT device types: BikePower, FitnessEquipment, RunningDynamics
    * added some safety checks for ant devices
  • Just for fun, I counted the number of available values. There are now 167 different values available ((-:
  • ...and today it is 5 months that you released the first version!
    Truly remarkable!
    Many thanks for that fantastic work!
  • Hi There, I have a DIY field that uses only the bottom half part of the edge1030 screen, but when I load it, select the 2 fields layout in the edge1030, and choose the DIY field for the bottom one, nothing is shown.
    Am I missing something?
    thank you
  • Hi
    Did you design the layout in the bottom half of the designer? Coordinates are absolute in the designer!
    regards
    Erich
  • Yes I did
    Please see code below:
    <?xml version="1.0" encoding="UTF-8"?>
    <DIYLayout>
        <Device name="Edge 1030"/>
        <LayoutElement type="1" color="FFFFFF" x="0" y="235" x2="282" y2="470" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="3" text="***   DATAFIELD LINES   ***"/>
        <LayoutElement type="3" text="*** Power Bars (325-395 px) ***"/>
        <LayoutElement type="1" color="000000" x="0" y="235" x2="282" y2="255" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="141" y="236" fixedtext="true" eletype="AS" text="POWER" font="TINY" halignment="1" precision="1" nr_values="1" sampletext="34.76"/>
        <LayoutElement type="3" text="***  Z0 (0-10w) ***"/>
        <LayoutElement type="3" text="***  Z1 (10-144w) ***"/>
        <LayoutElement type="1" color="C0C0C1" x="0" y="255" x2="47" y2="355" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="C0C0C1" x="0" y="255" x2="47" y2="355" eletype="RV" valuetype="S1" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C0C1" valDC00="1000" colDC00="C0C0C0" hideDC00="false" valDC01="1" colDC01="C0C0C0" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="24" y="320" fixedtext="false" eletype="H1" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="2560"/>
        <LayoutElement type="0" color="000000" x="24" y="260" fixedtext="false" eletype="S1" text="$V%" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="15"/>
        <LayoutElement type="3" text="*** Z2 (144-197w) ***"/>
        <LayoutElement type="1" color="38C8F8" x="47" y="255" x2="94" y2="355" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="38C8F8" x="47" y="255" x2="94" y2="355" eletype="RV" valuetype="S2" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="38C8F8" valDC00="1000" colDC00="38C8F9" hideDC00="false" valDC01="1" colDC01="38C8F9" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="72" y="320" fixedtext="false" eletype="H2" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="1825"/>
        <LayoutElement type="0" color="000000" x="72" y="260" fixedtext="false" eletype="S2" text="$V%" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="20"/>
        <LayoutElement type="3" text="***Z3 (197-236w) ***"/>
        <LayoutElement type="1" color="80FF80" x="94" y="255" x2="141" y2="355" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="80FF80" x="94" y="255" x2="141" y2="355" eletype="RV" valuetype="S3" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="80FF80" valDC00="1000" colDC00="00FF40" hideDC00="false" valDC01="1" colDC01="00FF40" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="118" y="320" fixedtext="false" eletype="H3" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="2190"/>
        <LayoutElement type="0" color="000000" x="118" y="260" fixedtext="false" eletype="S3" text="$V%" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="17"/>
        <LayoutElement type="3" text="*** Z4 (236-275w) ***"/>
        <LayoutElement type="1" color="FF8041" x="141" y="255" x2="188" y2="355" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF8041" x="141" y="255" x2="188" y2="355" eletype="RV" valuetype="S4" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="FF8041" valDC00="1000" colDC00="FF8040" hideDC00="false" valDC01="1" colDC01="FF8040" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="166" y="320" fixedtext="false" eletype="H4" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="1260"/>
        <LayoutElement type="0" color="000000" x="166" y="260" fixedtext="false" eletype="S4" text="$V%" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="3"/>
        <LayoutElement type="3" text="*** Z5 (275-415w) ***"/>
        <LayoutElement type="1" color="FF0001" x="188" y="255" x2="235" y2="355" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0001" x="188" y="255" x2="235" y2="355" eletype="RV" valuetype="S5" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="FF0001" valDC00="1000" colDC00="FF0000" hideDC00="false" valDC01="1" colDC01="FF0000" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="212" y="320" fixedtext="false" eletype="H5" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="1210"/>
        <LayoutElement type="0" color="000000" x="212" y="260" fixedtext="false" eletype="S5" text="$V%" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="19"/>
        <LayoutElement type="3" text="*** Z6 (415-1200w) ***"/>
        <LayoutElement type="1" color="FF00F1" x="235" y="255" x2="282" y2="355" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF00F1" x="235" y="255" x2="282" y2="355" eletype="RV" valuetype="S6" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="FF00F1" valDC00="1000" colDC00="FF00FF" hideDC00="false" valDC01="1" colDC01="FF00FF" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="260" y="320" fixedtext="false" eletype="H6" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="721"/>
        <LayoutElement type="0" color="000000" x="260" y="260" fixedtext="false" eletype="S6" text="$V%" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="1"/>
        <LayoutElement type="3" text="*** HR Bars (400-470 px) ***"/>
        <LayoutElement type="1" color="000000" x="0" y="355" x2="282" y2="375" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="141" y="356" fixedtext="true" eletype="AS" text="HR" font="TINY" halignment="1" precision="1" nr_values="1" sampletext="34.76"/>
        <LayoutElement type="3" text="***   Zone 1 ***"/>
        <LayoutElement type="1" color="C0C0C1" x="1" y="375" x2="57" y2="470" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="C0C0C1" x="1" y="375" x2="57" y2="470" eletype="RV" valuetype="P1" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="28" y="380" fixedtext="false" eletype="P1" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="25"/>
        <LayoutElement type="0" color="000000" x="28" y="440" fixedtext="false" eletype="T1" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="425"/>
        <LayoutElement type="3" text="***   Zone 2   ***"/>
        <LayoutElement type="1" color="38C8F9" x="57" y="375" x2="113" y2="470" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="38C8F9" x="57" y="375" x2="113" y2="470" eletype="RV" valuetype="P2" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="38C8F9" valDC00="1000" colDC00="38C8F8" hideDC00="false" valDC01="1" colDC01="38C8F8" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="85" y="380" fixedtext="false" eletype="P2" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="10"/>
        <LayoutElement type="0" color="000000" x="85" y="440" fixedtext="false" eletype="T2" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="528"/>
        <LayoutElement type="3" text="***   Zone 3 ***"/>
        <LayoutElement type="1" color="00F501" x="113" y="375" x2="169" y2="470" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="00F501" x="113" y="375" x2="169" y2="470" eletype="RV" valuetype="P3" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="00F501" valDC00="1000" colDC00="00F500" hideDC00="false" valDC01="1" colDC01="00F500" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="141" y="380" fixedtext="false" eletype="P3" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="18"/>
        <LayoutElement type="0" color="000000" x="141" y="440" fixedtext="false" eletype="T3" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="719"/>
        <LayoutElement type="3" text="***   Zone 4   ***"/>
        <LayoutElement type="1" color="FF8041" x="169" y="375" x2="225" y2="470" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF8041" x="169" y="375" x2="225" y2="470" eletype="RV" valuetype="P4" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="197" y="380" fixedtext="false" eletype="P4" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="13"/>
        <LayoutElement type="0" color="000000" x="197" y="440" fixedtext="false" eletype="T4" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="126"/>
        <LayoutElement type="3" text="***   Zone 5   ***"/>
        <LayoutElement type="1" color="FF80C1" x="225" y="375" x2="281" y2="470" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF80C1" x="225" y="375" x2="281" y2="470" eletype="RV" valuetype="P5" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="FF80C1" valDC00="1000" colDC00="FF80C0" hideDC00="false" valDC01="1" colDC01="FF80C0" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="253" y="380" fixedtext="false" eletype="P5" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="19"/>
        <LayoutElement type="0" color="000000" x="253" y="440" fixedtext="false" eletype="T5" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="621"/>
        <LayoutElement type="3" text="***   FIN   ***"/>
    </DIYLayout>
  • Every layout has to be startet at 0/0 in the designer - regardless where the datafield is situated on your display.
    Find here your code - moved to the right place.
    (I wrote a small program to do this work)
    <DIYLayout>
        <LayoutElement type="1" color="FFFFFF" x="0" y="0" x2="282" y2="235" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="0" x2="282" y2="20" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="141" y="1" fixedtext="true" eletype="AS" text="POWER" font="TINY" halignment="1" precision="1" nr_values="1" sampletext="34.76"/>
        <LayoutElement type="1" color="C0C0C1" x="0" y="20" x2="47" y2="120" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="C0C0C1" x="0" y="20" x2="47" y2="120" eletype="RV" valuetype="S1" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="24" y="85" fixedtext="false" eletype="H1" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="2560"/>
        <LayoutElement type="0" color="000000" x="24" y="25" fixedtext="false" eletype="S1" text="$V%" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="15"/>
        <LayoutElement type="1" color="38C8F8" x="47" y="20" x2="94" y2="120" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="38C8F8" x="47" y="20" x2="94" y2="120" eletype="RV" valuetype="S2" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="72" y="85" fixedtext="false" eletype="H2" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="1825"/>
        <LayoutElement type="0" color="000000" x="72" y="25" fixedtext="false" eletype="S2" text="$V%" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="20"/>
        <LayoutElement type="1" color="80FF80" x="94" y="20" x2="141" y2="120" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="80FF80" x="94" y="20" x2="141" y2="120" eletype="RV" valuetype="S3" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="118" y="85" fixedtext="false" eletype="H3" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="2190"/>
        <LayoutElement type="0" color="000000" x="118" y="25" fixedtext="false" eletype="S3" text="$V%" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="17"/>
        <LayoutElement type="1" color="FF8041" x="141" y="20" x2="188" y2="120" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF8041" x="141" y="20" x2="188" y2="120" eletype="RV" valuetype="S4" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="166" y="85" fixedtext="false" eletype="H4" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="1260"/>
        <LayoutElement type="0" color="000000" x="166" y="25" fixedtext="false" eletype="S4" text="$V%" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="3"/>
        <LayoutElement type="1" color="FF0001" x="188" y="20" x2="235" y2="120" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0001" x="188" y="20" x2="235" y2="120" eletype="RV" valuetype="S5" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="212" y="85" fixedtext="false" eletype="H5" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="1210"/>
        <LayoutElement type="0" color="000000" x="212" y="25" fixedtext="false" eletype="S5" text="$V%" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="19"/>
        <LayoutElement type="1" color="FF00F1" x="235" y="20" x2="282" y2="120" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF00F1" x="235" y="20" x2="282" y2="120" eletype="RV" valuetype="S6" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="260" y="85" fixedtext="false" eletype="H6" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="721"/>
        <LayoutElement type="0" color="000000" x="260" y="25" fixedtext="false" eletype="S6" text="$V%" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="1"/>
        <LayoutElement type="1" color="000000" x="0" y="120" x2="282" y2="140" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="141" y="121" fixedtext="true" eletype="AS" text="HR" font="TINY" halignment="1" precision="1" nr_values="1" sampletext="34.76"/>
        <LayoutElement type="1" color="C0C0C1" x="1" y="140" x2="57" y2="235" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="C0C0C1" x="1" y="140" x2="57" y2="235" eletype="RV" valuetype="P1" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="28" y="145" fixedtext="false" eletype="P1" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="25"/>
        <LayoutElement type="0" color="000000" x="28" y="205" fixedtext="false" eletype="T1" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="425"/>
        <LayoutElement type="1" color="38C8F9" x="57" y="140" x2="113" y2="235" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="38C8F9" x="57" y="140" x2="113" y2="235" eletype="RV" valuetype="P2" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="85" y="145" fixedtext="false" eletype="P2" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="10"/>
        <LayoutElement type="0" color="000000" x="85" y="205" fixedtext="false" eletype="T2" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="528"/>
        <LayoutElement type="1" color="00F501" x="113" y="140" x2="169" y2="235" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="00F501" x="113" y="140" x2="169" y2="235" eletype="RV" valuetype="P3" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="141" y="145" fixedtext="false" eletype="P3" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="18"/>
        <LayoutElement type="0" color="000000" x="141" y="205" fixedtext="false" eletype="T3" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="719"/>
        <LayoutElement type="1" color="FF8041" x="169" y="140" x2="225" y2="235" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF8041" x="169" y="140" x2="225" y2="235" eletype="RV" valuetype="P4" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="197" y="145" fixedtext="false" eletype="P4" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="13"/>
        <LayoutElement type="0" color="000000" x="197" y="205" fixedtext="false" eletype="T4" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="126"/>
        <LayoutElement type="1" color="FF80C1" x="225" y="140" x2="281" y2="235" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF80C1" x="225" y="140" x2="281" y2="235" eletype="RV" valuetype="P5" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="253" y="145" fixedtext="false" eletype="P5" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="19"/>
        <LayoutElement type="0" color="000000" x="253" y="205" fixedtext="false" eletype="T5" text="$m:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="621"/>
    </DIYLayout>
  • Nice, it worked llike a charm.... and saved me some work
    thank you!
