Hi guys!
After update 12.23 gps track has been disappointingly inaccurate.
Before update gps track was incredibly smooth!
What do you think?
Maybe opaque autumn clouds?
On pic below: after update and before.
Hi guys!
What do you think?
All,
After reviewing the information provided (in this thread and via email) by many of you, I am having a difficult time finding examples of when the watch is recording a GPS position outside of the 3…
In addition to my comment below, we would like to know if any of you are experiencing the symptoms mentioned in:
Not maintaining GPS Lock in GPS Only mode
If so, please comment on that thread.
All,
We have had various GPS improvements since the 12.23 update. After updating to 13.15 (which is the current beta software), are any of you seeing GPS issues either during your recorded activity or…
Then I’m not crazy. I am losing my mind, to understand, as it is possible, that a watch of this kind, does worse, than a watch, much cheaper and with less GPS systems! Today I tried again, with all systems…
Hi Kevin, after updating to 13.21 nothing changes:
Run on 22.11.22 at 19:08 SW:13.21 GPS: Smart; GPS-mode: auto-select, Problem at Minute 1:30-2:00
I suspect we're seeing two different things here.
There is undoubtedly GPS jamming in evidence in the tracks recorded in Moscow. They're accurate until they pass close to certain landmarks, then become…
there is no gps jam. I have the same problem. Recently used my old fenix 5 and there is no problems with gps near points where FR955 has now. First 5-10 minutes GPS corrupting, but then it becomes smooth and accurate.
Do you always start from the same place? What happens if you start your activity in a different place?
I have gotten F955 replacing my F6 Pro two weeks ago, with latest firmware 12.23 installled, dual-band GNSS provides pretty accurate GPS compared to my previous F6Pro, even I looped on a straight 600m road, with tall trees for 10 loops, it's just a straight line compared to wavy lines recorded previously
What's building or structure near the wavy lines, is there a telecommunication tower, power station affecting GPS signal? Just wonder ...
Same problem in the Fenix7 after 10.xx firmware and 2.37 GPS software.
In my case both F7 and FR955 works well for some sports and bad for others. Still no solution.
forums.garmin.com/.../inaccurate-gps-tracking-with-latest-firmwares
What if you set your GPS to All+Multiband (best accuracy) instead of All System (better accuracy)?
As All System is smart to determine when to use multiband and when is not.
Always the same scenario. plus/minus...
But I have spotted that period of corruption became shorter than before. Hope that Garmin IT on the right way. It's all really sad becouse of I had perfect track recording before 12.23.
Multiband often makes it even worse.
My previous F6 Pro always give me GPS problem (F5 and F3HR too especially near tall buildings), I am not sure if the metal or Fenix series and GPS not working ?
Since switching to F955 with firmware 12.23 (not update to 14.xx), the multi-band GNSS is pretty accurate
Mine is also good for running. But terrible when using water sports profiles.
