Since I got my 955, I cannot edit the percentages of heart rate zones. It allow me to enter a value but never saved.
Same behavior from the watch, and from Garmin Connect mobile.
Anybody else with same behavior ?
Thanks.
Thanks.
All,
We do have some other reports of this and are currently investigating. When we know more, I'll be sure to post updates to this thread.
All,
We believe that we have a fix for this report that will be rolling out with the next software release for this device. While I do not have a timetable for this release, I will be updating this thread…
All,
We are in the process of releasing 12.23 production software. If you experience this battery drain after installing the 12.23 sw update, please start a new thread.
Oh for sure, just confirming it's indeed a bug...
It seems to use the base zones btw, editing those also seems to edit the running ones. So that might be a workaround (maybe need to remove the running…
I have had the same issue. I eventually managed to get my inputs to save (I turned off auto-detect Max HR which may have made the difference, I'm not sure) however my HR guage is tracking incorrectly despite my zones appearing to be saved, and the data post-run is wrong. If I look at my run from yesterday, even though the zones appear saved and it should show the whole run in z1 and z2, it shows the run in z2 and z3 instead..
Needless to say this is a very irritating issue as it throws off recovery estimates, training load etc..
Exactly the same issue. Tempo run the other day was apparently entirely in zone 5...
After a run today, I accepted a new MHR and that screwed up all the zones again. Specifically, the 255M auto created a Running Sport Zone which was based on HRR (I was using default zones and had no other Sport HRs setup) and switched my default zones to from Based on BPM to Based on %HRR. This is so frustrating that I'm going back to my 245 in order to run in my %HRR zones. I'm just too tired of completing RPE 3-5 runs in Zones 4-5 and the 255M telling me 'low aerobic shortage'.
All,
We believe that we have a fix for this report that will be rolling out with the next software release for this device. While I do not have a timetable for this release, I will be updating this thread as information is made available. Thank you for your patience while we work toward a resolution for this report.
