Since I got my 955, I cannot edit the percentages of heart rate zones. It allow me to enter a value but never saved.
Same behavior from the watch, and from Garmin Connect mobile.
Anybody else with same behavior ?
Thanks.
Thanks.
All,
We do have some other reports of this and are currently investigating. When we know more, I'll be sure to post updates to this thread.
All,
We believe that we have a fix for this report that will be rolling out with the next software release for this device. While I do not have a timetable for this release, I will be updating this thread…
All,
We are in the process of releasing 12.23 production software. If you experience this battery drain after installing the 12.23 sw update, please start a new thread.
Oh for sure, just confirming it's indeed a bug...
It seems to use the base zones btw, editing those also seems to edit the running ones. So that might be a workaround (maybe need to remove the running…
It seems to use the base zones btw, editing those also seems to edit the running ones. So that might be a workaround (maybe need to remove the running entry and re-add it after seeing default zones)
same here...
i also have the 955 and are not able to set it up right.
on the 945 i used %LDHS for running and cycling.
if is switsch to use BPM on cycling (standard %LDHS) and try to change the values the highest i can select is 113bpm.
same here...
Same here also, can’t understand why something as important as HR wasn’t tested when the watch went into production. Doesn’t expect this from a high end Forerunner but hopefully they fix it soon.
