If anybody is curious about the new Track Run app in the latest beta, I got myself down to an actual track and gave it a go.
Here is what I found https://www.youtube.com/watch?v=AOzCGeUi_1I
Must say was impressed by the results.
extensive track run testing:
i even headed a few times towards the outside of the track (8th lane) in order to grab the water - all good
I just came from my first run using track mode (the actual update, not beta) and I couldn't be more disappointed. It just sucked, period. I don't have issues with GPS, and I've ran millions of times in…
I reached out to you via Direct Message at basically the same time these posts were being made; before you try deleting that calibration file, can you follow the steps I sent you in the DM? Ultimately…
I know one needs to calibrate a track by starting and stopping an activity of at least two laps to teach the watch what the track is like. Does this mean that every track activity needs to start and stop on the actual track?
Reason for asking is that I typically run from home to the track to warm-up and also run back as part of my cool down. Normally I capture all of this goodness in one activity. I don't really like to have a bunch of separate activities in my overview. So I wonder whether this is possible in Track mode as well, after the watch has learned the track obviously.
Not quite sure about that - I have to test it.
I meant only that first run at each of new location is needed for track calibration. Yesterday I made 3 runs on a stadium track using the Track Run. The first run make the shape of track as it was before at standard run, but the second run drawn perfectly good shape and counted 400m for each lap. I made exactly 16 stadium laps and got 6400m - not less, not more.
I have to test what will happen when I start off track and after some time I will go on it. I think the Track Run must be started at the saved stadium location to recognize it properly.
