We have escalated this issue to our engineers but we need any user experiencing this to reach out to our Product Support team directly. This can be done via support.garmin.com. We will gladly work with…
This is an issue that is actively being investigated by the engineering teams responsible for the Forerunner 945. We will be closing this thread as this is not an issue we can solve remotely via the forums…
A $600 watch should have buttons that respond in a way in which the user can tell that the press was registered, whatever that means. In this particular case, if I'm running and press the lap key, I shouldn…
I would buy this one, but after reading a lot of post with this problem, knowing that it is not sort it out. Do you recomend that i pay 600€ if i will have to call to suppot? really, i dont know what will…
hi, no harm done much to learn for everybody
try and edit your post...could work
or the topic starter could reject your solution ....I guess
happy sporting
ps
would you have noticed the button thingy when not for this forum thread ?
Just for talking... once, i teared down my old Fenix 5 since warranty was over and i tried to understand why some buttons had different response than others; once i opened the watch i tried to press all the buttons and i saw that someone had less play than others so, i loosened motherboard screws and i clearly saw that it was misaligned compared to the buttons; i aligned it, tightened screws and voilà: all buttons "clicks" ware perfectly fine! I think this is the problem with all strange buttons behaviours...
I don't know... i have never opened a 935/945 because they haven't any screw outside...
Watch is a few days old. Buttons overall feel harder to press(than previous Garmin watch) and do exhibit some minor stickiness, but okay for me except the Back button. I go to press sometimes and don't hear click or feel the button actuate. However the press does usually register.
I turned on Key Vibe and that helps.
