We have escalated this issue to our engineers but we need any user experiencing this to reach out to our Product Support team directly. This can be done via support.garmin.com. We will gladly work with…
This is an issue that is actively being investigated by the engineering teams responsible for the Forerunner 945. We will be closing this thread as this is not an issue we can solve remotely via the forums…
A $600 watch should have buttons that respond in a way in which the user can tell that the press was registered, whatever that means. In this particular case, if I'm running and press the lap key, I shouldn…
I would buy this one, but after reading a lot of post with this problem, knowing that it is not sort it out. Do you recomend that i pay 600€ if i will have to call to suppot? really, i dont know what will…
bakewell, :)
as I see it
you have a "down" button that works like it should and all others are sticky :p
You say two clicks is correct behavior? NAW...
Same here. Have the 945 as of yesterday and I much prefer the buttons on my 935
thomasclowes, I would not care about one or two click function
post #33 and #34 should explain the crux of the matter for FR945 buttons
as I see it : sticky button or mushy button
when pressing a button it has(gives) a tactile response so you note having pressed the button
this tactile response disappears after pressing a button
pressing again you get no tactile respons
after waiting a while the tactile response can return
