2.4Ghz Wifi 0200 error
Hi,
I try to use my 2.4Ghz wifi network for downloading my Spotify play list to my VA4. Despite the Wifi test in the Garmin Connect app succeeds everytime I try to download my play list, a system update or to attempt to connect to my wifi network from within the wifi settings of my VA4 I am getting a wifi 0200 error. I tried to change the wifi mode in my router from mixed to 802.11n, g and b. But that did not help. The ssid is broadcasted and the router that I have is a LinkSys EA8500.
The firmware version of my VA4 is 3.40.
Can someone help me?
Regards,
Chris.
    0 Former Member in reply to Michel
    Works for me too! (Vivoactive 4S)
    (Although transferring an 80 track playlist just ate 10% battery Wink)
    0 Former Member in reply to Former Member
    The file we are suppose to "save as", when I click on the link, its just wall of text on my PC.  Is that what we are suppose to be saving?  Also, when I connect my 645M to my PC, I get a primary folder and a media folder.  Both have "Garmin" folders in them.  Which one am I suppose to do?  I tried the primary one already and when I disconnected my watch, nothing installed.  Any help?
  • This file contains root CA SSL certificates (has something to do with security and trusted certificate authorities) . So I guess the root CA certificates installed on the watch got some problems or missed some root certificate authorities
    EDIT: Save file as page source. Work around fixed the problem!!
    Still getting the 0200 error. Installed the .crt file via Mac. (Vivoactive 4)
    Also rebooted the device, no change.
    ok thanks.  But when I open it in google chrome, it pages of just text.  That is what is suppose to be coming up right?  And then I just save that page as the file name directed in the instructions?  Then what file do I put it in on my watch?  When connected, I have both "primary" and "media" folders.  Both of which have a "Garmin" folder in them.  Thanks for the help.  Really hoping to get this working.  BTW, I have tried putting it in both of those folders and its not working.  That's what Im concerned with the file I am saving and if I am doing that right.
    work around works for me!
    volume settings doesnót work though. Waiting for the next update Slight smile
    I had only 1 Garmin folder on my Venu. The file was located in the root of the watch storage. Perhaps it's different for other watches.
    After I placed the file there, I disconnected my watch expecting some sort of feedback, but there was no special message. I connected my watch again to my computer and when I looked in the Garmin folder, the the file disappeared. I disconnected the watch again, started a sync with Spotify and it worked.
    Hmm yeah it's not working here.  I just want to make sure I am saving the file correctly.  When you clicked on the link, it took you to a separate web browser and it was just page of text.  I clicked save as and named it the file we are suppose.  Does that sound right for you?  Just want to make sure I am doing that right at least.
    Other than that, I have no idea about my two options that I have when I click on my watch.  I have tried placing it in the "Garmin" folder that resides in both sections, "primary" and "media".  Individually and both together.  Still nothing.  I am so tired of this.  This is the main function I wanted out of this watch and Garmin is failing at that.
    Unbelievable .... today I left Holland and now abroad it is working. I can synchronise a playlist to my Garmin Fenix 6. Synchronising my watch over WIFI is also working now.
