2.4Ghz Wifi 0200 error
Hi,
I try to use my 2.4Ghz wifi network for downloading my Spotify play list to my VA4. Despite the Wifi test in the Garmin Connect app succeeds everytime I try to download my play list, a system update or to attempt to connect to my wifi network from within the wifi settings of my VA4 I am getting a wifi 0200 error. I tried to change the wifi mode in my router from mixed to 802.11n, g and b. But that did not help. The ssid is broadcasted and the router that I have is a LinkSys EA8500.
The firmware version of my VA4 is 3.40.
Can someone help me?
Regards,
Chris.
    0 Former Member over 5 years ago
    Same here on my Garmin Fenix 6 Sapphire .... error 200 message ... can't find wifi network
    Contacted Garmin on twitter I got the following response after a few days:
    Good morning. Our engineers are currently investigating an issue with WiFi on these devices. I would be more than happy to add you to the case. Being added to the case means we’ll be able to see how many customers are being affected by this problem. It will also allow us to email you once this has been resolved. Unfortunately, we don’t have an ETA on when this will be fixed.
    If you would like to be added to the case place respond with the following:
    • The email address on your account
    • The serial number of your device
    • The software version on your device
    • Do our engineers have permission to sign in to your account? (we will not need your password)
  • It is worrying that this is taking this long. I was determined to keep the watch but with my return window coming to an end soon it just seems dumb to take the risk. I chose this watch for the music capabilties and this is almost nullified right now because of the WiFi problem.
  • Same issue here. Fenix 6 Pro 47mm.
    Hier hetzelfde probleem
    Incoming software update, according to connect.garmin.com website:
    vivoactive 4 Small, version 3.50
    Currently synchronizing through the Mobile app...
    Edit: not solved, unfortunately
    Same problem here. Just bought Vivoactive 4s and unable to connect. Hopefully Garmin wil fix it soon otherwise I will return it.
    0 Former Member over 5 years ago in reply to Former Member
    Just updated to fw3.50. Unfortunately the issue still persists.
