I'm unable to pair the new Speed Sensor 2 in Garmin Connect Mobile, tried both Android and iOS phones. However, I was able to pair it on fenix and Edge devices in both BLE and ANT modes. Any help?
We believe this was resolved in a recent update. Please reply to this post if you are still unable to pair your Speed Sensor 2.
Is garmin support reading this forum? It’s unbelievable that after 2 years there are still the same pairing and data transmission issues!
Iphone 6s ios 14.2
app Garmin connect 4.37.1.5
Speed sensor…
Hi, I found out that my Speed Sensor was unable to pair but had a lot of automatically recorded activities stored. Whenever I tried to pair, it was unsuccessful but transferred a few activities to Garmin…
Same issue. It shows up in the device list but says attention required and won't pair. Transmits data too but I can't get to any of the settings.
I can't get mine to pair in Connect on Android either. It starts to pair and then fails.
Exactly same issue. It actually pairs to the phone fine but Connect says it failed. What gives?
Exactly the same issue
Is your actually visible as one of your devices? Mine isn't visible.
Yes it appears in Bluetooth devices as connected but Connect says it can’t pair due to a ‘problem’
Same issue. Came here looking for the answer. Connects to phone. Shows in BT list. Garmin connect says pairing failed. Rebooted etc. Waited 2 weeks. No joy
Well, new update for Garmin Connect on iOS - still broken.
Does anyone from Garmin monitor these forums?
I've already discussed this with Garmin support, after several suggestions and actions I've sent them diagnostics logs from the app, so let's see what they come with.
Thank you, excellent
