Battery drain is horrendous after the 13.10 update! The battery drained 20% in 1 hour with no activities being recorded. I tried reset to factory settings. See how that goes. Very poor update. Garmin Fenix S Pro here.
For years I've always found my watch will drain battery faster than usual (forerunners and now Fenix). A few years back, after trial and error, I've found that after new update, if I switch off the watch…
I solved this issue according to this recommendation. Removing related file solved it, now I have magnificent battery life as far as I tested. In 24 hours with 1.5 hour running activity + heart rate sensor…
Same for me. The update went fine. Suddenly after charging the fenix, I do have a battery drain: 30% during the night in battery mode. Normal was 1-2%. It is strange because the update was a few weeks…
Replacement works great guys, it seems it is a hardware issue. Only one day of use will report back in one week.
Hi, i have Bluetooth OFF, no phone connection, so it doesn't make sense to do anything on phone. But thank you.
Same for me. The update went fine. Suddenly after charging the fenix, I do have a battery drain: 30% during the night in battery mode. Normal was 1-2%. It is strange because the update was a few weeks ago and I didn’t changed anything.
Has somebody got the same experience?
Same here, lost like 60% overnight and keept draining 10%/h, did a soft reset 3-4 times, no help, and then it went away all by it self anf now all is well..
How long does it took until it went away?
Was there an Update?
I know the topic is for a PRO.
But the ones that have NON PRO have you tested Beta 13.30?
And made it any difference?
F6X: After 2 weeks of charging every couple of days, loosing tens of percent a day, I did a hard reset. I didn't install anything now, only connected to mobile phone, no extra app installed. Loosing 3% per day, I hope problem is solved.
Next I will install the widgets and apps one per day and research... It would be nice to be able to see log file like on mobile phone, to see a number of wake-ups and background processes...
I did some testing on my F6Pro, which I concluded that the battery drain during/post activity was due to BT. Here's the link to the original post, which may be relevant
half a day, tried to reconnect to phone also couple of times, do not know what fixed it eventualy
The strange thing is: the accu drain during an activity is totally normal. But after that I go in battery save mode (BT, Wifi etc. off, no watch face), there is a abnormal drain of 3-5% per hour
