Ticket Created
WERETECH-8553
fenix 6 series firmware 6.0 causes watch face to crash
Hi, fenix 6 series users are reporting a crash while using the MagicDust watch face. (https://apps.garmin.com/en-US/apps/2851d38b-22a8-41b6-84bf-2b0d4a229869)
The crash report leads to the code logic where ActivityMonitor.getInfo().floorsClimbed returns an invalid value.
Error: Invalid Value
Details: 'Failed invoking <symbol>'
Firmware-Version: '6.00'
Language-Code: eng
ConnectIQ-Version: 3.1.7
Filename: A1VE3325 <- strange file name!?
Appname: MagicDust
Repro steps: just install the watch face, and trigger the high power mode with a rotation of your wrist. This seems to cause the crash.
I don't have a fenix 6 device, testing in simulator works perfectly.
On my fenix 5x also everything is fine.
Thanks, for your support.
Please verify this issue, thanks.
TheMagician
Parents
  • Hi, the stack trace location of the error is not listed in the debug.xml. So i used the next matching lines in the debug.xml to get the code location.
    The strange thing is that the lines of code are running stable since at least one year on several devices.
    It could also an issue of the new 3.1.7 SDK.
Comment
Children
  • Hi @ all, here is a workaround for this bug:
    After several refactorings i figured out that accessing several times the same property in ActivityMonitor.getInfo() causes the 'Symbol not found' or 'Invalid Value' exception. (e.g. ActivityMonitor.getInfo().floorsClimbedGoal)
    To fix this just create a local variable that hold the value and use the variable instead.
  • I just hope for a fix from Garmin and pray that my watch face will not get any bad reviews. Wish me luck! :-)
  • If you know the user (they contacted you), suggest they update to the latest firmware.  Other than that, there's not much you can do.
  • Here the firmware list including the "strange" crashes:
    crash in onPowerBudgetExceeded with 'Too Many Arguments Error' or 'Symbol Not Found Error'
    fēnix® 6X Pro / 6X Sapphire / 6X Pro Solar / tactix® Delta Sapphire: 3.10
    fēnix® 6X Pro / 6X Sapphire / 6X Pro Solar / tactix® Delta Sapphire: 3.00
    fēnix® 5S Plus: 7.10
    fēnix® 5 Plus: 7.60, 7.10
    fēnix® 6X Pro / 6X Sapphire / 6X Pro Solar / tactix® Delta Sapphire: 2.20
    fēnix® 5X Plus: 7.60, 8.40
    vívoactive® 3: 6.60, 6.20
    crash in onLayout with Unhandled Exception
    vívoactive® 3: 7.20
    crash in onUpdate in View and GoalView with 'Invalid Value', 'Too Many Arguments Error' and 'Symbol Not Found Error'
    ēnix® 6X Pro / 6X Sapphire / 6X Pro Solar / tactix® Delta Sapphire: 6.00
    fēnix® 6 Pro / 6 Sapphire: 3.00
    fēnix® 6: 2.20
    fēnix® 6 Pro / 6 Sapphire: 2.20
    fēnix® 6S Pro / 6S Sapphire: 6.00
    Puh... my watch seems to be the only one with a stable firmware (5X)
    Please provide some information how to handle this trouble, thanks.
  • Check the FW version in the ERA crashes, as there was/is a bug where things are getting installed on devices with old FW that can cause some odd crashes.
