Ticket Created
WERETECH-8553
fenix 6 series firmware 6.0 causes watch face to crash
Hi, fenix 6 series users are reporting a crash while using the MagicDust watch face. (https://apps.garmin.com/en-US/apps/2851d38b-22a8-41b6-84bf-2b0d4a229869)
The crash report leads to the code logic where ActivityMonitor.getInfo().floorsClimbed returns an invalid value.
Error: Invalid Value
Details: 'Failed invoking <symbol>'
Firmware-Version: '6.00'
Language-Code: eng
ConnectIQ-Version: 3.1.7
Filename: A1VE3325 <- strange file name!?
Appname: MagicDust
Repro steps: just install the watch face, and trigger the high power mode with a rotation of your wrist. This seems to cause the crash.
I don't have a fenix 6 device, testing in simulator works perfectly.
On my fenix 5x also everything is fine.
Thanks, for your support.
Please verify this issue, thanks.
TheMagician
  • The users also reported that they set the goal limits to zero (e.g. steps = 0, floors = 0). There seems to be an issue in the firmware that handles that, because the watch face logic handles the null and 0 values to be save for invalid input.
    The ERA crash reporting also displays a lot of crashes in the goalView.onUpdate class when i access the goal values. In this case (if the user sets the goal to 0) the goal reach event have to be prevented.
  • Hi @ all, here is a workaround for this bug:
    After several refactorings i figured out that accessing several times the same property in ActivityMonitor.getInfo() causes the 'Symbol not found' or 'Invalid Value' exception. (e.g. ActivityMonitor.getInfo().floorsClimbedGoal)
    To fix this just create a local variable that hold the value and use the variable instead.
  • I just hope for a fix from Garmin and pray that my watch face will not get any bad reviews. Wish me luck! :-)
  • If you know the user (they contacted you), suggest they update to the latest firmware.  Other than that, there's not much you can do.
  • Here the firmware list including the "strange" crashes:
    crash in onPowerBudgetExceeded with 'Too Many Arguments Error' or 'Symbol Not Found Error'
    fēnix® 6X Pro / 6X Sapphire / 6X Pro Solar / tactix® Delta Sapphire: 3.10
    fēnix® 6X Pro / 6X Sapphire / 6X Pro Solar / tactix® Delta Sapphire: 3.00
    fēnix® 5S Plus: 7.10
    fēnix® 5 Plus: 7.60, 7.10
    fēnix® 6X Pro / 6X Sapphire / 6X Pro Solar / tactix® Delta Sapphire: 2.20
    fēnix® 5X Plus: 7.60, 8.40
    vívoactive® 3: 6.60, 6.20
    crash in onLayout with Unhandled Exception
    vívoactive® 3: 7.20
    crash in onUpdate in View and GoalView with 'Invalid Value', 'Too Many Arguments Error' and 'Symbol Not Found Error'
    ēnix® 6X Pro / 6X Sapphire / 6X Pro Solar / tactix® Delta Sapphire: 6.00
    fēnix® 6 Pro / 6 Sapphire: 3.00
    fēnix® 6: 2.20
    fēnix® 6 Pro / 6 Sapphire: 2.20
    fēnix® 6S Pro / 6S Sapphire: 6.00
    Puh... my watch seems to be the only one with a stable firmware (5X)
    Please provide some information how to handle this trouble, thanks.
