Ticket Created
WERETECH-8553
fenix 6 series firmware 6.0 causes watch face to crash
Hi, fenix 6 series users are reporting a crash while using the MagicDust watch face. (https://apps.garmin.com/en-US/apps/2851d38b-22a8-41b6-84bf-2b0d4a229869)
The crash report leads to the code logic where ActivityMonitor.getInfo().floorsClimbed returns an invalid value.
Error: Invalid Value
Details: 'Failed invoking <symbol>'
Firmware-Version: '6.00'
Language-Code: eng
ConnectIQ-Version: 3.1.7
Filename: A1VE3325 <- strange file name!?
Appname: MagicDust
Repro steps: just install the watch face, and trigger the high power mode with a rotation of your wrist. This seems to cause the crash.
I don't have a fenix 6 device, testing in simulator works perfectly.
On my fenix 5x also everything is fine.
Thanks, for your support.
Please verify this issue, thanks.
TheMagician
Parents Comment Children
  • Hi @ all, here is a workaround for this bug:
    After several refactorings i figured out that accessing several times the same property in ActivityMonitor.getInfo() causes the 'Symbol not found' or 'Invalid Value' exception. (e.g. ActivityMonitor.getInfo().floorsClimbedGoal)
    To fix this just create a local variable that hold the value and use the variable instead.
