Acknowledged
CIQQA-3459
bug: no way to set elevation unit on vivoactive 5
This probably should also be reported in the vivoactive 5 forum, but since that's not monitored by Garmin employees, I'll try here.
A user of one of my apps reported that they can't change the elevation unit from feet to meters. I told them to do it in the system settings (my app uses DeviceSettings.elevationUnits). But it turns out that Garmin left that possibility out from vivoactive 5.
The only settings (both on-watch and via Garmin Connect) are:
distance, weight, height, temperature, pressure.
Note, it's not a mistake, it's height, with cm or inches, and not elevation or altitude that's supposed to be meters or feet.
This is vivoactive 5 with FW version 14.15
Yes, there's no barometer in va5, but it doesn't matter, because the watch displays the correct elevation based on GPS, just in feet.
See also: https://forums.garmin.com/sports-fitness/healthandwellness/f/vivoactive-5-series/418980/bug-no-way-to-set-elevation-unit-on-vivoactive-5
Parents
  • For example, I have Total Ascent and Elevation Change data fields in the store which simply display total ascent (from the API) and total ascent - total descent (both from the API). Even though I tried to make it clear that the data comes from Garmin's API and it's not to be trusted because it's based on GPS elevation, I still get complaints that the data is bad. These are literally my worst-rated apps. So it isn't surprising to me that Garmin chooses to hide all elevation-related data on the device itself, and only shows elevation data in Connect, because Connect is able to correct this data after the fact.
    To be clear, people asked me to make these fields because of the lack of corresponding built-in data fields. And once I made those fields, I got bad reviews because users think the data is bad. And it is, because it's based on GPS elevation.
    So again, it's clear to me why Garmin hides all uncorrected elevation-related data on the device itself, for devices without a baro. And since they do that, it makes sense to me that they would also omit the elevation units setting from the UI.
    I don't think this is a one-off mistake (or new decision for VA5), I think Garmin watches without a baro have been like this for since the beginning (meaning, at whatever point they started breaking out units settings for multiple metrics).
Comment
Children
No Data
