I have tried many data fields since purchasing my FR245(M) a month ago and yours is by far the best I have installed. Really love the amount of control you have over the display configuration, header size…
Your datafield is great, wow! Almost perfect, the only 2 things I don't like are:
- I'd love to have current HR at the bottom (which is is possible in current version of datafield) but I'd like to…
Great App, small question:-)
I am a bit confused and maybe it's my misunderstanding how to use. Here is the scenario I am confused about:
I am using a Target Pace of 360 sec/km. meaning I want to run 10 km in 1 hour. And I filled in a Pace range of 10 sec.
The result: When I am running 365 sec/km, the pace field is looking green but the Time Ahead/Behind is showing read (which is correct because I am losing time. I will not make the 10 km in 1 hour.
Wouldn't it be more logic when the pace field is looking green from 360 to (for example) 350 and from 350 to lower blue?
and for example from 360 to 370 orange and from 370 and above red?
Wim
Hello. I have two requests. 1. Please update GRun more because it does not work on Fenix 7 Pro. 2. I have Fenix 5S Plus and 7S Pro. Both have the same 1.2-inch screens (240x240pixels). Both configured the same: "Header Height" 25%, "Row Height Ratio" 4,7,7,3,3. Why are the numbers smaller on the Fenix 7S Pro (right), especially in the third row?
Something is weird with my Distance field. For example, the screen Garmin has with Distance said 4.25 and the Distance field on GRun said 3. Am I using the wrong field? I was doing a suggested Garmin run so there were intervals/laps involved (but I also display Lap Distance and that said 1). My Lap Distance in the settings is 1609, my version is 1.37, and I have a Fenix 7s Pro Sapphire.
Hello, I just tried installing this onto my Edge 520 Plus, but it does not display on the unit to select. Meaning, it shows in Garmin Express that it is installed, but it is not visible on my device. I want to hopefully use it for a Duathalon event later this year, with my Garmin HRM strap, once I get it to where I can play with it. I also tried to email you thru the connect website, but it would not allow me to put a message to you there.
It‘s a datafield - not an app.
You must set it to one of your datascreens like other datafields (data screens) and you‘ll find it under datafields - Connect IQ section!
www8.garmin.com/.../GUID-58CCEE56-34BF-44F4-ACCF-B81F6D716CA9.html
Great data field. I have used several times.
I set it to display total distance and time + distance and time of the current lap.
I don't know if this is supposed to be the case, but when the 2nd kilometer starts and the auto lap is turned on, the total time is, for example 5:05 seconds, but the time data of the current lap is one second more: 00:06. Shouldn't the time of the current lap be 00:05? :)
I wanted to install a second GRun More data field, but the Connect IQ app (2.28.1) does not search for this field. Even when I want to display the developer's applications, Connect IQ shows the message: "no results for More From This Developer".
Using Epix Gen 2, 51mm
Is it possible that I can't have two data fields GRun and GRun More at the same time and that's why I can't find it?
