Data Field: GRun
Forum for GRun Data Field:
GRun: https://apps.garmin.com/en-US/apps/bf56e088-aefe-4fb4-8f16-b2e136b996a9
GRun More: https://apps.garmin.com/en-US/apps/63cba559-b7a2-446a-afa1-51a4680f88e1
Questions, Comments, Suggestions?
Feel free to ask and remember the code is open source, so feel also free to contribute.
https://github.com/gcormier9/GRun
  • Hi
    First of all, I love GRun datafield - Best Data Field I have found so far, after testing several setups!
    BUT I have one problem: the Average Power does not work? (Shows 0 all the time).
    Am i the only one with this problem? Im using a FR945 with Stryd - and "Current Power" works fine.. I've tried several other datafields, and e.g. "DU8-10c0 Datarun Ultimate" shows average power correctly.
    But i prefer GRun for several other reasons - just really want my avg. power to work :)
    Regards,
  • Power seems a bit tricky as it does not seem to work the same way on all watches. Maybe if I got time later on, I'll try to fix it on FR945. sorry for the incovenient.
  • wow, quick response!
    Thanks mate!
    would love if it could work ;)
  • This is near perfect data field. As i often do hiking on the mountains, sometimes i wanna know how cold it is. It would be great if you could add the temperature from watch sensor. Thanks
  • Hi, in the settings what is the pace range parameter used for
  • Pace Range is used to determine if your pace/speed is too slow or too fast. For example, if you configure "Target Pace" at 5:30 min/km (330 seconds) and you can configure "Pace Range" at 15 seconds, it means a good pace will be within 5:15 min/km to 5:45 min/km. If your pace/speed is too slow, the pace/speed is displayed in red, if it's too fast, it is displayed in blue and if it's within the range, it will be displayed in green.
    Ref: github.com/.../GRun
  • Hi,
    Very nice app. Could you please add theses data fields : air pressure with the small arrows to show the trend and in teh battery field the time remaining.
    Best
  • Hi,
    I use this app in my Fenix 7. Is it possible to have the garmin native vertical speed data field?
  • Hi there, I'm running this on Garmin 935 and the reported HR zone is too high. On the garmin connect app, I've only set a default HR zone for all sports based on % of max. Do you know how to fix this?
  • The best data field in my opinion. Very good job. The only thing I would ask for is the ability to manually set the length of the run (regardless of the lap). I run different distances, also 3KM, 7.5Km, 15KM and I miss that because I would also like to use the advantages of lap length. But it's still great.
