Hello! Thank you very much for this watchface! Its very nice ;)
One small issue I've noticed on my vivoactive 4s: the Air pressure setting doesn't work in either field and when enabled for any field the watchwace looses both bars, fields 1,2,3,4,5 (field 6, time and phone fields work though).
Hope this helps and that's not the bug with my particular watch
Hope this helps and that's not a bug with my particular watch
oh! for that matter of fact there is always a 1 , 2 ,3 buttons clicks away for everything , why would you have steps in a data field ? there is a 2 button clicks with all your step statistics and even more? now isn't it ? My personal reason is because my profession requires 12hrs shift in a closed ACd place and working conditions so having a quick look at the current temp outside can give me a hint what to expect once I have the need to step out , it is the Gulf area btw . Is that reason valid enough ? I would like to have current weather temp in data field one and I always have ALT in data field 2 which are both are important to me .
I actually have no issue with wanting to know the current temp. I was wondering about the forecasted temp. That won’t change all day.
Having it in a field is possible but it is a lot more difficult than one might expect. you need to supply location information to a third party, then receive the desired information back from them. This also requires decoding that information and then displaying what you want to show in the field.
With all the other data, everything is handled inside the Garmin family of data.
