Forum for the data field "Datarun Next Generation 4-36 metrics"
If Garmin has connected a sensor that provides temperature values, these are read by DRNG every 5 minutes, saved and retained until other values are provided. It is therefore quite possible that the…
Hi NosGer, you're right, the "AvgPace" doesn't make sense in terms of color, because the pace fields are all compared with the AvgPace of the activity and the size of the difference is shown in color.…
Thank you
You know the Stryd data field is required to save for Stryd.
To do so, I have to connect Stryd to my Fenix 7x Pro not only as foot pod, but also as power meter.
And I do prefer to connect it…
vertical labels are used, when your Device supports the function drawAngledText().
Hello, I have a question about a function in the data field. I want to know how to set the colors for the "average pace" data field to reference the current deviation from the average pace so far. I don't quite understand which options need to be modified in the app to select this or the coloring based on a "set pace."
Thanks!
Hi NosGer, you're right, the "AvgPace" doesn't make sense in terms of color, because the pace fields are all compared with the AvgPace of the activity and the size of the difference is shown in color. I'm considering adding a new field (fixed AvgPace) that does this job. Similar to the PowerZones. It's on the TODO list.
Switching from DRNG10 to DRNG25:
Hi dear,
Is there a way to connect Stryd only via ant+?
I use a Fenix 7x pro, Stryd data field and your DRNG.
to make it works, seems I have to connect Stryd using BT, while I would only connect it by ant+.
actually I have set ant id in your data field and connect stryd to the Garmin via BT
Thank you
DRNG doesn't use BT direct. Have you tried this:
Howto use Power direct from Stryd:
Thank you
And I do prefer to connect it via ANT+.
The problem is that, if I connect the Stryd via ANT+ to permit to register for Stryd, and I also connect your DRNG via ANT ID #, then in your datafield I can't see the power. Just " -- "
The only way to save for Stryd and also to use your Datafield, is to connect stryd as powermeter via Bluetooth only.
That's exactly what I doesn't want.
I can assure, in the past, with previous Garmin software version, I could connect both DRNG datafield and stryd datafield to my stryd device ONLY via Ant+.
Now it doesn't work anymore.
Moreover:
in Garmin Connect IQ, in DRNG datafield settings it is said:
"Powermeter ANT-ID (Stryd or Footpod). If it is set, CP will be read directly from the Stryd"
To me, I understand if I don't set ANT-ID stryd ID, then your DRNG will read from my watch instead that directly from the Stryd. But if I don't put the ANT ID number, then your datafield shows " -- " in the power field. So it seeme I have no choice but to put the ANT ID number at all.
You dont need to connect Stryd as power meter. The Stryd-Datafield doesn't need this, because it uses his own Connection
