Garmin Forums
Garmin Forums
  • Site
  • User
  • Site
  • Search
  • User
  • Apps & Software
  • Outdoor Recreation
  • Sports & Fitness
  • Pilots
  • Developer
  • Beta Program
  • German Forum
  • More
  • Cancel
Connect IQ
  • Developer
Connect IQ
Connect IQ App Showcase Data Field: DRNG
  • News & Announcements
  • Forums
  • Bug Reports
  • Wiki
  • Tags
  • More
  • Cancel
  • Replies 39 replies
  • Subscribers 13 subscribers
  • Views 15779 views
  • Users 0 members are here
Options
  • Share
  • More
  • Cancel
Related
Data Field: DRNG
RoWe
RoWe over 2 years ago
Forum for the data field "Datarun Next Generation 4-36 metrics"
  • DRNG25c0 apps.garmin.com/.../a16d1b4c-7339-41b7-8ac5-a81aee08b2b7
  • DRNG25c1 apps.garmin.com/.../bbb26abd-e8e1-439e-8449-78beaa02b5d8
  • DRNG25c2 apps.garmin.com/.../1c5b9701-a164-4b38-ae40-6e57e5ab51c3
  • DRNG25c3 apps.garmin.com/.../367ca7b6-c44a-4752-9071-3ba963582f01
  • Manual: https://cloud.roweiss.de/index.php/s/kQyErXKLK8fSYXB
  • Sign in to reply
  • Cancel
Top Replies
  • RoWe
    RoWe over 1 year ago in reply to badbri +1
    If Garmin has connected a sensor that provides temperature values, these are read by DRNG every 5 minutes, saved and retained until other values ​​are provided. It is therefore quite possible that the…
  • RoWe
    RoWe over 1 year ago in reply to NosGer +1
    Hi NosGer, you're right, the "AvgPace" doesn't make sense in terms of color, because the pace fields are all compared with the AvgPace of the activity and the size of the difference is shown in color.…
  • OmarAlampi
    OmarAlampi over 1 year ago in reply to RoWe +1
    Thank you
    You know the Stryd data field is required to save for Stryd.
    To do so, I have to connect Stryd to my Fenix 7x Pro not only as foot pod, but also as power meter.
    And I do prefer to connect it…
All Replies
  • RoWe
    New Version is out
    New in 3.1.1:
    * Bugfix: Some settings could disable V-Grade calculation
    • Cancel
    • Up 0 Down
    • Sign in to reply
    • Cancel
  • RoWe
    Tip: Howto use Power direct from Stryd in DRNG:
    • enter the ANT ID in settings
    • FootPod automatically connected via ANT
    • PowerMeter available in the sensor list via ANT, not automatically connected
    • PowerMeter automatically connected via Bluetooth (only neccesary when your
      watch doesn't support Garmin-Power)
    • Cancel
    • Up 0 Down
    • Sign in to reply
    • Cancel
  • RoWe
    Tip: Howto use ExtData-Function in DRNG
    read here: cloud.roweiss.de/.../F4A8KqcKAsXPHr7
    • Cancel
    • Up 0 Down
    • Sign in to reply
    • Cancel
  • RoWe
    Tip: Howto use PartnerMetrics-Function in DRNG
    read here: cloud.roweiss.de/.../jNTH5DNntjRHQ84
    • Cancel
    • Up 0 Down
    • Sign in to reply
    • Cancel
  • RoWe
    New in 3.1.3:
    * Optimization: avoid exceptions on invalid configurations
    New in 3.1.2:
    * Bugfix: Replaced Storage.setValue() because of Garmin-System-Bug (used for Tempe data). Please report if you use a Tempe and it doesn't work.
    * Optimization: reduced memory usage
    • Cancel
    • Up 0 Down
    • Sign in to reply
    • Cancel
  • badbri
    badbri over 1 year ago in reply to RoWe
    Hi RoWe - Love the CIQ datafield, and I was one of the guys that was asking for someone to replace Joop Verdoon's original, so thanks again.
    However, I am getting intermittent power values on my 965 since the most recent FW 21.19.  Usually I get no power, but every 3rd use or so, it actually does show up.  Any ideas how I can fix?
    • Cancel
    • Up 0 Down
    • Sign in to reply
    • Cancel
  • RoWe
    Hi badbri, do you use an external PowerMeter like Stryd or native Power from 965?
    • Cancel
    • Up 0 Down
    • Sign in to reply
    • Cancel
  • badbri
    Sorry for the delay, yes I use Stryd - it's always worked fine but in the last month the power figures come and they go.  I had recently had 3-4 runs where it was showing up but the one from this morning was all "0" again.  What can I do to fix?
    • Cancel
    • Up 0 Down
    • Sign in to reply
    • Cancel
  • RoWe
    What kind/version of Stryd do you have? Is it Stryd-Duo?
    please check this:
    • ANT+ ID entered in DRNG
    • Stryd only connected as foot pod, power meter disconnected
    • Running power set to Off in the activity settings
    • If you also want native Garmin Running power, you can try PowerMeter
    automatically connected via Bluetooth.
    • When starting, always make sure that there are no red corners displayed at the
    bottom, left and right of the battery field. This means that there is no connection to
    the Stryd. When there are no red corners, DRNG has a ANT-Connection to Stryd.
    • Cancel
    • Up 0 Down
    • Sign in to reply
    • Cancel
  • badbri
    Okay thanks very much for the reply.  I think I have figured out that for some reason my watch is turning off the Power sensor in my Run/Trail-Run activity profiles.  I've noticed that Garmin will sometimes just turn-off sensors like HRMs and I think it's happening here too.  Since I have been paying attention and making sure that Stryd is not just connected as a FP but also a Power Meter, I haven't had this issue.
    The tip for looking for the red corners will help alot because I shouldn't have to dive into the Sensors menu to check now if the Red corners method will do that for me.  Thanks again.
    • Cancel
    • Up 0 Down
    • Sign in to reply
    • Cancel
