ANT+ HRM Heart Rate Monitor
As far as I know that is not possible. Once you connect the chest strap in the watch menu it becomes the only source of data. This means that even the functions that otherwise return the ohr hr will return…
Good job for developing this and making it accessible to the public. A really great idea to help in pacing a group ride.
I love it!
But it looks the other way around in the graph. Well, it isn't.
As flocsy said, the reason for *that* part is because the 2 graphs don't have the same y-axis in Connect when you overlay them.
Like I said above:
If you export the activity FIT file (*) and open it with www.fitfileviewer.com, you can graph two metrics at the same time with a single y-axis. (*) open the activity in the Connect website and select gear icon (upper-right hand corner) > Export File
Then the only question is why the OH1 measured a slightly lower HR and had weird artifacts (tiny valleys and plateaus). I would *guess* that difference might have something to do with the fact that it's an optical HR worn on your arm as opposed to a chest strap like the HRM Pro+.
It's not surprising to me that the HRM Pro+ data looks "nicer" (seems to have fewer weird artifacts.)
