ANT+ HRM Heart Rate Monitor
As far as I know that is not possible. Once you connect the chest strap in the watch menu it becomes the only source of data. This means that even the functions that otherwise return the ohr hr will return…
But it looks the other way around in the graph. Well, it isn't.
As flocsy said, the reason for *that* part is because the 2 graphs don't have the same y-axis in Connect when you…
Good job for developing this and making it accessible to the public. A really great idea to help in pacing a group ride.
I love it!
If your only goal is to compare the OHR and HRM after the activity is saved and you rather do all the above steps, then it's not necessary (I didn't know this is possible, and of course it wasn't even possible when I wrote ANT+ HRM)
But there are many other use cases for ANT+ HRM:
Yes, I agree. Like I said, I love this app.
I only wanted to point out that there's now a way to do the one use case which is not supported by this app: record both wrist and external hr, while (mostly) using the external hr as the source for the activity hr. (The cost is that sometimes you get bad data from the wrist hr, unless/until Garmin fixes the source switching bug.)
I should've said that this field isn't necessary to compare wrist hr and external hr after the fact (as long as you have a supported Garmin strap and you're willing to put up with the source switching bug *).
EDIT: [*] actually, Garmin devices that support source switching will also record both wrist hr and external hr even if the external hr is not a supported Garmin strap, as long as source switching is enabled (which it is, by default).
And fitfileviewer.com is a great tool regardless of whether you use it to analyze the data from this app, from source switching or to look at other FIT file internals.
Thanks.
The overlay feature in Connect is pretty cool, but as you mention, the y-axis is sometimes off.
I ended up installing GoldenCheetah. I find that tool not so user friendly, so I didn't managed to plot the data. However, I could fairly easy copy the data into Excel and created the plots I needed.
If you export the activity FIT file (*) and open it with www.fitfileviewer.com, you can graph two metrics at the same time with a single y-axis.
(*) open the activity in the Connect website and select gear icon (upper-right hand corner) > Export File
Thanks for this suggestion. www.fitfileviewer.com is a really great site, and super easy to use. I can easily plot my data and use the data from this field.
Some users ask where can they see the statistics after recording an activity or race. It's in the activity data, can be seen either in the web or mobile version of Garmin Connect.
On the phone open the activity, go to the Stats tab and scroll down to the bottom Connect IQ section:
Then go to the laps tab, make sure you're viewing in landscape mode (meaning the screen is wider than it is high) and scroll all the way to the right:
Hello. Do you know why it shows me such a difference in the graph? (avg hrm pro+ 151bpm & Avg polar Oh1+ 149bpm)
Unfortunately this is how GCM overlays 2 graphs. It doesn't "align" them so that the same values are at the same Y coordinate. I guess mainly because it's not necessarily the same scale (you can overlay HR and elevation for example). So while I don't like it, I don't think it's even a bug. It's just the way Garmin does it.
If you ask about the 2 bpm difference, then I have no idea. ANT+ HRM only records the data, but the calculations are done my the watch and the strap. I'm curious: if you move the cursor left and right, then will you see a 2bpm difference everywhere?
Looking at the shapes of the graphs, it seems that the peaks for foreground chart showing the "activity HR" (srdcovy tep = "heart rate") are more "regular" than the background chart showing ANT+ HRM's recorded HR. For example the first background chart peak (around 13:14) has a weird plateau before an increase. Some of the other background peaks have weird micro-valleys and small plateaus too. The peaks in the foreground charts seem to have more "normal" / expected shapes (lacking the little valleys and plateaus).
I don't know which one is hrm pro+ and which one is polar oh1+, but whichever one was recorded by ANT+ HRM seems to have worse data.
When I moved my finger over the graph, the values were +/- 2bpm different. But I attribute that to the fact that one was an optical shoulder sensor and the other a chest strap. In this second test, it looks better. Avg bpm was only 2bpm.
The burgundy color is Ant+ Oh1 and the average heart rate was 148 bpm. The faint red line was the heart rate measured via HRM Pro+ but the average heart rate was 151 bpm. But it looks the other way around in the graph. Well, it isn't.
