Support and feedback section for the NoFrills watchface
How to install and configure NoFrills
Please post any issues, questions and / or suggestions you have here and I will assist as best I can.
I cannot get the sunrise/sunset function to appear on the watch face! Love it otherwise, simple function and nice looking
Hi, thanks for your interest and posting your question here.
I fully get you regarding the need to have peace and a calm experience when using your watch.
Unfortunately the background blending option is…
Another user who reported the exact same issue said it started working again after he upgraded the firmware.
What is your current firmware version?
I'm on version 2.40 of the watch firmware.
Overnight I've been running one of the stock faces. I was going to post pictures to show that the HR info appeared while browsing through the faces to select one but then vanished as soon as the face was actually activated, but it has now started working! I haven't updated anything. I've also just done a resync, to check that it didn't make the problem come back, and all seems to be working.
I guess I'll keep an eye on it and let you know if the problem occurs again and thanks for the prompt reply.
I updated NoFrills with GCM iOS and lost all settings (need to redo everything in settings :( ). I have the same issue with my own widget and I'm just wondering if this is a known issue of GCM iOS. Are you aware of this?
Hello, I really appreciate this watchface on my Vivoactive HR but seems to lag a lot when I scroll from it to any adiacent widget, compared to other watchfaces I sometimes use that they don't seem to lag.
Any solution?
Thanks for using the watch face.
Unfortunately utmost care and performance improvements have already been pushed to the max.
As with most complex watch faces, there is some visible lag as you described. You even see this with some other watchfaces too.
Can you please take a screenshot so I can determine what settings and datafields etc. you have enabled that could possibly be the cause.
Thanks, I cannot see anything odd.
You even have the HR disabled, so that should count in your favour.
I will check the code again, but like I said, I've been through careful cleanup and optimizations before.
Funny that it lags even when I cycle only through widgets without passing through watchface.
