Watchface: Superb
Analog watchface with some cool features like altitude or sunset/sunrise times.
https://apps.garmin.com/en-US/apps/5fc2b92c-fbf5-42c2-9f6c-597a6520e896
  • 235 DO have a GPS that gives altitude: can't you use this function?
    No, because it requires active GPS to get altitude and it can't be on watchface. Fenixes and Vivoactive HR are measuring altitude with its barometer continualy, so it is available there.
    how do i find the app on my watch after sync?
    I have managed to download the superb watch face but i can't figure out how to find it on the watch? I see that it is on the watch by checking Garmin Express. not sure how to actually use it now??
    Hello,
    I'm a new user of Garmin Forerunner 235 and Superb Watchface, thank you for this work.
    After last update, I had problem with hour display, which was wrong.
    I reboot the watch, I change settings to adjust manual hour and after to automatic. The hour was correct, so I think it was not important.
    But this morning, I missed my wake up :cool:
    Hour display was bad, for 9 am, display was 11 pm..
    I think problem appeared during night, because before go to bed hour was correct.
    I don't know if problem is coming from watch or watchface to be honnest, but it's my second poblem with hour after update Superb.
    My comment is not a critical, but just to feed back information to developer :D
    Kind Regards
    New@ngel
    Last firmware 4.7
  • Hello,
    Kind Regards
    New@ngel
    Last firmware 4.7
    Hi,
    thanks for the feedback. It shouldn't be related to the watchface because Superb is just reading time from the watch. You can switch to another watchface or to the default watchface to check and ensure where the issue lies..
    Heart Rate Data
    Hello, I seem to be having an issue with the displayed Heart Rate data not being the same as the heart rate widget on my watch. I am using a Garmin Fenix 3 HR with software version 3.20. The watch face would display, for example, 80BPM and the heart rate widget (by Garmin) will show, for example, 95BPM. Any help would be greatly appreciated!
  • great watch face, but if i can, i'd love to add a wishlist (which may increase the memory footprint) :
    - ability to change the color of the minor ticks. i like the simplicity of your face, but i think having an extra splash of color would make it look interesting [i like green :) ]
    - ability to turn off the minor hour marks (1,2,4,5,7,8,10,11), in which case, make 3,6,9,12 slightly larger
    - ability to display steps in fields 2 and 3 (it seems that it can only be put in field 1 at 9'oclock)
  • Circle appears on the watch face
    Hi Petr,
    First I would like to say great watch face, thanks!
    I am using on a 630, it 'lost' the sunrise/set and replaced with date; I found out how to reinstate it. But since then, I am getting a circle appearing on the watchface (clears overnight - maybe midnight, but I haven't seen it go!).
    It starts at the 12 position and is outside the numbers, but inside the hour marks.At 5pm (as I write) it has reached the 3 marker.
    (I also don't have the sunrise/set symbol any more - is that a setting I've selected incorrectly?)
    Thanks,
    Peter
  • Hi Petr,
    Thanks,
    Peter
    Hi, please uninstall it and reinstall again. It should helps..
  • Hi, please uninstall it and reinstall again. It should helps..
    Thanks - looks OK so far.
    Only thing I have 'lost' is the sun rise/set symbol.
  • Bluetooth icon not showing on Fenix 3 HR
    Just came across SUPERB last night and like it very much. Info page says Bluetooth icon is supported but it isn't listed in any of the 3 drop down menu nor does the icon automatically appear on the watchface when Bluetooth is activated.
