Watchface: Superb
Analog watchface with some cool features like altitude or sunset/sunrise times.
https://apps.garmin.com/en-US/apps/5fc2b92c-fbf5-42c2-9f6c-597a6520e896
    Thanks - looks OK so far.
    Only thing I have 'lost' is the sun rise/set symbol.
    Hi, I have this too, no sunrise/sunset symbol. Was this part removed?
    Great watch face btw, you always make the best watch faces!
  • Hi,
    is it possible to display burned calories in custom field 1? I think this was possible in an earlier version of the watchface.
    thanks
  • Very nice
    Real good clean design and easy to see everything you need.
    Well done to the developer!
    Installing on Forerunner 735xt?
    Hi - Quick question for the developer. This watch face looks great on the IQ Connect Store. However, when I install it on my 735xt it doesn't seem nearly as nice (crisp/clear/sharp) as it is on the pictures here in the IQ Store photos. Almost seems a bit blurry. The firmware on the watch is fully up-to-date, so I know that is not the issue. Perhaps it was not originally designed for this model? Or, am I doing something incorrect. Would welcome any insight.
    Thanks,
    peter
  • Hard to say.. It's not very easy to make it super-crisp with a resolution of 218x180 pixels.
    Excellent, but lacking a bit of color
    Hi, I really really like this watchface. The only 2 things I would like to see added to make it the ultimate one are:
    • Choose color theme: for me the hour-ticks would be preferably red, but I can imagine people wanting other colors for the dials, hands or tick marks.
    • Have a seconds-hand added (also in red).
    Keep up the good work!!!
    Yes, but I wasn't sure if CIQ limitations (hw and sw) allow me to implement this complex calculations. But they will. And moreover it hasn't impact on battery because it's calculated once a day (if you don't change your position, otherwise it's recalculated).
    How do you actually get the last known position?
    I'm developing a watchface too, and the calculation is working perfectly, but only when I input the location manually since a permission is required otherwise.
    Apparently it is possible, would you mind sharing how?
  • Apparently it is possible, would you mind sharing how?
    You can get the last location from the data from Activity.getActivityInfo(). It may not be available on all devices for much time after you're done doing an activity that used GPS. If you get a valid lat/lon, you can save it in the Object Store, in the event that it's not available at a later time.
    Hi
    Hello, you made great apps. but I would like to ask if you do not think about the corporate design. well thank you
    Bílé pozadí
    Dobrý den pane Koula.
    Váš skin Superb je bezvadný. Dobře čitelný a přehledný. Proporce ručiček krásně čitelné na první pohled. Ale měl bych dotaz: Bylo by prosím možné udělat bílé pozadí a trochu větším písmem datum a čas svítání atd.? Přece jenom jsem už troska přes 40 let a špatně to přečtu. Bílé pozadí je lépe čitelné. Děkuji moc za Vaši práci a přeji hodně zdaru v dalším životě :-) Vašek Tábor. [email][email protected][/email]
