HMs DIY #1-6
Store Link
Because I want to keep this datafield and the app free for use I would be very grateful about a small donation to PayPal
A detailed description of how to use it can be found here:
HMs_DIY_GUIDANCE.pdf
HMs_DIY_ANLEITUNG.pdf
Thanks very much to mcinner1 for putting so much time into this documentation!
Designer download
You can contribute on my github page.
You can upload your layout so others can use it as well.
Also any changes to the fonts.txt can be updated there as well.
Garmin_HMsDIY
RELEASE NOTES
3.6.2
* switched to new SDK 7.2.1
* added devices: Approach S7 42mm, Descent Mk3 43mm /Mk3i 43mm, Descent Mk3i 51mm, Edge 1050, epix Pro Gen2 42mm, epix Pro Gen2 47mm / quatix 7 pro, epix Pro Gen2 51mm / D2 mach 1 pro / tactix 7
Fenix 7 Pro, Fenix 7 Pro Solar, Fenix 7S Pro, Fenix 7X Pro, Fenix 7xPro Solar, Forerunner 165, Forerunner 165M, Venu 3, Venu 3S, Vivoactive 5
3.5.1
* switched to new SDK 4.2.4
* added devices: FR265, FR265S, FR965, GPSMAP 67/67i, Marq (Gen 2), Marq (Gen 2) Aviator, EDGE 540, EDGE 840, Instinct 2x Solar
* added two new font types GLANCE, GLANCENR (only available if device supports it!)
for full releasenotes see: releasenotes.txt
  • Hi
    Ijust changed BikeSpeed bat status to voltage! All other ant bat fields are still bat status. So, even Voltage is not shown for BikeSpeed?
  • Sorry - my mistake with ANT power.
    No, battery status/Voltage for ANT bikespeed battery remains 0.
  • There must be some ANT communication from the Garmin hub speed sensor to the head unit:
  • For the Stages powermeter ANT bikepower battery works perfectly! After placing a new battery I've got battery status 1 which is new.
    ...but on the other hand - if it works perfectly with my power sensor, there can't be anything wrong with the code...?
  • Hi. Strange situation in designer 2.7.8 and 2.7.9 I can't load my layouts, for example. Regards
    14 łuki speedu wersja z czasami w srodku z ZONE BAR.xml
    <?xml version="1.0" encoding="UTF-8"?>
    <DIYLayout>
        <Device name="Edge 830"/>
        <LayoutElement type="1" color="DFDFDF" x="246" y="5" x2="0" y2="5" eletype="LN" valuetype="FX" radius="0" stroke="27" nr_values="1"/>
        <LayoutElement type="1" color="BBFFDD" x="0" y="19" x2="246" y2="54" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="0" y="53" x2="246" y2="324" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="80FFFF" x="123" y="178" x2="178" y2="362" eletype="AC" valuetype="FX" radius="115" stroke="17" nr_values="1"/>
        <LayoutElement type="1" color="F8F8F6" x="123" y="178" x2="178" y2="362" eletype="AF" valuetype="CS" radius="115" stroke="17" nr_values="1"/>
        <LayoutElement type="1" color="F8F8F5" x="123" y="178" x2="178" y2="362" eletype="AF" valuetype="AS" radius="115" stroke="4" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="53" x2="246" y2="53" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="25" y="249" x2="66" y2="249" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="180" y="249" x2="224" y2="249" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="75" y="259" x2="169" y2="259" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="0000FF" x="25" y="291" x2="66" y2="291" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="0000FF" x="180" y="291" x2="224" y2="291" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="44" y="124" x2="202" y2="124" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="181" x2="246" y2="181" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="215" x2="246" y2="215" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="72" y="320" x2="72" y2="218" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="86" y="177" x2="86" y2="128" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="92" y="181" x2="152" y2="215" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="104" y="215" x2="142" y2="229" eletype="RC" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="160" y="177" x2="160" y2="128" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="172" y="320" x2="172" y2="218" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="55" y="20" x2="55" y2="52" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="189" y="20" x2="189" y2="52" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="123" y="20" x2="123" y2="52" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="123" y="136" fixedtext="false" eletype="CP" text="$M:$S" font="TINY" halignment="1" precision="1" nr_values="1" sampletext="280"/>
        <LayoutElement type="0" color="EA0000" x="123" y="78" fixedtext="false" eletype="MP" text="$M:$S" font="TINY" halignment="1" precision="1" nr_values="1" sampletext="211"/>
        <LayoutElement type="0" color="0000FF" x="54" y="136" fixedtext="false" eletype="AP" text="$M:$S" font="TINY" halignment="1" precision="1" nr_values="1" sampletext="254"/>
        <LayoutElement type="0" color="0080FF" x="193" y="136" fixedtext="false" eletype="EP" text="$M:$S" font="TINY" halignment="1" precision="1" nr_values="1" sampletext="254"/>
        <LayoutElement type="0" color="000000" x="123" y="153" fixedtext="false" eletype="CS" text="$V" font="NR_MILD" halignment="1" precision="1" nr_values="1" sampletext="45.34"/>
        <LayoutElement type="0" color="EA0000" x="123" y="95" fixedtext="false" eletype="MS" text="$V" font="NR_MILD" halignment="1" precision="1" nr_values="1" sampletext="65.34"/>
        <LayoutElement type="0" color="0000FF" x="54" y="153" fixedtext="false" eletype="AS" text="$V" font="NR_MILD" halignment="1" precision="1" nr_values="1" sampletext="34.76"/>
        <LayoutElement type="0" color="0080FF" x="194" y="153" fixedtext="false" eletype="AD" text="$V" font="NR_MILD" halignment="1" precision="1" nr_values="1" sampletext="14.36"/>
        <LayoutElement type="0" color="EA0000" x="201" y="226" fixedtext="false" eletype="MH" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="204.79"/>
        <LayoutElement type="0" color="000000" x="201" y="262" fixedtext="false" eletype="HR" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1" sampletext="183.55"/>
        <LayoutElement type="0" color="0000FF" x="200" y="300" fixedtext="false" eletype="AH" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="154.49"/>
        <LayoutElement type="0" color="EA0000" x="45" y="226" fixedtext="false" eletype="MC" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="210.55"/>
        <LayoutElement type="0" color="000000" x="44" y="262" fixedtext="false" eletype="CC" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1" sampletext="167.34"/>
        <LayoutElement type="0" color="0000FF" x="46" y="300" fixedtext="false" eletype="AC" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="188.45"/>
        <LayoutElement type="0" color="000000" x="150" y="0" fixedtext="false" eletype="CT" text="$H:$M" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="63312"/>
        <LayoutElement type="0" color="000000" x="227" y="0" fixedtext="false" eletype="BV" text="$V %" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="87"/>
        <LayoutElement type="0" color="000000" x="200" y="193" fixedtext="false" eletype="ET" text="$H:$M:$S" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="3356"/>
        <LayoutElement type="0" color="000000" x="46" y="193" fixedtext="false" eletype="TT" text="$H:$M:$S" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="4374"/>
        <LayoutElement type="0" color="000000" x="123" y="230" fixedtext="false" eletype="DS" text="$V" font="NR_MILD" halignment="1" precision="2" nr_values="1" sampletext="12.56"/>
        <LayoutElement type="0" color="000000" x="123" y="212" fixedtext="false" eletype="OM" text="$V" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="1121.21"/>
        <LayoutElement type="0" color="000000" x="216" y="30" fixedtext="false" eletype="TA" text="$V" font="SMALL" halignment="1" precision="0" nr_values="1" sampletext="423.66"/>
        <LayoutElement type="0" color="000000" x="24" y="30" fixedtext="false" eletype="TD" text="$V" font="SMALL" halignment="1" precision="0" nr_values="1" sampletext="457.21"/>
        <LayoutElement type="0" color="000000" x="89" y="29" fixedtext="false" eletype="CL" text="$VM" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="478.22"/>
        <LayoutElement type="0" color="000000" x="157" y="29" fixedtext="false" eletype="GR" text="$V%" font="MEDIUM" halignment="1" precision="1" nr_values="16" sampletext="6.69"/>
        <LayoutElement type="0" color="000000" x="186" y="104" fixedtext="false" eletype="HP" text="$V%" font="SMALL" halignment="1" precision="0" nr_values="1" sampletext="84.12"/>
        <LayoutElement type="0" color="000000" x="62" y="104" fixedtext="false" eletype="CA" text="$Vc" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="1563.77"/>
        <LayoutElement type="0" color="000000" x="123" y="202" fixedtext="false" eletype="PT" text="$H:$M:$S" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="374"/>
        <LayoutElement type="0" color="000000" x="123" y="181" fixedtext="false" eletype="TI" text="$H:$M:$S" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="374"/>
        <LayoutElement type="0" color="EA0000" x="44" y="216" fixedtext="true" eletype="FX" text="MAX" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="EA0000" x="200" y="216" fixedtext="true" eletype="FX" text="MAX" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="200" y="249" fixedtext="true" eletype="FX" text="bpm" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="45" y="249" fixedtext="true" eletype="FX" text="rpm" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="123" y="125" fixedtext="true" eletype="FX" text="SPEED (KM/H)" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="0000FF" x="55" y="124" fixedtext="true" eletype="FX" text="AVG  M" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="0000FF" x="48" y="291" fixedtext="true" eletype="FX" text="AVG " font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="0000FF" x="202" y="291" fixedtext="true" eletype="FX" text="AVG " font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="0080FF" x="191" y="124" fixedtext="true" eletype="FX" text="AVG  E" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="86" y="216" fixedtext="true" eletype="FX" text="Dyst." font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="163" y="216" fixedtext="true" eletype="FX" text="Km" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FF0000" x="123" y="69" fixedtext="true" eletype="FX" text="MAX" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="46" y="182" fixedtext="true" eletype="FX" text="Czas Jazdy." font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="200" y="182" fixedtext="true" eletype="FX" text="Czas Ca�ko." font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="121" y="18" fixedtext="true" eletype="FX" text="   Ca�k.SPD   WYSOKOSC      NACHYL      Ca�k.WZN" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="1" color="E9E9E9" x="0" y="216" x2="13" y2="323" eletype="RF" valuetype="FX" radius="0" stroke="10" nr_values="1"/>
        <LayoutElement type="1" color="E9E9E9" x="233" y="216" x2="246" y2="323" eletype="RF" valuetype="FX" radius="0" stroke="7" nr_values="1"/>
        <LayoutElement type="1" color="CAFFF0" x="0" y="216" x2="13" y2="323" eletype="RV" valuetype="CC" radius="0" stroke="10" nr_values="1"/>
        <LayoutElement type="1" color="E9E9E0" x="233" y="216" x2="246" y2="323" eletype="RV" valuetype="HR" radius="0" stroke="7" nr_values="1"/>
        <LayoutElement type="2" replDC="CAFFF0" valDC00="950" colDC00="330066" hideDC00="false" valDC01="900" colDC01="800000" hideDC01="false" valDC02="850" colDC02="CC0000" hideDC02="false" valDC03="800" colDC03="FF0000" hideDC03="false" valDC04="750" colDC04="FF8000" hideDC04="false" valDC05="700" colDC05="8080FF" hideDC05="false" valDC06="650" colDC06="00FFFF" hideDC06="false" valDC07="600" colDC07="00FF40" hideDC07="false" valDC08="550" colDC08="FFFF00" hideDC08="false" invertcolor="false"/>
        <LayoutElement type="2" replDC="E9E9E0" valDC00="1900" colDC00="800000" hideDC00="false" valDC01="1710" colDC01="800000" hideDC01="false" valDC02="1520" colDC02="FF0000" hideDC02="false" valDC03="1330" colDC03="EAA000" hideDC03="false" valDC04="1140" colDC04="0080FF" hideDC04="false" valDC05="950" colDC05="00D200" hideDC05="false" valDC06="550" colDC06="FFFF00" hideDC06="false" invertcolor="false"/>
        <LayoutElement type="1" color="FF000E" x="14" y="9" x2="0" y2="0" eletype="CF" valuetype="GA" radius="8" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="FF000E" valDC00="40" colDC00="00A800" hideDC00="false" valDC01="30" colDC01="00FC00" hideDC01="false" valDC02="20" colDC02="E86224" hideDC02="false" valDC03="10" colDC03="F80000" hideDC03="false" invertcolor="false"/>
        <LayoutElement type="3" text="----------------- Seperator ------------------"/>
        <LayoutElement type="0" color="000000" x="123" y="258" fixedtext="true" eletype="FX" text="ZONE BAR" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="1" color="E9E9E9" x="75" y="270" x2="90" y2="322" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="E9E9E9" x="91" y="270" x2="106" y2="322" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="E9E9E9" x="107" y="270" x2="122" y2="322" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="E9E9E9" x="123" y="270" x2="138" y2="322" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="E9E9E9" x="139" y="270" x2="154" y2="322" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="E9E9E9" x="155" y="270" x2="170" y2="322" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="E9E9E0" x="75" y="270" x2="90" y2="322" eletype="RV" valuetype="P0" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="E9E9E1" x="91" y="270" x2="106" y2="322" eletype="RV" valuetype="P1" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="E9E9E2" x="107" y="270" x2="122" y2="322" eletype="RV" valuetype="P2" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="E9E9E3" x="123" y="270" x2="138" y2="322" eletype="RV" valuetype="P3" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="E9E9E4" x="139" y="270" x2="154" y2="322" eletype="RV" valuetype="P4" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="E9E9E5" x="155" y="270" x2="170" y2="322" eletype="RV" valuetype="P5" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="E9E9E0" valDC00="1000" colDC00="FFFF00" hideDC00="false" valDC01="1" colDC01="FFFF00" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="2" replDC="E9E9E1" valDC00="1000" colDC00="00D200" hideDC00="false" valDC01="1" colDC01="00D200" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="2" replDC="E9E9E2" valDC00="1000" colDC00="0080FF" hideDC00="false" valDC01="1" colDC01="0080FF" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="2" replDC="E9E9E3" valDC00="1000" colDC00="EAA000" hideDC00="false" valDC01="1" colDC01="EAA000" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="2" replDC="E9E9E4" valDC00="1000" colDC00="FF0000" hideDC00="false" valDC01="1" colDC01="FF0000" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="2" replDC="E9E9E5" valDC00="1000" colDC00="800000" hideDC00="false" valDC01="1" colDC01="800000" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="80" y="304" fixedtext="false" eletype="P0" text="$V" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="15"/>
        <LayoutElement type="0" color="000000" x="97" y="304" fixedtext="false" eletype="P1" text="$V" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="25"/>
        <LayoutElement type="0" color="000000" x="114" y="304" fixedtext="false" eletype="P2" text="$V" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="10"/>
        <LayoutElement type="0" color="000000" x="130" y="304" fixedtext="false" eletype="P3" text="$V" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="18"/>
        <LayoutElement type="0" color="000000" x="145" y="304" fixedtext="false" eletype="P4" text="$V" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="13"/>
        <LayoutElement type="0" color="000000" x="162" y="304" fixedtext="false" eletype="P5" text="$V" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="19"/>
        <LayoutElement type="0" color="000000" x="87" y="266" fixedtext="false" eletype="HZ" text="$V z" font="TINY" halignment="1" precision="1" nr_values="1" sampletext="4"/>
        <LayoutElement type="0" color="000000" x="151" y="266" fixedtext="false" eletype="TE" text="$VT.E" font="TINY" halignment="1" precision="1" nr_values="1" sampletext="4.2"/>
        <LayoutElement type="0" color="000000" x="75" y="0" fixedtext="false" eletype="TM" text="$V�C" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="18.4"/>
        <LayoutElement type="2" replDC="F8F8F6" valDC00="500" colDC00="0000A0" hideDC00="false" valDC01="10" colDC01="0000A0" hideDC01="false" invertcolor="false"/>
        <LayoutElement type="2" replDC="F8F8F5" valDC00="530" colDC00="00FF40" hideDC00="false" valDC01="200" colDC01="00FF40" hideDC01="false" valDC02="199" colDC02="FF8080" hideDC02="false" valDC03="1" colDC03="FF8080" hideDC03="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="241" y="39" fixedtext="true" eletype="FX" text="M" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="51" y="39" fixedtext="true" eletype="FX" text="M" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
    </DIYLayout>
    Regards
  • Hi
    Do you mean the special characters? I corrected to designer to read/write correctly as UTF8. Please edit the special characters, and it will be ok in the future..
    There was a problem with storing speical characters in the designer before, this is fixed now.
    Please remove special characters from filename!
    regards
    Erich
  • I could load it with no problems, but your special characters "Ca?k SPD) got lost during up- and download in this forum.
    You should upload your zipped XML file, so we can check.
