HMs DIY #1-6
Store Link
Because I want to keep this datafield and the app free for use I would be very grateful about a small donation to PayPal
A detailed description of how to use it can be found here:
HMs_DIY_GUIDANCE.pdf
HMs_DIY_ANLEITUNG.pdf
Thanks very much to mcinner1 for putting so much time into this documentation!
Designer download
You can contribute on my github page.
You can upload your layout so others can use it as well.
Also any changes to the fonts.txt can be updated there as well.
Garmin_HMsDIY
RELEASE NOTES
3.9.1
* switched to new SDK 9.3.0
* added devices: Approach S72 43mm, Approach S72 47mm, D2 Mach 2 Pro, Edge 1060, Edge Explore 3, Edge Explore 3 Plus, Enduro 4, fenix 9 43mm, fenix 9 47mm, fenix 9 Pro 43mm, fenix 9 Pro 47mm, fenix 9 Pro 51mm,
fenix 9 Pro Solar 47mm, fenix 9 Pro Solar 51mm, Forerunner 70, Forerunner 170, Forerunner 170 Music, MARQ (Gen 3)
3.8.3
* fixed problem with backslash in configuration string
3.8.1
* switched to new SDK 8.3.0
* added devices: Approach S50, D2 Mach 2, Descent G2, Edge 550, Edge 850, Edge MTB, eTrex Touch, fēnix 8 Pro 47mm / 51mm / MicroLED, Forerunner 970, Forerunner 570 42mm, Forerunner 570 47mm,
GPSMAP H1, Instinct 3 AMOLED 45mm, Instinct 3 AMOLED 50mm, Instinct 3 Solar 45mm / 50mm, Instinct Crossover AMOLED, Instinct E 40mm, Instinct E 45mm, Venu 4 41mm, Venu 4 45mm / D2 Air X15, Venu X1, vívoactive 6
for full releasenotes see: releasenotes.txt
  • Hi
    Thank you very much, really cool layout !!
    Didn't think myself that this is possible with only 5 types of graphic elements.
    Thanks for your testing and fast responses.
    Unless there is a major bug I will release a new version in a few days with most of the points from my todo list.
    If there are any more wishes for values or features please post it here.
    regards
    Erich
  • If there are any more wishes for values or features please post it here.
    Hahaha! You'll regret saying that because of all the wishes you will get!
    Grinning
  • Hi Erich
    What I miss the most is
    • Values for last lap
    • Pacer functionality (+/- target pace set in app with gained/lost time due to off pace)
    • Distance left to some set distance (in app - what the original DIY did with multiple distances was really nice) and expected time to the target distance set in app.
    • A "graph" field  would also be nice (HR/pace/etc)
  • Hi
    I think distance left is already available, it should be "distance to destination" and "distance to next point", including time to XX and ETA.
    regards
    Erich
    I had today with my Forerunner 945 extreme battery consumption - 8-12% per hour (8% by running with 1 variable with dynamic coloring and 12% by cycling with 2 variables with dynamic coloring), normally was 4-5% per hour. Had someone that experience? What can be a reason for this? Thanks.
  • Hi Thanks for offering some solutions. I hadn't spotted the 2-stroke, like you suggested it was originally cloned from a 2-stroke line, but once it was changed to a filled rectangle the stroke couldn't be changed.
    I recreated the rectangle with 1-stroke but the issue still occurs. Also as you alluded to, the element is disappearing not simply turning black as the red highlight disappears when I increase the size of the rectangle
    Here is a link to the XML if you have time to check it out: layout_Edge1030.xml It's still work in progress as a couple of the timer functions haven't been released as yet, so I was just testing the layout for when they are
    Note for . I'm not sure if the Left/Right alignment is working correctly. I originally added a left aligned % text element to a right aligned battery percentage in my layout above and positioned it as can be seen in my layout. However when it was loaded on to the edge the % symbol was positioned further left and was on top of the battery percentage value.
    Also, not a bug, more cosmetic with the 'Name of next point'. If there isn't a course loaded or the loaded course doesn't contain any course points the field displays 0.0. Maybe at some point in a future release if there is no data for that field it could be made to be blank
  • I‘m out and will check your XML on Sunday afternoon!
  • Hi
    I tried you layout and couldn't reproduce your problem. But I changed the behaviour of the clipping area, I hope this fixed the problem. I will release a new version later today.
    regards
    Erich
  • Hi
    I have to admit, I did not test the battery consumption with my datafield. Is it possible that you do 2 identical runs, one with my datafield and one with a standard one, so we can narrow down the problem (with same devices attached and same gps settings) ?
    thanks
    regards
    Erich
