HMs DIY #1-6
Store Link
Because I want to keep this datafield and the app free for use I would be very grateful about a small donation to PayPal
A detailed description of how to use it can be found here:
HMs_DIY_GUIDANCE.pdf
HMs_DIY_ANLEITUNG.pdf
Thanks very much to mcinner1 for putting so much time into this documentation!
Designer download
You can contribute on my github page.
You can upload your layout so others can use it as well.
Also any changes to the fonts.txt can be updated there as well.
Garmin_HMsDIY
RELEASE NOTES
3.9.1
* switched to new SDK 9.3.0
* added devices: Approach S72 43mm, Approach S72 47mm, D2 Mach 2 Pro, Edge 1060, Edge Explore 3, Edge Explore 3 Plus, Enduro 4, fenix 9 43mm, fenix 9 47mm, fenix 9 Pro 43mm, fenix 9 Pro 47mm, fenix 9 Pro 51mm,
fenix 9 Pro Solar 47mm, fenix 9 Pro Solar 51mm, Forerunner 70, Forerunner 170, Forerunner 170 Music, MARQ (Gen 3)
3.8.3
* fixed problem with backslash in configuration string
3.8.1
* switched to new SDK 8.3.0
* added devices: Approach S50, D2 Mach 2, Descent G2, Edge 550, Edge 850, Edge MTB, eTrex Touch, fēnix 8 Pro 47mm / 51mm / MicroLED, Forerunner 970, Forerunner 570 42mm, Forerunner 570 47mm,
GPSMAP H1, Instinct 3 AMOLED 45mm, Instinct 3 AMOLED 50mm, Instinct 3 Solar 45mm / 50mm, Instinct Crossover AMOLED, Instinct E 40mm, Instinct E 45mm, Venu 4 41mm, Venu 4 45mm / D2 Air X15, Venu X1, vívoactive 6
for full releasenotes see: releasenotes.txt
  • These are the settings I came up with for a Vivoactive 4. It's a first pass, but I think they're close enough.
    FNT_VIVOACTIVE4_BOLD_NUMBER_FONT_5;IDR_FNT_BEBASNEUE_REG; 76; -12; 0; 13; -13
    FNT_VIVOACTIVE4_BOLD_NUMBER_FONT_6;IDR_FNT_BEBASNEUE_REG; 90; -16; 0; 18; -18
    FNT_VIVOACTIVE4_REGULAR_NUMBER_FONT_1;IDR_FNT_BEBASNEUE_REG; 39; -7; 1; 8; -5
    FNT_VIVOACTIVE4_REGULAR_NUMBER_FONT_2;IDR_FNT_BEBASNEUE_REG; 56; -10; 0; 10; -10
    FNT_VIVOACTIVE4_ROBOTO_MEDIUM_BOLD;IDR_FNT_BEBASNEUE_REG; 31; -4; 0; 5; 4
    FNT_VIVOACTIVE4_ROBOTO_MEDIUM_PLUS_BOLD;IDR_FNT_BEBASNEUE_REG; 35; -5; 0; 6; 1
    FNT_VIVOACTIVE4_ROBOTO_SMALL_BOLD;IDR_FNT_BEBASNEUE_REG; 25; -3; 0; 4; 4
    FNT_VIVOACTIVE4_ROBOTO_TINY_BOLD;IDR_FNT_BEBASNEUE_REG; 10; 0; 0; 0; 0
    FNT_VIVOACTIVE4_ROBOTO_TINY_PLUS_BOLD;IDR_FNT_BEBASNEUE_REG; 25; -3; 0; 4; 2
    FNT_VIVOACTIVE4_ROBOTO_XTINY_BOLD;IDR_FNT_BEBASNEUE_REG; 20; -2; 0; 3; 4
    Now I'm just having an issue to get anything to display on my actual device. I add the data screen, set it to one field, set that field to DIY. And in the Android app I copied test string into the default field. However, only a blank white screen appears so I need to look into that a bit more.
    Edit: Got something to display on my device now, but I think it's evidence that my font settings aren't that good since everything is off from what's displayed in the editor. So, back to the drawing board.
  • I'm stumped again. Using the font settings I previously posted and an example xml, I see a setup that appears to be sized right. But when I load it on my watch everything is off. Here's an album with the comparison: https://imgur.com/a/OYIXZRn
    I just selected christian888_FR935_hiking.xml, switched the device to vivoactive 4, then scaled to device and came up with the second pic. The first pic is what I see on my watch.
  • Hi
    Seems to me that you have a Vivoactive 4S, looks more like it.
    regards
    Erich
  • Just out of curiosity: I‘m wondering if one can see which kind of memory-sized-device a special device is.
    Can one see here in „specs“?
    https://buy.garmin.com/en-US/US/p/643382/pn/010-02174-01
    ...you know, I mean the DIY element classes (H) (M) —
  • Nope, it's definitely a plain old 4. The back says 4 and the Garmin app confirms it.
  • Could you post your xml please.
  • Just to make sure I'm not messing it up with edits, I started fresh. I loaded christian888_FR935_hiking.xml from the examples folder into the program, changed the Device to vivoactive 4, clicked Scale to device, then copied that code to the clipload and loaded it into the Connect IQ app.
    Here is the comparison of the app and what I see on my watch: https://imgur.com/a/1Snodvo
    It's a little different from my first example, but still off.
    This is the xml from the example I used:
    <?xml version="1.0" encoding="UTF-8"?>
    <DIYLayout>
        <Device name="Forerunner 935"/>
        <LayoutElement type="1" color="000000" x="120" y="120" x2="0" y2="0" eletype="CF" valuetype="FX" radius="120" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF8040" x="120" y="120" x2="200" y2="41" eletype="CR" valuetype="FX" radius="120" stroke="9" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="0" x2="240" y2="40" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="200" x2="240" y2="240" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="30" y="68" x2="210" y2="68" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="30" y="143" x2="210" y2="143" eletype="LN" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="120" y="6" fixedtext="false" eletype="CL" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="77" y="17" x2="85" y2="33" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="155" y="17" x2="163" y2="33" eletype="RF" valuetype="FX" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="49" y="40" fixedtext="true" eletype="FX" text="up" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="83" y="38" fixedtext="false" eletype="TA" text="$V" font="SMALL" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="133" y="40" fixedtext="true" eletype="FX" text="down" font="XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="180" y="38" fixedtext="false" eletype="TD" text="$V" font="SMALL" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="110" y="76" fixedtext="false" eletype="CT" text="$H:$M" font="NR_THAI_HOT" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="210" y="84" fixedtext="false" eletype="BV" text="$V" font="S_XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="210" y="106" fixedtext="true" eletype="BV" text="%" font="S_XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="75" y="142" fixedtext="true" eletype="FX" text="sum" font="S_XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="165" y="142" fixedtext="true" eletype="FX" text="lap" font="S_XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="75" y="168" fixedtext="false" eletype="DS" text="$V" font="NR_MILD" halignment="1" precision="2" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="165" y="168" fixedtext="false" eletype="LD" text="$V" font="NR_MILD" halignment="1" precision="2" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="81" y="200" fixedtext="true" eletype="FX" text="hr" font="S_XTINY" halignment="1" precision="0" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="120" y="203" fixedtext="false" eletype="HR" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1"/>
    </DIYLayout>
  • I did some work to help you...
    Find attached a ZIP-file with:
    - fonts(McInner).txt
                      an Vivoactive 4 edited font.txt file. Copy it to the folder of the Designer tool and rename it fonts.txt.
                      If you have edited your font.txt already then make a backup of your file.
    - VA4_font_test1.xml    a font test layout
    - VA4_hiking.xml           your testlayout - adapted for Vivoactive 4
    Load the layout-file(s) to the designer and transmit the layout to your watch.
    Then upload pictures of the watch!
    Since I have no Vivoactive 4 watch, I cannot check if the fonts.txt file is ok.
    7455.FontMappingVIVOACT_4.zip
