HMs DIY #1-6
Store Link
Because I want to keep this datafield and the app free for use I would be very grateful about a small donation to PayPal
A detailed description of how to use it can be found here:
HMs_DIY_GUIDANCE.pdf
HMs_DIY_ANLEITUNG.pdf
Thanks very much to mcinner1 for putting so much time into this documentation!
Designer download
You can contribute on my github page.
You can upload your layout so others can use it as well.
Also any changes to the fonts.txt can be updated there as well.
Garmin_HMsDIY
RELEASE NOTES
3.9.1
* switched to new SDK 9.3.0
* added devices: Approach S72 43mm, Approach S72 47mm, D2 Mach 2 Pro, Edge 1060, Edge Explore 3, Edge Explore 3 Plus, Enduro 4, fenix 9 43mm, fenix 9 47mm, fenix 9 Pro 43mm, fenix 9 Pro 47mm, fenix 9 Pro 51mm,
fenix 9 Pro Solar 47mm, fenix 9 Pro Solar 51mm, Forerunner 70, Forerunner 170, Forerunner 170 Music, MARQ (Gen 3)
3.8.3
* fixed problem with backslash in configuration string
3.8.1
* switched to new SDK 8.3.0
* added devices: Approach S50, D2 Mach 2, Descent G2, Edge 550, Edge 850, Edge MTB, eTrex Touch, fēnix 8 Pro 47mm / 51mm / MicroLED, Forerunner 970, Forerunner 570 42mm, Forerunner 570 47mm,
GPSMAP H1, Instinct 3 AMOLED 45mm, Instinct 3 AMOLED 50mm, Instinct 3 Solar 45mm / 50mm, Instinct Crossover AMOLED, Instinct E 40mm, Instinct E 45mm, Venu 4 41mm, Venu 4 45mm / D2 Air X15, Venu X1, vívoactive 6
for full releasenotes see: releasenotes.txt
  • Hello,
    A question. "Rct hor. filled" fills a rectangle left to right. How to do the opposite side, right to left ?
  • Hola #hundsmiachn y al resto alguien me puede ayudar a hacer esta pantalla para sram axs 12v?
  • A couple of days ago I have come across another bug in the system, when a heart rate strap is removed, DIY keeps heart rate values displayed, ie BPM, HR zone. All Garmin HR data fields and other app's display a "0" a few seconds after removing the HR strap.
    The background to it was I wanted to create "Dynamic Colours" to heart rate, speed and cadence so that if I had forgot to fit my HR strap or a battery was flat in my HR strap, speed or cadence sensor at the point of setting off for a ride or even a sensor drop out, I would see a flashing red zero which would alert me to a possible issue especially with the HR. Both speed and cadence I would notice when I start moving as the flashing red "0" would catch my eye better than a black unflashing "0".
    Everything worked perfect for speed and cadence and heartrate intially flashing "red 0" and when I fitted the HR strap, it would show my HR value in BPM and Zone. But when I removed the HR strap to see if it would return to a "red flashing "0" the heart rate reading would remain about 77bpm and on occasions would rise to 133 bpm and lock up at that.
    The issue is in all DIY's 1 - 6. I tried old apps that I have created in DIY and reversed what I have done today and tried saved as backups but the issue is present in everything I have done.
    It is not a major issue as you do not remove your HR strap whilst riding, but if it breaks or the battery goes flat whilst riding or a sensor drop out, it could take a long time to see the problem.
    After leaving the device for a few minutes and reopening the activity profile, HR values have gone back to "0"
    Today on my ride, I realised in 2022 when riding London Edinburgh London Audax,, my heartrate strap broke, but I did not notice it had until I was leaving a control when I saw the heart rate was "0", but, I never saw that prior to arriving at the control. On my download of my ride, I saw that the heartrate had failed far earlier than the control and stopped recording HR but DIY was still showing it.
    Now I understand why I never see any HR sensor dropouts whilst riding but on ocassions I can see by my download of the ride I have.
    This morning, I also had an oddity, DIY 6 shortly after removing the HR strap, it went to "0" for bpm, but DIY 1 kept showing a reading for bpm, but I could not repeat it.
  • I cannot say for sure, but most likely this is a Garmin issue.  In a CIQ program such as this, one is generaly just taking a value that Garmin provides.  I have seen other cases where the value Garmin provides to the CIQ program is different than the value displayed in a Garmin Data Field.  If this is the case, there is little the programmer can do.....
  • Is it possible to change the update intervall for graphs.
    I would like to see, say, the average or maximum speed every minute as a point in the diagram so that I can see the last 4 hours as a graph on a GPSMAP67.
  • Hi there :)
    I'm struggling with fontmapping for Fenix 8 and Forerunner 165 Music. I've managed to make adjustments for the Instinct 2X correctly in the past, so the process isn't completely foreign to me.
    However for both the F8 and 165 all the fonts are mapped to Roboto-Regular i.e. no initial mapping has been done which makes it a little different to the 2X.
    I've tried to do the mapping myself, but the designer doesn't reflect any changes to the mapping in graphical interface of the software.
    For example, as a starting point for the 165 I tried using the existing mapping from the Vivoactive 5 as they are both amoled screens with 390x390 resolution.
    Thus my starting point is in the fonts.txt file is:
    "Forerunner 165 Music" - "XTINY" ==> FNT_006B442500_TINY
    "Forerunner 165 Music" - "TINY" ==> FNT_006B442500_SMALL
    "Forerunner 165 Music" - "SMALL" ==> FNT_006B442500_MEDIUM
    "Forerunner 165 Music" - "MEDIUM" ==> FNT_006B442500_LARGE
    "Forerunner 165 Music" - "LARGE" ==> FNT_006B442500_XLARGE
    "Forerunner 165 Music" - "NR_MILD" ==> FNT_006B442500_NUMBER_XSMALL
    "Forerunner 165 Music" - "NR_MEDIUM" ==> FNT_006B442500_NUMBER_SMALL
    "Forerunner 165 Music" - "NR_HOT" ==> FNT_006B442500_NUMBER_LARGE
    "Forerunner 165 Music" - "NR_THAI_HOT" ==> FNT_006B442500_NUMBER_XLARGE
    "Forerunner 165 Music" - "S_XTINY" ==> FNT_006B442500_TINY
    "Forerunner 165 Music" - "S_TINY" ==> FNT_006B442500_SMALL
    "Forerunner 165 Music" - "S_SMALL" ==> FNT_006B442500_MEDIUM
    "Forerunner 165 Music" - "S_MEDIUM" ==> FNT_006B442500_LARGE
    "Forerunner 165 Music" - "S_LARGE" ==> FNT_006B442500_XLARGE
    "Forerunner 165 Music" - "S_NR_MILD" ==> FNT_006B442500_NUMBER_XSMALL
    "Forerunner 165 Music" - "S_NR_MEDIUM" ==> FNT_006B442500_NUMBER_SMALL
    "Forerunner 165 Music" - "S_NR_HOT" ==> FNT_006B442500_NUMBER_LARGE
    "Forerunner 165 Music" - "S_NR_THAI_HOT" ==> FNT_006B442500_NUMBER_XLARGE
    However there is no change to the GUI in the designer.
    I'm using designer 3.71
    What am I missing / doing wrong with my attempt to map fonts for the 165 and Fenix 8?
  • answered to this issue here already:
    https://forums.garmin.com/developer/connect-iq/f/showcase/206277/hms-diy-1-6/1839353#1839353
    One more thing. There is still a problem with the different font sizes on the new devices. Current designer version cannot display these fonts of the new devices correctly. I dont know when I have time to fix that, because it isn't a minor change.
    I hope I can fix that in the next few weeks.
  • Thumbsup
    Thanks - I read that, but didn't understand it correctly.
    I thought that perhaps the watches would display the fonts, and just that the designer couldn't, and when I saw that all the fonts weren't mapped yet I thought perhaps that mapping them was what @hundsmiachn hadn't had time to do.
    Appreciate you setting me straight on that point.
  • The watches will display the fonts.  Just not the designer.  What I did was find an older watch that had the same resolution and used that in the designer.  I was able to get fairly close doing that.
  • Ah, awesome. I'll give that a try! Thanks Steve.
